Old 05-13-2013, 02:48 PM   #15
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
It's probably located further down the "neck" of the fuel tank. If I remember correctly it HAS to be there by law to prevent fumes from escaping the tank, they figured out in the 80's that the fumes that were being emitted while filling up and letting a gas tank "breath" were incredibly damaging to the environment so they came up with systems to trap them.
Now when you fuel up that big rubber donut creates a seal which channels the fumes in your empty tank to the tank under the gas station as your tank gets filled up, same thing happens when the gas station gets their tanks refilled and then the fumes get transported back to the refinery. Not sure what happens to them if they're re-processed into something or just disposed of in a less damaging way to the environment than venting to the air.
This I didn't know, I knew its purpose but didn't know it was a regulation.
Gregory Gawaran is offline   Reply With Quote
Old 05-13-2013, 03:36 PM   #16
strat61caster
strat61caster's Avatar
My post kind of strayed into the refueling component but the basis of the regulation is to prevent fumes from escaping the tank and polluting the atmosphere. There is probably some form of pressure relief in an emergency so the tank doesn't balloon up but for the most part tanks are sealed.
ineedyourdiddly
Old 05-13-2013, 07:43 PM   #17
root
Drives: Raven FR-S
Yeah, modern fuel systems are sealed but the gas cap has a safety release that goes at a certain pressure. I know that because my other car would vent there eventually.
I know a some of cars now don't even have a screw on gas cap anymore.
root is offline   Reply With Quote
Old 05-13-2013, 07:54 PM   #18
jdcorbitt3
jdcorbitt3's Avatar
Drives: 2013 red FR-S, OFT. 2000 Miata SE
It is no longer required, since we will get a check engine light if we leave the gas cap off. That was also designed so you couldn't put a larger diameter leaded gas nozzle just into the filler neck and gravity feed the tank. It required you to push the narrower unleaded nozzle in the neck in order for fuel to flow. I don't think there is leaded auto gas anymore, so the flapper valve is no longer necessary.
John
jdcorbitt3 is offline   Reply With Quote
Drill a hole in the taillights? dem00n Issues | Warranty | Recalls / TSB 50 01-24-2014 12:58 PM
Covering a large paint chip Panecki17 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-20-2012 02:51 PM
Torque hole discussion jeebus Engine, Exhaust, Transmission 19 08-28-2012 07:51 PM
Mysterious microscopic hole Aznek Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-09-2012 08:22 PM
Anyone else considering painting or covering the silver dash panels? Jimbo BRZ First-Gen (2012+) — General Topics 83 04-12-2012 07:32 PM
