Old 05-31-2013, 03:21 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I get this in warm weather sometimes.. a few weeks ago it cranked away all by itself until it decided to stop. Next push of the button it started right up. :shrug: no idea. There are some other threads about that issue.
Oh and I agree, it's not the oil.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-31-2013, 04:42 PM   #16
Mokiki
Drives: FR-S firestorm
Originally Posted by CSI:86 View Post
I have a March 2013 build Toyota 86. Has 5500kms (3400 miles), had a oil and oil filter change at 2000kms with Mobil 1 5w30. Always filled up with BP ultimate 98RON (93AKI)
put ur key in, turn to on (don't start the engine), wait for 5-10 seconds then turn the engine on. I started doing this, and haven't had long start since (maybe just the weathers getting warmer here :-)
Mokiki is offline   Reply With Quote
The Following User Says Thank You to Mokiki For This Useful Post:
FR-S Hot Lava (05-31-2013)
Old 05-31-2013, 05:00 PM   #17
FR-S Hot Lava
FR-S Hot Lava's Avatar
Drives: FR-S Hot Lava (AT)
I've done the exact same thing as mentioned above and I haven't had anymore problems.
FR-S Hot Lava is offline   Reply With Quote
Old 05-31-2013, 08:00 PM   #18
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
It's normal for the car to take a bit longer to start when it's cold out, but in your case, I would attribute the the extended start time to the unichip, like a few others have mentioned. We're not talking about freezing temperatures here, so your oil is just fine.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 06-01-2013, 04:37 AM   #19
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
Problem still there, after taking off unichip. Thinking about selling unichip to get ecutek stg 2
CSI:86 is offline   Reply With Quote
Old 06-01-2013, 11:38 AM   #20
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Recently, the weather here in Sydney Australia has been a bit chilly. About 10 degrees celsius on a 6am morning. I find the car takes quite a long time to start up. On a cold start, it takes a good 5 seconds for the car to start up. On a warm start, it starts instantly. This happens all the time on a cold start.
My girlfriend's 86 is a April 2012 build has 18000kms, has had two services with 0w20 castro Oil, very occasionally has the idle dip problem, but always starts immediately on a cold start. She only has a K&N filter in hers.
I have a takeda intake, Borla UEL and Unichip.
Is this to be of any concern?
EDIT: I have taken out the unichip. Still has the same problem. I press the start button twice to on mode, leave for 10 secs, clutch in press button... still takes 5 secs to crank up.
Will take it to the dealer soon.
i had those problems too, (my car is made in march) the problems just disappeared at 20k miles for no reason... lol
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 06-02-2013, 04:37 AM   #21
CSI:86
86 = First New Car
OK hopefully will disappear with more driving.
Booked in for a check up at dealer on Wed
Old 06-02-2013, 05:05 AM   #22
JS86JS
JS86JS's Avatar
Drives: 2013 Toyota 86 GTS, Marine Blue
I've got 10,000km on my car, picked up in feb only 12km.. I have had an oil change from Toyota at about 2k and I have an injen CAI intake (which has supposed problems) and an injen SES exhaust. My car is parked outside most days in the cold, 7 degrees avg. and I have had no problems and an instant start. I don't believe it's the mods fault, but in saying that I don't know what my oil is...
check out my on-going build here: My blue 86
JS86JS is offline   Reply With Quote
Old 06-02-2013, 05:13 AM   #23
CSI:86
86 = First New Car
Yeah its weird... Whats even weirder, say i park in a shopping centre and leave the car for 2-3 hours. And i come back to start the car, it still takes pretty long to start the car (roughly 2-3 secs) but not as long as it takes to start it when its a cold start in the morning (5-6 secs).
I park in a garage. Gets to around 10 degrees on a cold morning. Your oil will be 0w20. All Toyota dealers service with either Toyota Genuine 0w20 oil or Castro 0w20. I changed the oil to 5w30 myself with a Subaru oil filter.
Old 06-02-2013, 06:59 AM   #24
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I have started a GT86 in below -15°C many times and it was almost instant every time.
What you're describing is definitely something wrong.
Old 06-02-2013, 09:38 AM   #25
Mikem53
Drives: FR-S 6MT
Sometimes the variable valve timing system needs to be "reset" for a cold start.. So oil needs to circulate and pressurize the system for it to function properly and be in the right position for a cold startup, since it was elsewhere when it was shut down warm. You might be experiencing this delay. If the oil is thicker, it could also take longer to actuate the solenoid(s). But I agree.. Should not be the oil as 5w is thin enough. I experienced this delay at times with VANOS in my M3 and this system is hydraulically activated too..
Mikem53 is offline   Reply With Quote
Old 06-04-2013, 11:52 AM   #26
CSI:86
86 = First New Car
Mechanic and the dealer service centre says he is baffled. Everything is fine. It looks like they are going to lift the engine to look at spark plugs and ignition coils. If they are going to look at the spark plugs, i will be asking them to change the spark plugs to iridium NGK while they at it. Luckily, i only live 15 mins walk away from the dealer
Old 06-04-2013, 12:00 PM   #27
CSI:86
86 = First New Car
Originally Posted by Freetime View Post
Because you clearly know more than the Toyota/Subaru engineers. Especially when yours isn't working right...
Only way to figure it out is to start changing things one a time until it doesn't do it anymore. Maybe you should start by changing your oil....
Yes i do know more than the Toyota/Subaru engineers since it is scientifically tested that 5w30 oil can start a car instantly in weathers as low as -25 degrees celsius. Learn about engine oil first before suggesting others to change their oil
Old 06-17-2013, 12:10 AM   #28
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Mine did that once. Hopefully it will not happen again. Strange thing is that the motor was actually warm. So i am assuming it is the starter or the wiring is somewhat faulty from the factory.
Muaddib is offline   Reply With Quote
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 01:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
ABS Problem chrislee2423 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 07-09-2012 05:06 PM
anyone with this problem? debs0712 Scion FR-S / Toyota 86 GT86 General Forum 2 06-30-2012 11:17 AM
