Old 06-21-2013, 09:50 PM   #15
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
This is normal.
Jond63 is offline   Reply With Quote
Old 06-22-2013, 03:06 AM   #16
ric342
FR-S driver
ric342's Avatar
Drives: ULTRAMARINE Scion FR-S
what about when you go neutral and slow down and then to a stop the car raddles. sounds like it is coming from the diff?
ric342 is offline   Reply With Quote
Old 06-22-2013, 03:21 AM   #17
topazsparrow
Drives: slow
I don't get anything like that. When you say neutral do you mean in gear with the clutch depressed? Or do you mean the shifter is in neutral and your foot is off the clutch?
The diff is known to be a bit noisy but shouldn't be making any noises unless you're turning.
topazsparrow is offline   Reply With Quote
Old 06-22-2013, 04:13 AM   #18
fistpoint
Drives: Supercharged Golf Cart
2000rpm has been the "effective" minimum rpm of any 4 cylinder I have ever driven.
fistpoint is offline   Reply With Quote
Old 06-22-2013, 08:35 AM   #19
Mikem53
Drives: FR-S 6MT
Originally Posted by topazsparrow View Post
not noticeable from a stop as I'm usually above 2k rpm in 1st gear when taking off.
It's mostly in 2nd gear when moving really slowly (stop and go traffic) and I'm too lazy to shift into 1st. It's fine until you load the engine then it's noisy.
I'm not sure why everyone has an opinion on what I SHOULD be doing when I'm simply asking if anyone else has run across this.
Yes.. Normal.. As long as you are not excessively loading it at low rpms.. It's fine..
Its not all engine noise either.. Clutch and gears make noises with low rpms that rattle on thru..
Mikem53 is offline   Reply With Quote
Old 06-22-2013, 09:41 AM   #20
whtchocla7e
Drives: 2013 FR-S Hot Lava
When I'm gentle on the gas, the rattle is very quiet.
I don't know of any way to get the car moving in 1st/2nd at 10mph or less without the rattles. Anyone have a secret?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 06-22-2013, 09:49 AM   #21
Mikem53
Drives: FR-S 6MT
Turn the radio up..
Or slip the clutch alot.
Old 06-22-2013, 10:06 AM   #22
Mandy
I came from a motorbike
Mandy's Avatar
Drives: Firestorm 2013 FR-S 6MT
Is it only when you have the car in neutral and you're coasting to a stop? I believe it may be the sound of direct injection.
Mandy is offline   Reply With Quote
The Following User Says Thank You to Mandy For This Useful Post:
e46m3 (06-22-2013)
Old 06-22-2013, 01:36 PM   #23
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
Downshift to 2nd if your going really slow like under 10mph might as well go back to 1st gear..your not driving an automatic you do the work..lol
CAMBAM_6 is offline   Reply With Quote
Old 06-22-2013, 01:59 PM   #24
hendryhendry
Drives: hot lava FR-S
I had the same problem at low RPM, and I brought my car to Longo to find out whats wrong with this car. The mechanic guy at Longo said ,"It's normal." Also he told me that FRS makes weird noises. :/
hendryhendry is offline   Reply With Quote
Old 06-22-2013, 02:18 PM   #25
whtchocla7e
I would ask for that statement in writing.
Old 06-22-2013, 02:49 PM   #26
Cyau
Cyau's Avatar
Drives: UltraMarine FRS MT
I was told from multiple people, first gear is only to get the car moving, once you start moving you should go second. Never drive in first, unless you're just in parking lot and needs to move 10feet to park
Cyau is offline   Reply With Quote
Old 06-22-2013, 02:59 PM   #27
gzpermadi
gzpermadi's Avatar
Drives: Toyota 86 Silver
mine does too.
chatter sound when traveling 1000-2000 RPM in 2nd gear.
better use 1st gear for very slow stop and go traffic.
gzpermadi is offline   Reply With Quote
Old 06-22-2013, 07:01 PM   #28
id338
My FR-S will rattle a bit if it gets too low. My WRX rattled a lot too.. same exact sound.
id338 is offline   Reply With Quote
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 04:52 AM
