#15 |
Drives: 2013 BRZ 6MT Satin White Pearl
ok, so i think im gonna go with the pdx v9 (seems like an amp i can use with most potential future setups), and i like that its compact....
morel components 2 8" alpine type R 4ohm subs im going to get a single box for now, but will eventually get custom boxes to put one in each corner of the trunk. anything else i should know or get ? |
#16 |
Drives: 13 BRZ Limited & 16 Hyperblue
Crutchfield.com... Just go there.
Also, I prefer to just run 1 Mono and 1 4channel. In the BRZ I would just go high end speakers, bridge the 4 channel and forget the back (not like you need it). |
#17 | |
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Sent from my SPH-L710 using Tapatalk 2 |
#18 | |
#19 |
#20 | |
Drives: Argento 6spd FR-S
I'd add some deadner to do your doors and rear deck for sure. Other than that a DSP if you wanna splurge later, but that's about it. |
#21 |
Drives: 86 GT Manual - Sonic Blue
#22 | |
I'm not saying the V9 is a bad option, because it's a great one. I just like 2 Amps vs 1 for wiring purposes. |
#23 |
I do not envy anyone trying to put an amp under a seat in this car. Also, that means you have to pull the seat out to adjust the tune, which is a little annoying.
#24 |
Drives: 2013 Subaru BRZ Limited in WRB
+1. You should definitely factor in some sound deadening material into your build. This car is a no-frills sports car and therefore is prone to road noise and rattles - they wanted to keep the car as light as possible. The small 10 will exacerbate any rattles.
#25 |
I found the v9 new for 399$ shipped on eBay, and the 8 inch speakers 99$ each shipped. Just wondering if the v9 has more than enough power if I wanted to put the 10inch alpine later on?
Also, what volume box should I look for for the 8 inch type R? (eBay) |
#26 |
#27 |
I'd just go a single 10". 2 8's is a bit much for this car.
#28 |
2 8's will have more surface area than a 10 and just a little shy of 1 12.
| GaN-MaN's Custom Audio Setup + Sub/Amp Box | GaN-MaN | Electronics | Audio | NAV | Infotainment | 23 | 03-26-2014 05:43 AM |
| Boombacloud's BRZ Audio Build...Need Help/Advice | boombacloud | Electronics | Audio | NAV | Infotainment | 1 | 12-28-2012 12:35 AM |
| In need of advice (full setup) | computertech01 | Electronics | Audio | NAV | Infotainment | 8 | 08-02-2012 06:23 PM |
| Any specs on the standard Audio setup? | viking84 | Electronics | Audio | NAV | Infotainment | 72 | 05-30-2012 03:34 AM |
| Audio setup | 315FR-S | Electronics | Audio | NAV | Infotainment | 20 | 05-17-2012 06:23 PM |
