Old 07-11-2013, 12:41 PM   #15
ptuning
ptuning's Avatar
Drives: White FR-S
Originally Posted by swift996 View Post
Is that the current nozzle with the built in check valve? We can definitely test it. We have a bench mounted WMI system that we use for dyno testing.
ptuning is offline   Reply With Quote
Old 07-11-2013, 01:42 PM   #16
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Typical street customer will not have 4 channel wideband nor the ability to log individual cylinder pressure or knock. you and I can.... and it costs lol.
Nozzles and water filters are maintenance items like spark plugs or oil.
Toma is offline   Reply With Quote
Old 07-11-2013, 01:43 PM   #17
swift996
swift996's Avatar
I'm not certain. I know you guys have a lot of experience with the AEM system and was curious if you guys have tested this. I'm afraid that water dribbles/improper atomization at different spray rates would cause inconsistency and issues long term.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-11-2013, 01:45 PM   #18
Toma
A little water dribble at low speed wont hurt anything. If.your worried about it, install a low pressure check valve.
Old 07-11-2013, 01:48 PM   #19
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
It would seem to me that injecting pre-compressor (not always a good idea, but seems to be OK with the Innovate Twin-Screw) that the air would be churned enough at output that the cylinders would get an even mixture (whatever it ends up being at that point).
@ptuning do you have a ballpark of when your kit will be available?
Old 07-11-2013, 01:57 PM   #20
swift996
swift996's Avatar
The water dribble worries me because I'll be injecting right before the screws (innovate kit) and I don't know what excess moisture in the form of water drops will do to the blower unit?
Essentially the same concern as injecting pre-turbo.
Old 07-11-2013, 04:41 PM   #21
ptuning
ptuning's Avatar
Drives: White FR-S
We're hoping only 2-3 weeks at this time.
Old 07-11-2013, 04:43 PM   #22
ptuning
ptuning's Avatar
Drives: White FR-S
It shouldn't be an issue, but we'll test it shortly. It looks like we used the nozzle off of the bench system for one of our other shop cars. We have more on order though. We'll try to shoot a video as soon as the nozzles arrive.
The Following User Says Thank You to ptuning For This Useful Post:
swift996 (07-11-2013)
Old 07-11-2013, 04:58 PM   #23
Draco-REX
Corner Junkie
Draco-REX's Avatar
If all goes well, that should be about the time I do my SC install.
The Following User Says Thank You to Draco-REX For This Useful Post:
ptuning (07-12-2013)
PTUNING: PnP Water/Methanol Injection System w/Optional Failsafe ptuning Forced Induction 121 09-29-2017 03:01 PM
NA water meth injection? Ingen Engine, Exhaust, Transmission 26 06-03-2014 06:08 PM
AEM WATER METH METHANOL INJECTION KIT JPxM0Dz Engine, Exhaust, Transmission 10 04-14-2013 12:03 AM
Meth/Water Injection question showbe Engine, Exhaust, Transmission 9 10-18-2012 08:25 PM
ever seen fuel injection like this? carbonBLUE Other Vehicles & General Automotive Discussions 1 10-17-2012 03:17 AM
