Old 05-29-2013, 05:42 PM   #15
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by SkullWorks View Post
My car has same issue, both sides, it will "snap" into place there under the light but soon slips back out
yeh, mine does the same, i think it may be caused by the play allowed by the incorrect fastener there (part #4, goes through the hole in bracket #3)
The part # for that fastener is 909130132 if anyone wants to try before mine arrives.
The Following User Says Thank You to xjohnx For This Useful Post:
charged86 (06-19-2013)
Old 05-29-2013, 05:44 PM   #16
SkullWorks
Drives: SSM LT MT BRZ
Yeah, that's not it,
I have the factory pieces there, properly installed I feel as if the back of the bumper where it engages the clips maybe rounded or the plastic clip is rounded or deformed from coming off and on several times...
SkullWorks is offline   Reply With Quote
Old 05-29-2013, 05:46 PM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
I'll be testing the clips as well.
SkullWorks (05-29-2013)
Old 05-29-2013, 06:05 PM   #18
qoncept
qoncept's Avatar
On the WRX the rear part of the front bumper clips to the fender. The fender is cheap stamped steal and the tab sags and bends over time. On every WRX. I sure hope the BRZ isn't the same.
qoncept is offline   Reply With Quote
Old 05-29-2013, 11:43 PM   #19
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
yes. I got the same issue. started off just a bit off and now its a lot worst.
make a diy if you find the problem before I do
Out of the FRS game
Mr.Jay is offline   Reply With Quote
The Following User Says Thank You to Mr.Jay For This Useful Post:
StarsGarrador (06-05-2013)
Old 05-30-2013, 05:26 PM   #20
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Had this same problem. I scratched my head for at least an hour taking the bumper on and off trying to figure it out. Eventually one of the guys here said it felt like something was pushing the bumper down as we could push it in a bit and it would kinda "pop" back out. We tracked it down to the front lower air dam(hard plastic piece under the bumper/radiator) and the bottom of the bumper lip/tabs, we messed with it for a bit until everything lined up perfectly, and voila no more gaps!
Please note we are using the APR Carbon front lip, so we thought that may have been contributing to the problem with getting everything lined up as we had no flex in the bottom of the bumper, but hopefully this may help some of you, or at least give you an idea on where to look.
Thanks!
Rick
Edit, I stole this picture from @DC-FRS, hope he does not mind
The large plastic air dam(#22 in pic) was not sitting right with the lower portion of the bumper and was sort of forcing the bumper down a bit. I had to push, pull, prod, poke, talk nice to, and yell at it until it was all lined up perfectly.
RallySport Direct is offline   Reply With Quote
The Following 7 Users Say Thank You to RallySport Direct For This Useful Post:
civicdrivr (09-03-2013), ill86 (06-04-2013), Mr.Jay (05-31-2013), Ornelas66 (04-21-2015), SkullWorks (06-18-2013), sw20kosh (12-24-2014), xjohnx (05-31-2013)
Old 05-30-2013, 07:21 PM   #21
DC-FRS
Drives: Whiteout FR-S
Thanks!
Rick
Don't mind at all, bro! If you guys need part numbers for any OEM parts, let me know. I'm an estimator at a body shop and have access to the database and all of these diagrams.
DC-FRS is offline   Reply With Quote
The Following User Says Thank You to DC-FRS For This Useful Post:
RallySport Direct (05-30-2013)
Old 05-30-2013, 07:38 PM   #22
RallySport Direct
Thanks! Always good to have resources like this on the forums
Thanks again,
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
Jose_Timberlake (02-03-2015)
Old 05-31-2013, 08:05 AM   #23
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks!
Rick
I don't care what they say about Utah, if this works you guys are alright with me! As soon as my replacement fasteners comes in I'm going to give it a try (don't want to risk it with the fragile replacement fasteners i'm using now.) Maybe today with any luck, probably not until Monday though.
Old 05-31-2013, 08:13 AM   #24
xjohnx
Grip>Slip
xjohnx's Avatar
Also you can get most of those part #'s from this site:
http://www.buysubarupartsnow.com/par...and-components
They have a pretty extensive catalog of both body and mechanical parts.
Old 05-31-2013, 04:45 PM   #25
Kenta
Kenta's Avatar
Drives: Raven 2013 FR-S
I had the same issue on my FRS. Took it to the service department a while ago, they had their body shop try fixing the issue, but the guys at the body shop said the entire bumper needed to be replaced. They said there might be something wrong with the way it was molded or something like that, so my front bumper's being replaced under warranty. It's currently at the shop, but I'll let you guys know how it appears once I get the car back.
Kenta is offline   Reply With Quote
Old 05-31-2013, 08:02 PM   #26
bcmakesiteasy
Drives: 2013 FRS Ultramarine
same problem with my FRS. I was in an accident only 3 weeks after i bought the car. (someone rear-ended me and pushed me into a back of a Jeep ) Mines poppin out so badly my side marker is sticking out of the cut out for it on the fender like a sore thumb. I'm going to have it checked out when i take my car in for its 15 k miles service at the dealership
bcmakesiteasy is offline   Reply With Quote
Old 05-31-2013, 09:56 PM   #27
Hardrock4445
Hardrock4445's Avatar
When you put bumper on you have to work from the center out and kind of flex it in place and you will have no issues getting it put back on. If I had to take the bumper back off I would make a video for it. Stock bumper on stock clips and has been off 4 times. No fitment issues at all.
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
The Following 3 Users Say Thank You to Hardrock4445 For This Useful Post:
Mr.Jay (05-31-2013), Wes (06-13-2013), xjohnx (05-31-2013)
Old 05-31-2013, 10:13 PM   #28
xjohnx
Grip>Slip
xjohnx's Avatar
When you are working your way from the center out, are you putting any fasteners in before you've got it all clipped in? or put the fasteners in as you work your way out?
Bumper and fender damage - Hit and Run 01s0uljah Cosmetic Modification (Interior/Exterior/Lighting) 40 12-24-2016 02:44 PM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 02:32 PM
Where to Buy Fender badges and bumper V light?? taimysho0 Scion FR-S / Toyota 86 GT86 General Forum 5 05-17-2013 05:31 AM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 05:52 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 08:34 PM
