Old 07-09-2013, 06:44 PM   #15
BFunk43
BFunk43's Avatar
Nice rims f0rge! 9.5 seems kinda big for the front though. From the pictures I've seen, the staggered setup looks pretty cool. I don't know, maybe I just like that style, or maybe staggered doesn't look as cool IRL?
BFunk43 is offline   Reply With Quote
Old 08-25-2013, 11:27 AM   #16
BFunk43
BFunk43's Avatar
Update: So my friend talked me out of the staggered setup and I ended up going 18x8.5 square with TSW Tanaka wheels and the 245/40/18 Hankook tires. I also put some Eibach Sportline springs on, got the windows tinted 20%, and went with the Agency Power catback exhaust. My car is dirty as hell in these pics.
Before:
After:
Old 09-27-2019, 05:58 PM   #17
xan_diego86
Originally Posted by Trojan_SC View Post
Depends on the tires even with the same size different tire companies' tires fit differently. I have 245/35/18 on 18x9.5 with Michelin PSS and no stretch or rubbing at all. You should be fine with 245/4 but my only concern would be rubbing unless you are running negative camber because that's more sidewall.
Can anyone recommend some good tires that run wide? Looking to run this spec but really dont want any stretching
xan_diego86 is offline   Reply With Quote
Old 09-30-2019, 08:55 PM   #18
Shizuka
Shizuka's Avatar
Drives: 2018 BRZ PP (Modified)
Are you on stock suspension?
If you're on coilovers just run 255/35s...
Shizuka is offline   Reply With Quote
FS: Work Emotion CR-Kai 18x9.5 +38 Jesse@JDLAutodesign Wheels and Tires 24 05-20-2013 06:56 PM
18x9.5 +38 Work Emotion CR kai Work Metal Buff Jive Turkey Wheels and Tires 22 05-20-2013 02:54 AM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 04:14 AM
Wheel Directory: Work Meister M1R 18x8.5 +?? / 18x9.5 +?? DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-03-2012 03:45 AM
