Old 05-09-2013, 01:15 AM   #15
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
I got the stock out without lifting the engine. It was on a lift though, so I had a better angle at it.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 05-09-2013, 01:23 AM   #16
cnk
Drives: '13 DGM BRZ Limited
I got my stock OP out and installed a Perrin one without jacking the engine up. Did it with the car on stands. Just take the heat shields off and you can remove it towards the back while twisting it. Installed the new one from the back in reverse.
Sent from my Transformer using Tapatalk 2
cnk is offline   Reply With Quote
Old 05-09-2013, 01:24 AM   #17
g0lden
Drives: 2013 Scion FR-S Argento
same thing happened to me. I ran a day with only one bolt, until I got to an exhaust shop to get it fixed...
g0lden is offline   Reply With Quote
Old 05-09-2013, 01:30 AM   #18
OrbitalEllipses
Drives: Attitude
"Just take the heat shield off"
Those bolts securing the halves to each other are a PAIN in the ass to get to.
Old 05-09-2013, 01:54 AM   #19
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
I was about to say the same, also WD40 the hell out of it.. I found out if you let your car run for a bit then spray WD40 (careful propellant is flammable) it cools down the bolts and lubricates for easier removal while overpipe is decent hot.
Furtive is offline   Reply With Quote
Old 05-09-2013, 11:05 AM   #20
cnk
I guess I got lucky then because mine came right off with little effort.
Old 05-09-2013, 11:53 AM   #21
Foobar
SLO NO MO
Foobar's Avatar
Same here. I did manage to cut my arm on something sharp though. It's all good though. Every successful mechanical job involves some sweat and blood investment!
Old 05-09-2013, 01:45 PM   #22
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The studs connecting the over pipe to the header on mine stripped the second time I disconnected it. I heated up the studs, removed them (they are screwed in) and used bolts to make install/removal of the header easier.
Maybe you can do the same?
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following User Says Thank You to civicdrivr For This Useful Post:
Xinshadow (10-25-2013)
Old 05-09-2013, 02:51 PM   #23
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
One of mine broke coming off for the very first time so it was a virgin and broke. I am pretty sure there was something mentioned about it in the "Issues" section at some point as being a pretty regular occurrence. The Motiv stuff comes with new hardware so no need to go buy anything separate.
I didn't have any issues taking the heat shield off first either. Could be a matter of what tools you have available to you. The over pipe literally only took a couple minutes to do. I have a Motiv over pipe and front pipe.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 05-09-2013, 03:17 PM   #24
Sniper2606
Sniper2606's Avatar
Well the reason i did not wanna do the over pipe is because i order the SC kit and idk if i will need a different tune for that, dont want the car running lean
Sniper2606 is offline   Reply With Quote
Old 05-09-2013, 06:57 PM   #25
Foobar
SLO NO MO
Foobar's Avatar
Same tune unless you swap the header out.
Sent from my Nexus 4 using Tapatalk 2
Old 05-09-2013, 07:05 PM   #26
Sniper2606
Sniper2606's Avatar
Talking
You pinky swear?
Old 05-09-2013, 07:08 PM   #27
Foobar
SLO NO MO
Foobar's Avatar
You pinky swear?
Yeah. Cross my heart!
Old 05-09-2013, 07:18 PM   #28
Sniper2606
Sniper2606's Avatar
Well shit in that case im excited then.
Just to recap tho, i bought this
Visconti Tuning Vortech STG1
Full Vortech ProCharger Kit with EcuTek (does not include Upgraded Fuel Kit)
- Vortech ProCharger Kit (with everything seen below in pictures)
- EcuTek ProECU Kit (includes OBDII-to-USB Cable, EcuTek License & Software)
- V-Tune Forced Induction STG1 Calibration for Pumpgas
- Upgraded 3Bar Map Sensor
- Free Updates for Life
- Full Support Console Access
Right now i only have the q300 with catless pipe and overpipe running 91 gas.
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 03:03 AM
Oh-Oh's, I Think I Broke It! track_warrior Issues | Warranty | Recalls / TSB 232 06-12-2013 11:58 PM
Selling stock overpipe, midpipe, and exhaust for anyone interested markmatley Hawaii 0 02-20-2013 10:37 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 01:19 PM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 01:24 AM
