Old 07-02-2013, 09:24 AM   #15
forwallblakmail
Troll Level: Expert
forwallblakmail's Avatar
Drives: '13 BRZ, '18 F150 3.5EB, '07 Cayman
This happened to me. I tired to have the dealer replace it but they said "their hands are tied" because they havent seen a broken one yet. I had to buy one for 320$ +3 canolies for the parts guys (true story). I still drove on mine for a few months though, it just clicked on acceleration decel. I think ProSolo with V710's did it.
Easy enough to replace though.
Nick K.
NASA ST5/TT5 #130
Southeast Region
forwallblakmail is offline   Reply With Quote
The Following User Says Thank You to forwallblakmail For This Useful Post:
whataboutbob (08-09-2013)
Old 07-02-2013, 09:55 AM   #16
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Another user here broke his differential this weekend.
I wonder if this axle issue will affect stock height cars as much, since your axles have a different angle than the OEM meant for.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-02-2013, 09:57 AM   #17
forwallblakmail
Troll Level: Expert
My car was stock height when mine broke.
Nick K.
NASA ST5/TT5 #130
Southeast Region
Old 07-02-2013, 10:02 AM   #18
Kido1986
Dodging cones
Kido1986's Avatar
Well damn. Blows that idea out of the water.
Also, I am hoping I can continue to do 5k launches on concrete for many years :P
Old 07-02-2013, 10:05 AM   #19
Jeffsu350
Drives: Frs
Sounds like aftermarket axles should be developed ...
Jeffsu350 is offline   Reply With Quote
Old 07-02-2013, 10:46 AM   #20
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
drive shaft shop makes them.
Ranatsu is offline   Reply With Quote
Old 07-02-2013, 10:47 AM   #21
forwallblakmail
Troll Level: Expert
I had a co-driver at a ProSolo (concrete surface)
Over 25 launches with slicks. Could have taken its toll.
Nick K.
NASA ST5/TT5 #130
Southeast Region
Brianjoy77 (08-15-2013)
Old 07-02-2013, 11:17 AM   #22
qoncept
qoncept's Avatar
Cannolies?? Sounds like you didn't raise enough hell. :happy0180:
qoncept is offline   Reply With Quote
The Following User Says Thank You to qoncept For This Useful Post:
forwallblakmail (08-12-2013)
Old 07-02-2013, 02:55 PM   #23
Kido1986
Dodging cones
Kido1986's Avatar
My car has that many concrete launches but on 215 RS3s. They usually spin a little, never a HARD bite
Old 07-02-2013, 03:21 PM   #24
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Pretty sure Crawford Performance changed out the axles on their BRZ after having some issues. No clue where they sourced them from but it may be worth contacting them about it.
cobrabyte is offline   Reply With Quote
Old 07-02-2013, 03:50 PM   #25
simpleisbest
Senior Citizen
Drives: Scion FR-S
Probably these:
http://www.driveshaftshop.com/featur...-in-rear-axles
simpleisbest is offline   Reply With Quote
The Following User Says Thank You to simpleisbest For This Useful Post:
cobrabyte (07-02-2013)
Old 07-02-2013, 04:18 PM   #26
toro73
toro73's Avatar
Drives: 2013 scion FR-S
Looks like the Launches and the extra grip are taking there toll indeed!
toro73 is offline   Reply With Quote
Old 07-03-2013, 08:14 PM   #27
carlitosway6891
Drives: white out project fr-s
same exact thing happened to me...driver axle broke on the inner joint.....i took mine apart and seen it was the carrier assembly split in two. i thought it was cause my car was too low too....i ended up raising the rear about a half inch and crossed my fingers the other side isnt on its way too....
carlitosway6891 is offline   Reply With Quote
The Following 2 Users Say Thank You to carlitosway6891 For This Useful Post:
TurtleFace (01-31-2016), whataboutbob (08-09-2013)
Old 07-03-2013, 08:45 PM   #28
Jeffsu350
Drives: Frs
Thanks for sharing!
Please let us know if the other failures were also at the cage
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 01:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 03:31 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 05:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 11:17 AM
