Old 06-18-2013, 07:59 PM   #15
Sac-BRZ
Drives: BRZ Limited AT
Just found these wheels on TireRack, had to do a double take. Could buy them & have them painted and still come out cheaper than GramLights.
Sac-BRZ is offline   Reply With Quote
Old 06-19-2013, 12:01 AM   #16
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Originally Posted by djdnz View Post
Well I ordered a set in 18x9 square with 245/35/18 Continental ExtremeContact DW so I'll post some pics when they arrive and I get a chance to throw them on.
That's the exact setup I am looking to buy. Are you on stock suspension?
The Racers Line is offline   Reply With Quote
Old 06-19-2013, 12:09 AM   #17
djdnz
1337
Drives: 2013 BRZ WRB S/C
At the moment I am, I have RCE Tarmac Zero on the way but the wheels will arrive first. I'll try mounting them on the stock suspension at first until the coils arrive.
djdnz is offline   Reply With Quote
Old 06-19-2013, 12:21 AM   #18
The Racers Line
Sweet, the only thing I'm worried about with the setup is the tire rubbing on the strut. I'm lowered on h&r Supersports and hopefully they will clear.
Old 06-19-2013, 11:09 AM   #19
jflogerzi
jflogerzi's Avatar
They look pretty damn good, but man the weight. wheel is on average 3-4LBS heavier per wheel.
Old 06-19-2013, 11:38 AM   #20
djdnz
1337
Heavier than what? Gram Lights are not exactly feather weights.
Stock, 17x7: 20.1lbs
Gram Lights, 18x9.5: 22lbs (best source I could find was 18x8.5 +38 21.75 lbs, 18x9.5 +22 22.5 lbs; source; wrong offset, so I rounded down to 22lbs which I have heard floating around a few times)
BR10, 18x9: 22.6lbs
2.5lbs heavier than stock (and +1" diameter, 2" wider)
0.6lbs heavier than Gram Lights. Then when you throw on tires with a similar stretch on both, you are at minimum 10mm wider on the tire which will add that weight back to the Gram Lights. Also $1300+tax cheaper for a set, coincidentally that's enough for a quality set of RCE Tarmac Zeroes - which is exactly what I did with the extra :P
The Following User Says Thank You to djdnz For This Useful Post:
joergasm (06-21-2013)
Old 06-19-2013, 02:19 PM   #21
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
I laugh when people complain about few pounds added to the car's overall weight. Maybe they should start cutting their own weight instead.
hanabie is offline   Reply With Quote
The Following 4 Users Say Thank You to hanabie For This Useful Post:
Firestorm_86 (09-26-2013), joergasm (06-21-2013), OjiGeorge (12-22-2013), SkAsphalt (06-19-2013)
Old 06-19-2013, 04:07 PM   #22
djdnz
1337
Kitty approved. They look wide...
If anyone is interested, this is the look of 245/35/18 Continental ExtremeContact DW mounted to 9" wheels.
The Following 3 Users Say Thank You to djdnz For This Useful Post:
hanabie (06-19-2013), joergasm (06-21-2013), The Racers Line (06-19-2013)
Old 06-19-2013, 04:17 PM   #23
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Hahaha YES! People spend 2-300 dollars on light weight batteries to shave 10 pounds or less...could do that by spending less on poor food
but I cannot talk, I weigh 260. Being able to bench every pound that I weigh is nice, but still, I am a big dude (6'4) and could stand to lose a few. Every time I worry about wheel weight, I immediately tell myself to lose weight instead. I know up sprung mass is different and one pound is multiplied by X but still. I could lose 30 pounds and solve the whole issue right there :p
OH and to keep on topic This rims are on my possible buy list. They are nice, would look good painted and are affordable. I wish the Konig Torches came in nice sizes for 5x100 but they do not. Thankfully Bremmer made something decent for us at a very reliable price.
Old 06-19-2013, 04:47 PM   #24
hanabie
hanabie's Avatar
I was going for konig torch silver until I saw the sizes ==
I'm thinking of getting Bremmer instead too.
The Following User Says Thank You to hanabie For This Useful Post:
SkAsphalt (06-21-2013)
Old 06-19-2013, 04:53 PM   #25
hanabie
hanabie's Avatar
really need more pictures on the face. Where did you get your tires from? Tirerack? How much are you going to lower your car? Adding any spacer?
Old 06-19-2013, 08:24 PM   #26
qtwre
Drives: White FR-S
It's the difference of sprung vs unsprung weight. Wheels, brakes and suspension count as unsprung weight which is important to keep down for handling. A few pounds can make a difference when talking unsprung weight.
[ame="http://en.wikipedia.org/wiki/Unsprung_mass"]Unsprung mass - Wikipedia, the free encyclopedia[/ame]
qtwre is offline   Reply With Quote
Old 06-19-2013, 10:26 PM   #27
The Racers Line
Those look so wide! I can't wait to see them mounted.
Old 06-19-2013, 10:38 PM   #28
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
Pug face...
...as in need more concavity.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Wheel Directory: 3SDM 0.01 18x8.5 +35/18x9.5 +35 Adrenaline Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 10-14-2016 02:24 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 09:10 AM
Wheel Directory: Bremmer Kraft BR10 18x9.0 +42 djdnz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 11-29-2013 03:32 PM
Wheel Directory: XXR 531 18x8.5 +35 / 18x9.5 +35 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-07-2013 01:43 PM
Bremmer Kraft grgonium Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-14-2012 08:30 PM
