Old 05-16-2013, 04:23 PM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by RallySport Direct View Post
Now you might be wondering why we need a boost gauge.... well, stay tuned
TUNED IN!
Now update me!
Old 05-16-2013, 04:23 PM   #16
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
I was thinking about getting the vent pod and the adapter too since my gauge is a 52mm
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 05-16-2013, 04:26 PM   #17
ft_sjo
Drives: GT86
I would imagine it would work on either side without a problem as the internals to the vents should be identical left to right. I would want to confirm fitment before saying that for sure though.
Toyota/Subaru list different part numbers for the left and right side vents.
The Following User Says Thank You to ft_sjo For This Useful Post:
RallySport Direct (05-16-2013)
Old 05-16-2013, 05:44 PM   #18
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Originally Posted by eikond View Post
Thanks! Rick do you want me to order direct on the website or contact you through PM? Any discounts for forum members here?
Best to order it over the site for the easiest and quickest method. Unfortunately we do not offer any additional discount
TUNED IN!
Now update me!
HAHA you will just have to wait... should not be much longer though!
Yeah I think that should be a great setup for you!
Thank you for this. I would imagine the ring that the ATI piece replaces would be the same Left to Right, but it is possible they are different. I will try to dig into this some more.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 05-16-2013, 06:17 PM   #19
xwd
I did the vent install with a Greddy Multi D/A gauge. It's 62mm so I don't think it would work with this adapter. As long as you are okay with cutting a small hole in the fuse box cover for the wires there are fuses you can use for all of the wires as well. You can use the add-a-circuit things.
Old 05-16-2013, 06:19 PM   #20
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Very clean! Not just the DIY but the car is coming along nicely.
FYI - you've got a double-post of the same pic in the wiring section where it says to remove a screw behind the panel. Meaning, same pic for pointing out two screws.
Any info on a 52mm-only pod at some point?
My only concern is that although I don't use AC often, I want as much of a blast as I can get when I do use it. The adapter fills the space, but doesn't give any more venting. Plus, I'd rather buy one part than two.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-16-2013, 06:22 PM   #21
OrbitalEllipses
Drives: Attitude
I don't know that I'd use the left vent for a gauge...I use A/C (and heat) often AND I notice that the left side is the only one I can really aim where I want. The vents above the center stack are kinda useless in aiming where I want them to go. Sacrifices must be made for boost though.
Old 05-16-2013, 07:02 PM   #22
2point0
2point0's Avatar
Good point. Really not sure which way I want to go, but the gauge pod options for this car are really slim so far. People are trying, but nothing really gets up and screams "this is the one!"
The Following User Says Thank You to 2point0 For This Useful Post:
Cessblood (06-08-2013)
Old 05-17-2013, 01:02 AM   #23
ft_sjo
Drives: GT86
It looks as if only the front silver trim ring is universal, but the housing and inside section come as a unique pair:
RallySport Direct (05-17-2013)
Old 05-17-2013, 01:34 PM   #24
RallySport Direct
I really like the Greddy Multi D/A gauge and was thinking you may be able to modify the ATI ring to accept the 62mm gauge, it may not look as clean as I would imagine you would overlap onto the vent opening around the gauge. It should work, but may not look as clean.
Got the picture fixed, good catch
They did not have any immediate plans to go with the 52mm specific gauge, but you could always use their 60mm to 52mm adapters in a pinch. Hopefully one will come out soon for the 52mm guys, and will allow for more venting around the gauge.
Yeah, I think as more and more people modify this car, we will see more options for mounting. I really like this pod and am very pleased with it all around, but it would be nice to see more options on the market, which I can't imagine we will have to wait very long.
I was really excited when I saw this pod and I knew that we were finally starting to get some good aftermarket solutions for gauge mounting. I expect to see more and more innovative solutions coming out shortly.
Wow, great information! I would have assumed they were the same, but you know what happens when you assume!
Thanks for everyone's input, I love when threads start going in this direction. Helpful, constructive, thought provoking and it gives manufacturers an idea of what the customers want. Big thumbs up to everyone!
Thanks,
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
2point0 (05-17-2013)
Old 05-21-2013, 05:33 PM   #25
RallySport Direct
Let me know if anyone needs more pictures, I took something like 130+ during the install haha
Thanks,
Rick
Old 06-08-2013, 04:56 AM   #26
nix
nix's Avatar
Drives: AVO BRZ
Very cool product. Makes me wish I wasn't running a 2 5/8" (66.7mm) gauge.
nix is offline   Reply With Quote
Old 06-11-2013, 01:33 PM   #27
RallySport Direct
Wow, that is a big gauge for sure! I don't think anyone will come out with a pod in this location specific for a 66mm pod, but you should be able to modify one to fit as this ATi pod has an outer diameter of 90mm. Hope this helps
Thanks,
Rick
Old 06-18-2013, 09:15 PM   #28
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I'm really liking the adapter, and a big thanks for the DIY. It saved me tons of time. I really like that it lets me have a gauge while keeping close to an OEM look.
[ame="http://www.youtube.com/watch?v=MhxC7zH1ztw"]Depo 4 in 1 Gauge - YouTube[/ame]
The Following User Says Thank You to neutron256 For This Useful Post:
RallySport Direct (06-19-2013)
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
FS [BNE] - Pivot DXW-R air vent gauge, Cusco catch can and Team Voodoo gear knob Nardi330 Australia Classifieds 3 04-22-2016 09:24 AM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
DCW Single Gauge Pod - 52/60mm gauges - In stock USA No Limit Motorsport Interior Parts (Incl. Lighting) 17 06-27-2013 04:20 PM
