Old 05-30-2013, 01:29 AM   #15
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Originally Posted by BlueSTaR View Post
I'm also thinking of just disconnecting the back speakers. I don't really see a need for them. Although I do have a 4 channel amp :P
I wouldn't spend too much time & effort on the rear-speakers either, but from my experience things sounded better (at least fuller) with them there.
My setup: I'm running a RF P500X4D 4-ch amp to components in front and bridged for a single sealed 10" sub in the trunk. Tweeters were mounted in the dash and 6.5" speakers (4-ohm) were obviously in the doors, running full pass-through on the HU and amp, allowing the crossovers to do all the frequency separation. The OEM 3.5" rear speakers are currently being powered by the aftermarket Pioneer AVH-X8500BHS HU.
I accidentally cut the wires to the rear speakers for about a week and drove around without them connected thinking to myself they're virtually useless anyway. But to my surprise, it just felt something was missing. After connecting them back up I was happier with the overall sound. Now I'm wondering if a $50 pair of 3.5" or 4" speakers for the rear, powered by the aftermarket Pioneer HU, is worth experimenting with. Anybody try to install aftermarket 4" speakers to the back? I hear speaker baffles ($7.50 on Amazon for a 4" pair) actually work pretty well for smaller speakers like these.
mit_peid is offline   Reply With Quote
Old 05-30-2013, 03:02 AM   #16
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
What did you guys do for the fronts? 3 channels?
BlueSTaR is offline   Reply With Quote
Old 05-30-2013, 03:59 AM   #17
Zippy
Drives: 2013 Subaru BRZ WRB AT
Originally Posted by cruzinbill View Post
Again you are comparing a car to a home enviroment. Do you even know of any headunits that will play SACD in car? I'm pretty sure there are none.
I took 30 seconds and google found these three. All 3 are Sony head units, models MEX-DV1000, MEX-DV2000, and XAV-W1.
So you would need processing to actually make use of the rear speakers still. Slim to none offer true surround sound either. Unless your source unit has it then you aren't actually doing anything other than cloning the front output. Thats all rear is, a duplicate of the front output in 90% of car stereos.
So even if you are listening to dvd audio in a car, its still not surround sound just incorrect imaging from the rear. Unless you have one of the few units that do 5.1.
I have an older alpine in my other vehicle that supports it in surround. There is no DSP and the imaging is correct with it. Just about any car dvd player supports dvd-a and sacd format. Including newer systems. Any new head unit that has toslink out will support it. Last I checked toslink is 100% correct channel presentation in car or home. The toslink out will be correctly setup to present the rear channel and the RCA outputs will also be correct for rear with no DSP required. I do plan on using a DSP in my build. I will start next week on it and be posting it when completed. Just do some research before purchasing and everything will be fine.
If someone wants to run rears fine, but there's no reason to have false beliefs of whats going on.
Again this is dependent upon the equipment you purchase. Making an assumption that everything being sold by every company is identical is just wrong.
Zippy is offline   Reply With Quote
Old 05-30-2013, 12:44 PM   #18
cruzinbill
Drives: Argento 6spd FR-S
Those are no longer in production, when SACD was the new fad a few companies did it... but they pretty much all dropped support. Sony had tons of issues with their SACD models since they rushed them out to be the first to have them.
Toslink is another ultra rare thing to find on a car Headunit now. Other than finding some older models on ebay thats about the only way its gonna happen.
Wish you luck on your build tho, hope to see somthin on it when your done.
cruzinbill is offline   Reply With Quote
Old 05-30-2013, 01:00 PM   #19
cruzinbill
I'm using 6 channels for the front, 3 per side.
Old 05-30-2013, 01:18 PM   #20
mit_peid
Boosted Noob
mit_peid's Avatar
Clarification on your question.... are you asking if the front gets "3-way" speakers like kind of what the stock OEMs are? (a tweeter in the dash, a 4" next to the tweeter, and a 6.5" in the door).
I went with "2-way" components with tweeters in the dash and 6.5" in the doors. I have my crossovers under the seat but still looking for a better location. All components that I'm aware of are '2-way" setups, but I've seen '3-way' 6x9s that don't fit this car without some mods. The 4" slots in the dash currently sit without speakers in my setup.
Old 05-30-2013, 03:16 PM   #21
SkullWorks
Drives: SSM LT MT BRZ
What do you guys think of eliminating the rear speakers and molding a Sub Box that eliminates the armrest area in the rear and utilizes some of the open area behind that panel?
I would like to be able to still fold down the rear seat and keep all my storage area, and this seems like the best place to put a couple of 6" subs.
SkullWorks is offline   Reply With Quote
Old 05-30-2013, 03:28 PM   #22
cruzinbill
Would be a bit of work, but would turn out alright if done correctly. I would use a pair of 8s tho, more cone area and there is enough space.
The Following User Says Thank You to cruzinbill For This Useful Post:
SkullWorks (05-30-2013)
Old 05-30-2013, 03:30 PM   #23
SkullWorks
I'll surely end up using what I have for now (a 10" sub) and make a box, but in the long run I'd like to be able to drive to the track without having to take apart my sound system.
For now the car requires a truck with a bed full of E-85 to go to the track anyway...lol
Old 07-22-2013, 10:21 PM   #24
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Alpine SPS 410
I installed these and insulated/soundproofed the area with Raammat on the sheet metal and Ensolite on the interior panel.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 07-23-2013, 01:25 AM   #25
mit_peid
Boosted Noob
mit_peid's Avatar
If you did the rear speaker upgrade, Raammat, and Ensolite separately and sequentially, how would you rank the impact to your overall sound from each of the three? I was considering buying some 3.5" speaker baffles for the rear speakers to see if the air separation would improve the sound coming from the stock speakers but I starting getting into more suspension mods for the car. That plus most of my sounds are coming from the front components being powered by an amp.
Old 07-23-2013, 07:58 AM   #26
tonystewart
The insulation has the greatest impact, tire noise is less.
Speaker Tweakers made a noticeable difference, Speakers sound better, fuller.
The Alpines have to be at least worth the price ($46) to replace them,
That is my ranking
The Following User Says Thank You to tonystewart For This Useful Post:
DAEMANO (11-24-2014)
Old 07-23-2013, 08:13 PM   #27
rbrender
Drives: 2012 toyota 86 gts
do those Alpine SPS 410 fit in the stock mount?
rbrender is offline   Reply With Quote
Old 07-23-2013, 09:37 PM   #28
tonystewart
Yes with modifications
Panel Removal for rear speakers? sesmls Electronics | Audio | NAV | Infotainment 8 08-01-2014 06:43 PM
Dash Top Speakers / Rear seat speakers Laurie Electronics | Audio | NAV | Infotainment 9 03-01-2013 06:31 PM
FS [vic] Speakers & Sub fuddbutter Australia Classifieds 2 10-13-2012 06:59 AM
Rear speakers, problem? Style Electronics | Audio | NAV | Infotainment 8 07-15-2012 08:59 PM
Speakers Audi Scion FR-S / Toyota 86 GT86 General Forum 1 01-21-2012 05:09 PM
