#15 |
Drives: FRS
I got one axle out using a 3ft bar. Now that one axle is out, however, when I pry on the other side the diff just slides on the ground and I cannot get the leverage to get the other axle out of the carrier. I thought about bolting it back up to pry on it but I don't think the axle would pop out with the carrier in place. I'll have to find some clever way of securing it so i can get leverage. It is a real PITA.
#16 |
Drives: Attitude
Hold the axle, push the diff off it?
#17 |
Drives: 2JZ FRS
The special tool is probably a slide hammer. That's what we use at the shop to remove clipped in axles. Then you wouldn't have to worry about the housing moving like you do with the pry bar. Maybe wedge a 2x4 on the opposite side to keep it from walking across the floor while prying?
| The Following User Says Thank You to spitfire481 For This Useful Post: | wootwoot (06-08-2013) |
#18 | |
Drives: White 86 Sport Plus
#19 |
Drives: FRS
It is a stock frs diff with a cusco 4.55 FD.
Thanks for the suggestions. I'm going out to try and get it done now. |
#20 |
Drives: FRS
Got the axles out. Yay!
Installing the rear subframe inserts right now. I got one of the rears in but I cannot get the drivers side rear hole to line up. I've hit it with a hammer, pry bar, jacked the car up, jacked it down, etc. just can't get it to line up. I may try to lessen the front sub frame bolts to try and wiggle it in place. If it ant one thing it is another! |
#21 |
Drives: FRS
Loosened up the front sub frame bolts and was able to line it all back up again.
Done for the day. Hopefully I can finish tomorrow. Thanks again for all the help guys! |
#22 |
Drives: Frs
The SST looks like a slide hammer to me. Glad pry bar worked!
-Robert
#23 |
Drives: FRS
Got the diff in! Also installed the whitleine sub frame bushings and diff bushings.
Need one last thing: what are the tightening specs on the rear sway bar mount? |
#24 |
Yes, Toyota fr-s
Drives: 1991 MR2 Turbo T-Top, Gen3 3SGTE
Any pix of the install? Also, what do you plan to do with the spare diff?
#25 |
Drives: FRS
Just finished everything. I did the following:
Whiteline trans mount insert Whitleine subframe inserts Whiteline diff cradle inserts Kartboy rear shifter bushing Pentosin fluid Cusco 4.55 final drive TRD intake It was a loooooooong weekend! Shifting feels great. Very smooth and precise. I love the subframe inserts. They are by far the best upgrade of the lot. I am going to drive the car for the week as is and see how things go. I was a bit overwhelmed by the NVH on the first test drive. It wasn't offensive but the change is very evident. No pics. I bought a second one so I cold swap it out if something goes wrong. The change in gearing is much more profound than I thought it would be. Like I said, I'll have to run it over the week and see how it all goes. |
#26 |
Drives: FRS
Does anyone know if it is safe to take out two of the four whiteline diff inserts? As in, either the two fronts or the two rears? The more I think about it the less I understand why stiffening up the diff that much is a good idea. If I can take two out and tone down the NVH it would be nice. But I don't want to put any added stress on anything in the process....
#27 |
Drives: A Potential Traffic Ticket
Shift springs? Can you post a link where you got them? Thanks!
#28 |
Drives: FRS
I got them off the forum but I don't know if they are still a vendor.
Here is the company: http://www.mtecind.com/ |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Where can I buy the trans and diff washers? | ngabdala | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 05-09-2013 01:35 AM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
| So what is the Big Diff? (pun intended sorry) | Erik @ GBox | Engine, Exhaust, Transmission | 22 | 10-21-2012 10:21 AM |
| T1R Rear Diff colars ! | AJ PwR | Engine, Exhaust, Transmission | 0 | 10-09-2012 11:00 PM |
