Old 05-23-2013, 11:50 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by s2d4 View Post
robi said he's on 225..
robi's car was a NASA TTD car which means he is limited on what size width and how sticky his tires can be. Many guys in TT competition run smaller width super sticky tires. Heck a Hoosier A6 225 is probably at least as wide as a Michelin PSS 245.
Old 05-23-2013, 11:50 AM   #16
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Robi also wasn't FI till recently, I'm thinking now that he has that new found torque he may go with a wider wheel to cope with new wider tires. @robispec
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 05-23-2013, 11:51 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by Adeets View Post
Yeah that thread had nothing of use, he's not FI, and those wheels are ridiculously heavy, not to mention he's running 18x9.5 all the way around on 265's.
I am going to be running a similar setup to him next week, but I am FI. How heavy are the GramNotLights?
Old 05-23-2013, 11:55 AM   #18
s2d4
s2d4's Avatar
True, there are plenty of tyres that run way wider.
A lot of the guys on 265s aren't actually wider than 245s, some are even only equivalent to 235s.
Old 05-23-2013, 11:59 AM   #19
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
I've installed and driven a Vortech setup and it is much easier on the tires than turbo. I would imagine the same should apply to the Innovate setup.
Pure Automotive is offline   Reply With Quote
Old 05-23-2013, 12:04 PM   #20
Adeets
OEDC
Adeets's Avatar
25lbs each for 18x8.5
You know I would pay an extra 2k for a car on wedsports then stock wish auto makers start making it an option
My BRZ FI Build
Old 05-23-2013, 12:11 PM   #21
Foobar
SLO NO MO
Foobar's Avatar
I've got 17x9 Weds on my rears with 245/40-17 Yoko S.Drives and a Vortech Stage 1. I'm definitely getting stickier tires next time around, not sure I need to go to 255, but something definitely with more bite than these S.Drives. It can get squirrely even at Stage 1. With E85, you'd definitely throw these suckers loose without much effort.
Old 05-23-2013, 12:11 PM   #22
s2d4
s2d4's Avatar
You may also be looking at 26-30lbs for the tyres.
I can deal with a couple after FI, not extra 10+ lbs per corner though.
Old 05-23-2013, 12:31 PM   #23
DAMotorsports
Drives: 2013 Scion FRS "Raven"
we just singed with Weds Sport and will be running there new SA15 18/9.5. We will be testing them with a 275 and hopefully a 285 set up. We will be running a squired setup so the final tire will be the one that fits the front. the SA15 are about 19 lbs.
DAMotorsports is offline   Reply With Quote
Old 05-23-2013, 12:33 PM   #24
Adeets
OEDC
Adeets's Avatar
Stock is 21.5 stock w/tire I belive is 48 lbs, I think tcn105 17x9 with good sticky was 52 lbs.
My BRZ FI Build
Old 05-23-2013, 12:36 PM   #25
s2d4
s2d4's Avatar
stock is about 40-41lbs.
Old 05-23-2013, 12:40 PM   #26
dabocx
dabocx's Avatar
Drives: Scion FRS
Im going to run the full blown kit on the stock 215s like a madman
Tires/wheels should have come first but ill manage somehow.
dabocx is offline   Reply With Quote
Old 05-23-2013, 12:56 PM   #27
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Keep the nanies on and don't floor it to often, you'll be fine (at least for public roads, the track is a whole different story).
Old 05-23-2013, 12:57 PM   #28
robispec
Drives: Black frs project
nasa ttd spec = na 205 wide tires on 8x17 wheel
Current spec will run 245 wide street grip tires 225 wide hoosier grip tires both on 17x9" wheels
Robi
robispec is offline   Reply With Quote
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
Wheel Size vs. Balance jellygorilla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-11-2012 01:23 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 12:01 AM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 03:06 PM
