Old 02-29-2012, 06:07 AM   #15
OrbitalEllipses
Drives: Attitude
ITBs on a Subaru boxer engine have been attempted and not succeeded in getting past design issues. Expect an ITB setup by a reputable company to be beyond most people's means.
Old 02-29-2012, 08:49 AM   #16
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
This. Not to mention with engine bay space being such a large factor with this car I don't see it happening.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline   Reply With Quote
Old 03-05-2012, 04:21 AM   #17
go baby go
Drives: soon to be 86
how tough would it look with four trumpets from the ITBs sticking out of the bonnet.
go baby go is offline   Reply With Quote
Old 03-05-2012, 06:22 AM   #18
OrbitalEllipses
Drives: Attitude
http://hargettprecision.com/index.ph...che-itb-s.html
I can't see many people buying something similar for this car at that cost. Would it be so f'ing cool? Yes. The reality is that the flat engine is rather expensive to engineer certain parts for. Porsche is the only other manufacturer still using them and their engines are on another level, including cost-wise. However, if an ITB setup were to come to market for a flat 4 Subaru engine this would be the platform I'd expect to see it in, given the limited application in a F/I setup.
EDIT: This car, from what I've seen, has throttle-by-wire. That means an ITB setup gets that much more complicated since you don't have a simple mechanical link between the pedal and throttle body. Some kind of electronic mumbo-jumbo would have to be figured out in regards to the electronic motor that actuates the throttle body, or in this case, 4 ITBs. I simply don't see that kind of research and development going into this platform.
What is this a muscle car? You got something you want to talk about? I don't need to make my car LOOK tough...
I'd rather see something like this:
Old 03-05-2012, 10:11 AM   #19
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
throttle by wire is only a limitation if you want to keep the stock programing
people jumping over to ITBs are likely to run stand alone so whether the throttle operation is electronic or mechanical is of no concern.
you can most likely drop in a mechanical pedal and call it a day.
more work sure, but at the level of prep where ITBs come in the car is probably in pieces anyway.
Old 03-05-2012, 11:02 AM   #20
OrbitalEllipses
Drives: Attitude
Unpossible for a street registered car that needs to pass emissions, in most states. Need the stock ECU for that.
Old 03-05-2012, 11:03 AM   #21
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I like how easy you make that sound. Obviously I think better intake manifold designs (Plastic is light and smooth though) will have a larger market hold than ITBs.
chulooz is offline   Reply With Quote
Old 03-05-2012, 04:31 PM   #22
serialk11r
Drives: '06 AM V8V Coupe
Another problem with mechanical throttle is that load is controlled with both the throttle and the valve timing, you'd need to lock the VVT-i in the position for highest load at a given rpm if you want load fully controlled by throttle, but you'll have very bad issues with idling and low load stability. For best results ITB should be integrated into the stock system in some sense...
Old 03-05-2012, 06:29 PM   #23
SkullWorks
Drives: SSM LT MT BRZ
ITB...why exactly?....you haven't even gotten the car yet and you want to sacrifice low end torque for a little bit of response and top end?
I think there are gains to be had in the intake manifold, but I think to really make this motor come alive we will be well into the internals, or doing proper finishing of the motor with a turbo.
Don't get me wrong I like a set of stacks as much as the next guy but...you need some serious runner length to keep the torque peak near stock, or even with in the limits of stock redline...not a huge potential on this motor at the current time, maybe later when they can spin like a rotary...just no time soon.
SkullWorks is offline   Reply With Quote
Old 03-05-2012, 06:57 PM   #24
chulooz
Registered you sir
chulooz's Avatar
couldnt have said it better myself. When it comes time for some real high performance, boost will need to be entered into the equation. Sorry horsepower-phobic people.
Old 03-06-2012, 09:49 PM   #25
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
personally i hate the maintenance of a turbo car but i would like to get some high numbers on this one, NA just doesn't cut it lol
Old 03-08-2012, 03:13 AM   #26
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
i hope they make a cosworth manifold
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 03-08-2012, 05:35 AM   #27
Levi
Drives: Toyota
Die-Hard-Turbo-Fans make me hatting turbos.
Levi is offline   Reply With Quote
Old 03-08-2012, 10:18 AM   #28
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
I'm intrigued what Costworth is doing.
GT86 Confirmed Pricing Jayvelliott Scion FR-S / Toyota 86 GT86 General Forum 42 01-31-2012 05:21 AM
Confirmed NZ spec will called '86' bricktop AUSTRALIA 2 01-31-2012 12:41 AM
Confirmed Torsen Differential Andy Engine, Exhaust, Transmission 50 12-12-2011 11:01 PM
