Old 05-06-2013, 12:34 PM   #15
Roach
Roach's Avatar
Drives: '98 Impreza RS -> BRZ
Just use a belt (like the kind you wear). Wrap it around the filter, through the buckle, then reverse the direction of the wrap and pull hard. Same concept as starting a push mower.
Roach is offline   Reply With Quote
Old 05-06-2013, 04:18 PM   #16
ST185RC
Drives: White Out FR-S
If the filter is cool, wrap a wide rubber band on it for better grip. Works especially well when the oil filter is sitting straight up.
ST185RC is offline   Reply With Quote
Old 05-06-2013, 05:32 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
Apoc (05-06-2013), DrDuquette (11-11-2013), Hawk77FT (05-16-2013), kmbkk (05-28-2013)
Old 05-06-2013, 05:39 PM   #18
frsvr4
Drives: '13 FRS
So... when I remove the filter, what kind of spillage should I be prepared for? It's been a couple days since I looked at it, is there a tray to catch most of the oil that spills out? I'm not exactly excited to dump oil all over the top of our ~300 mile engine, haha.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 05-06-2013, 09:29 PM   #19
Sportsguy83
Drives: Limited BRZ
Originally Posted by Perihelion View Post
Kinda feel like a newb here, but I can't seem to unscrew the oil filter. Any trick to this?
Originally Posted by Sportsguy83 View Post
Hey man, I was looking at the thread again and wanted to make it clear just in case. My silly image above is not an insult to you, it was just a funny image that fitted a bit of the situation. All of the suggestion made before me are good. Welcome to the forum and genuinely, my humor is light hearted.
Old 05-06-2013, 09:40 PM   #20
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Originally Posted by cnk View Post
Get a oil filter cap from Pep Boys or Autozone. You could also use a oil filter strap or Sears has one that rotates with 3 prongs to grip the filter. Usually the first oil filter change is the most difficult since we all know OEM's use gorillas to torque the filters down.
I am a big gorilla and I have no issues removing my oil filter. I do however have great difficulty typing on my computer. I wish some days I had slender little girly hands like some of you.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 05-06-2013, 09:42 PM   #21
Noahsark
Noahsark's Avatar
Drives: Fr-s
See my avatar. Or get some tools man!!
Noahsark is offline   Reply With Quote
The Following User Says Thank You to Noahsark For This Useful Post:
Sportsguy83 (05-16-2013)
Old 05-07-2013, 07:34 AM   #22
Roach
Roach's Avatar
There is no spillage, nice and clean.
Old 05-07-2013, 09:03 AM   #23
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Marry a strong man and ask him to do it.
SloS14 is offline   Reply With Quote
Old 05-13-2013, 12:34 PM   #24
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
get the proper tool/tools and get it off the right way. you dont want to be stuck with a swiss cheesed oil filter after the screwdriver method failed you and can no longer drive to the store. if you are going to be changing your own oil, a $5 investment is worth it to do it right every time.
Grymm86 is offline   Reply With Quote
The Following User Says Thank You to Grymm86 For This Useful Post:
kmbkk (05-28-2013)
Old 06-07-2013, 09:58 AM   #25
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Originally Posted by Hanakuso View Post
...but when worse comes to worse you can jam a screwdriver in it and twist it off. Be prepared for a mess.
Never do this. If the filter truly is stuck (it does happen), you'll be paying for a tow truck to brink your car in for service. If you can't get the filter off with a strap, there's a problem.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 06-07-2013, 12:08 PM   #26
FReSh
Dirt Trackin'
FReSh's Avatar
Drives: '13 Raven FR-S MT
FReSh is offline   Reply With Quote
The Following User Says Thank You to FReSh For This Useful Post:
supramkivtt2jz (07-18-2013)
Old 06-07-2013, 03:22 PM   #27
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Do the Subie's get free oil changes for the first 35k miles like the FR-S? If so, have the dealer change it for you?
Narcoden is offline   Reply With Quote
Old 06-07-2013, 03:51 PM   #28
Hanakuso
Why not ? I've done it in the past with no problems when I had no tools to remove the oil filter.
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
infinite012 (07-12-2013)
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 02:19 AM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Buzzer removal Micene DIY (Do-It-Yourself) Guides 33 03-14-2013 11:51 PM
Does anybody know exactly what filter the injen Sri uses? I want to get a new filter Frsexxxy Engine, Exhaust, Transmission 13 02-19-2013 11:04 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
