Old 03-07-2012, 01:37 AM   #15
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
Originally Posted by Nate219BRZ View Post
i take it its okay to run racing fuel in these...110 octane?
On a stock engine? Why? lol The engine is tuned to run on 91 fuel. If you were going to rebuild your engine for FI then sure, race fuel would help. But on a stock engine? You are just wasting your $$$.
tranzformer is offline   Reply With Quote
Old 03-07-2012, 01:40 AM   #16
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
I'd guess the college intern in the marketing department saw the world "premium fuel required" and converted that to "93 octane required"
91 AKI is 95 RON anyways I think, so the 93 doesn't make sense for that mistake.
So we use 91 or 93 then?
Snoopyalien24 is offline   Reply With Quote
Old 03-07-2012, 01:57 AM   #17
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Weird, I think all the pumps here are 87, 89, and 91. I could be wrong but... I thought so anyway.
Enemies is offline   Reply With Quote
Old 03-07-2012, 01:59 AM   #18
Canibuz
Canibuz's Avatar
Drives: BRZ SOON!
Just add a can of this every fill up and you will be good to go
The member of the BRZerhood formerly known as Reypt
How to spot a troll
Canibuz is offline   Reply With Quote
Old 03-07-2012, 01:59 AM   #19
Nate219BRZ
Nate219BRZ's Avatar
Drives: Rip 04 golf gti rip 05 scion TC
depends on the station, i know my local gas station has everything from 86 to 115, but they are really close to the track
Nate219BRZ is offline   Reply With Quote
Old 03-07-2012, 02:15 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Whatever they sell near you. We don't have 91, just 93 and occasionally 92.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-07-2012, 02:16 AM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
We don't know if the ECU is smart enough to retune itself by advancing timing to take advantage of higher octane fuels. If it's not, you won't only be wasting a lot of money per gallon but you'll be reducing performance at the same time.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-07-2012, 09:41 AM   #22
borge12
Drives: Tie Fighter
I just posted this in another thread, but it is relevant here too:
Speaking about the Genesis taking 87, saw these tweets from Scion:
https://twitter.com/#!/scion/status/176767072662065153
@scion So, the FRS can use regular gasoline and take a performance hit?
@adamjwiggins Correct, to get the optimal performance 91 Octane fuel is recommended. ^SP
borge12 is offline   Reply With Quote
Old 03-07-2012, 10:00 AM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Normal. Timing will be retarded and fuel economy will drop with performance making it basically pointless to bother.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-07-2012, 03:00 PM   #24
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
JUST GET PREMIUM
i think im done here.... if you are worried about paying a bit more for the gas, then you arent ready to pay for the car...
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 03-07-2012, 03:05 PM   #25
tranzformer
Drives: Zoom Zoom
Actually that isn't necessarily true about the fuel economy. We will have to wait and see once we get it in our hands if someone will test several tanks of regular vs. premium.
While different engine, different car the 3.8 GC has no difference between regular and premium. Owners have been saying that for a long time. Doubt we will see much with the BRZ. Probably down on a few HP ~5 but that is about it.
Old 03-07-2012, 03:21 PM   #26
carbonBLUE
Reverse Burnouts
does the GC have a 12.5 compression ratio?
the GC has a 10.4:1 compression ratio, you can run anything in it
when you are at a 12.5:1 ratio you cant run anything below 91 because the engine will detonate
there is no way anyone should run less than 91, if you do, you're an idiot, go ahead and blow your engine up, shame to see the first 86 off the road cause some dumbass cant fill it up with the right fuel
my celica says PREMIUM REQUIRED so what do i do... fill it up with premium... its easy people... never once did i ask myself "uhhhh maybe 87 will be fine?... yup "
(wont forget you)
2011 Infiniti G37x
Old 03-07-2012, 03:23 PM   #27
tranzformer
Drives: Zoom Zoom
Originally Posted by carbonBLUE View Post
When you are at a 12.5:1 ratio you can't run anything below 91 because the engine will detonate.
There is no way anyone should run less than 91, if you do, you're an idiot, go ahead and blow your engine up, shame to see the first 86 off the road cause some dumbass cant fill it up with the right fuel?
Why don't you give Scion a lesson in engine management and proper use of octane rating?
Old 03-07-2012, 03:26 PM   #28
carbonBLUE
Reverse Burnouts
i dont need to, its common sense, if my 2zz-ge has a 11.5:1 compression ratio and someone has tried 87 and had detonation problems, why would a 12.5:1 compression handle 87 any better... or if the car manual says USE PREMIUM, and says it on the gas lid, in the car, why would you use anything different, stop being cheap, treat the car right and give it 91-93 octane
(wont forget you)
2011 Infiniti G37x
