Old 05-23-2013, 09:50 PM   #15
mad_sb
Drives: 2013 Asphalt FR-S
It must be a miracle that i survived driving so many rwd sports cars growing up in the days before traction control, skid control, and even abs in a case or two...
I'm not advocating people drive like Initial D on public roads, but seriously, if you NEED traction and stability control on a 200hp rwd car to keep from hurting other drivers, property, or yourself then you really need to learn how to drive.
@Red2Liter, I do the hold "trac off" for 5 seconds most of the time. It did still act up on me a tiny bit at my last track day but not enough to worry about, it was only when clipping gators right before a hard breaking zone. At my last drift event it acted up a good with with "trac off" for 5 second. For the next drift event i am going to pull the abs fuse or do the pedal dance depending on run group timing etc.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
acro (05-23-2013), R2 (05-24-2013)
Old 05-23-2013, 10:29 PM   #16
so26
Drives: Raven FR-S 6MT
Originally Posted by Red2Liter View Post
Nope, Not Chris Harris.
Then slow down.
so26 is offline   Reply With Quote
The Following User Says Thank You to so26 For This Useful Post:
supramkivtt2jz (05-24-2013)
Old 05-23-2013, 11:11 PM   #17
Red2Liter
Drives: Subaru BRZ Limited, Red
I've already said that turning the nannies off doesn't really turn them off. it just raises the engagement threshold. I find that mode to be a perfectly acceptable, safe mode in which to drive except under VERY slick conditions. I'm neither foolhardy nor do I consider myself immortal. So why did you folks buy this car, one which has such a great performance envelope? This is clearly a fruitless conversation, perhaps a Prius is the more appropriate choice for you, or did you just buy it for the image it projects?
Red2Liter is offline   Reply With Quote
Old 05-23-2013, 11:24 PM   #18
so26
If after trying the "pedal dance" the car still does not feel right try changing the diff. oil. I noticed that after changing mine to Motul 300 that the LSD engagement improved. If none of this helps there might be something wrong with your car.
Old 05-23-2013, 11:33 PM   #19
mrk1
Drives: Sterling BRZ Ltd
@Red2Liter what cars are you used to?
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-24-2013, 12:31 PM   #20
Red2Liter
TC & VSC
Thanks! I've got about 6 K on the car. Thought I'd get a few more miles on the transmission and the Diff. The transmission is already improved for smoothness with every mile of use.
Old 05-24-2013, 12:37 PM   #21
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
Autocross: Everything off
All other times: Everything on (unless intentionally hooning)
Sport mode: Worthless, too intrusive to have fun
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 05-24-2013, 12:59 PM   #22
Red2Liter
TC & VSC
I've driven or raced everything from Mini-Coopers (the originals) to Porsches & BMW's. Recently I've been driving AWD Subaru's. Still transitioning back to front engine/rear drive. Each drive layout has its' own unique handling character. The BRZ is inherently neutral, though it can be persuaded to oversteer. I feel most comfortable with trailing throttle oversteer; nothing quite as comforting as walking the rear out gently by easing off the throttle and being able to stop the oversteer by getting into the gas. Just a personal preference that is probably the safest solution for most folks. Of course the driver needs to be aware of what the car is communicating.
Old 05-24-2013, 01:20 PM   #23
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Strange. My V8 pony doesn't have TC or even LSD. Hasn't made me spin off the road yet. All these nannies on cars these days are goofy to me. It masks the real problem: drivers with no sense of responsibility. TC or not, there's no reason to drive like an ass on the streets. Morons kill people, not turning off some settings.
OP, there is a device for 08+ WRX/STi that lets you program the TC state when turning on the car. Not sure if it's available for this car, but I believe it was called "Setting Saver". Meaning if you normally have TC off, you can just turn it on when desired instead of the other way around. Might be worth looking into, maybe they can work out automating the pedal dance for those who track regularly.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-24-2013, 02:03 PM   #24
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
Welp, the mods decided delete all posts relating to me pointing out that youre obviously breaking laws on public roads.
supramkivtt2jz is offline   Reply With Quote
Old 05-24-2013, 02:21 PM   #25
xjohnx
Grip>Slip
xjohnx's Avatar
Just a guess, but it probably had something to do with the manner in which you chose to point it out.
Old 05-24-2013, 03:39 PM   #26
Red2Liter
TC & VSC
Yes, you certainly had good reason to be sensitive the subject, but to assume that a 71 yr-old experienced driver was some kind of a idiot was a bit of a reach. I've decided to not take it personally; I know the manner in which I drive responsibly.
The Following User Says Thank You to Red2Liter For This Useful Post:
xjohnx (05-24-2013)
Old 05-24-2013, 09:10 PM   #27
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Holding the trac button for 5 seconds turns off everything except ABS I believe. Works for me, although I can understand how that'd be annoying while drifting. Meh, so what if I like a litte tire spin occasionally. I only do it in situations where EVEN IF I crashed I'd only injure myself. I hate VSC sport, it feels like it does nothing...
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 05-24-2013, 09:22 PM   #28
mad_sb
Sadly, it does not turn off everything. Not even the pedal dance does. The pedal dance is the closest you can get to zero nannies without defeating ABS.
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 02:48 PM
CEL/Traction Control Lights artizhay Issues | Warranty | Recalls / TSB 5 11-04-2012 11:33 PM
CEL Traction Control ON then OFF HATED1 Issues | Warranty | Recalls / TSB 5 09-24-2012 08:11 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 09:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 12:20 PM
