Old 07-03-2013, 07:30 PM   #15
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
94 Chevron but at a cost of over $6 per gallon.
Muaddib is offline   Reply With Quote
Old 07-03-2013, 07:50 PM   #16
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by SkullWorks View Post
Not sure what you think you might be inferring...E85 is commonly understood to be 109 octane
Usually 91 octane no ethanol. I try to get 93 whenever i can (tolled interstates or when i go down to nj or nyc)
TM is offline   Reply With Quote
Old 07-03-2013, 08:07 PM   #17
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Just wondering but do you guys still get the chirp with 93 octane+ gas? Or is it an ethanol content thing?
- poor 91 octane guy
l0aded is offline   Reply With Quote
Old 07-03-2013, 08:14 PM   #18
wheelhaus
wheelhaus's Avatar
Originally Posted by topazsparrow View Post
94 Chevron. Smells so good
I've read avoiding gas with ethanol will help avoid the chirps. I'm at 1500km and chirp free so far.
It's not a direct correlation. Avoiding E10 helped some, not others.
E85 should not be used in place of gasoline or E10 unless the car is specifically designed for "flex fuel" or has been tuned for E85. It's stoichiometric ratio is different and needs to run richer. Simply dumping it into a car that's not designed to use it will cause it to run lean.
The whole octane thing is pretty well covered as to "why" we need high octane for the FA20 engine. Those at low altitude should stick with 93 (RON+MON/2) minimum, higher altitude can use 91 with no danger due to lower atmospheric pressure. In short, the high octane simply makes it more stable and resistant to preignition (a.k.a. ping, detonation, knock, etc). This, in turn, allows the ECU to advance timing as far as it's programming allows, and allows tuners and builders to be more aggressive.
wheelhaus is offline   Reply With Quote
Old 07-03-2013, 08:41 PM   #19
roddy
roddy's Avatar
Drives: '13 Ultramarine
For me, yes. Others have said differently, but in my particular case, The 94 octane is an E10 blend and chirps like crazy. In my area, Shell's premium (91 Octane) has no Ethanol and I get no chirps when using it. As much as I HATE the crickets, I usually run the 94 in the summer as the car feels better when using it. In the colder months it doesn't seem to make much difference.
Old 07-03-2013, 08:47 PM   #20
roddy
roddy's Avatar
Originally Posted by Brahsbrah View Post
Wish we had something other than 91 Octane here in Nova Scotia.
Did you ever have Sunoco stations in NS? Here in Ontario, all of the Sunoco stations were re-branded as Petro Canada or Husky a couple of years ago. Most of the ones that had 94 and were changed to PC kept the 94.
Old 07-04-2013, 02:47 AM   #21
BlackMagicSir
Drives: Gt86
100 Octane where I'm from. On a related note, does anybody know the pros/cons between a 100 Octane fuel and an E85? I googled it but there wasn't a helpful result in the first page.
BlackMagicSir is offline   Reply With Quote
Old 07-04-2013, 10:20 PM   #22
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
Haven't noticed it, although I usually get gas at Esso. I'll have to keep an eye outfor Petros and have a look.
I need those 3x Esso points though on Supreme
Brahsbrah is offline   Reply With Quote
Old 07-05-2013, 12:20 PM   #23
reeves
Nothing to infer.. the pump is labeled 104 here.
reeves is offline   Reply With Quote
Old 07-05-2013, 12:54 PM   #24
Splat
Drives: FR-S ultramarine
Holly Cow
Splat is offline   Reply With Quote
Old 07-08-2013, 12:17 PM   #25
SkullWorks
Drives: SSM LT MT BRZ
That is interesting.
SkullWorks is offline   Reply With Quote
Old 07-08-2013, 08:05 PM   #26
Steve201brz
Since day 1 I've been using 93 and never had any problems n it runs great. One time on a long drive I made a pit stop for gas and a drink, it was a long drive n my buddy was going to fill up n I forgot to tell him 93... So I got a tank of 87 and I definitely felt a difference on the those last 200 miles. Might be a decent difference in octane but now I definitely get 93 or higher if I can find it. I feel guilty giving it lower lol
Steve201brz is offline   Reply With Quote
Old 07-08-2013, 10:55 PM   #27
PStaff716
PStaff716's Avatar
Drives: 2013 Raven FRS 6MT
93 octane from Sunoco..it's just so damn close to my house. Anyone know if that's an inferior company to purchase gas from? Never really thought too hard about it..
PStaff716 is offline   Reply With Quote
Old 07-09-2013, 10:06 AM   #28
topazsparrow
Drives: slow
Same, It's about 1.53 / L right now for me.
topazsparrow is offline   Reply With Quote
Octane booster? SanDiegoFRS Off-Topic Lounge [WARNING: NO POLITICS] 5 02-17-2013 01:20 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
93 Octane Smokinbuffalo Northwest 20 09-02-2012 05:24 PM
110 octane EZWood Engine, Exhaust, Transmission 19 06-29-2012 08:12 PM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 12:22 PM
