Old 04-30-2013, 04:36 PM   #15
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Yeah I know how it works man. Contact patch stays the same size. Just a different shape
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 04-30-2013, 04:36 PM   #16
ayau
Drives: Some rust bucket
Here's my take on car comparisons.
Both cars should be 100% stock. This includes restricting to factory tire compounds. You could always say you could do X to a car to equalize the comparison, but the point of the comparison is to compare them, not equialize them.
If both cars are 100% stock, the ITR would most likely be "faster" due to better tire compound.
The Following 2 Users Say Thank You to ayau For This Useful Post:
fatoni (04-30-2013), _hollywood (04-30-2013)
Old 04-30-2013, 04:50 PM   #17
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Sonolin View Post
EDIT: After some further research (thanks @DarkSunrise!), it seems these times were with the stickier bridgestone tires. Good to know! I thought these were with the primacy's which would've been much more impressive, but a little unbelievable when you think of it
Yep, switching tires (even just RE050A's) made a big difference in that test. There's also some indication that the 9:09 was a partially wet lap.
Yeah I can see both sides to this issue, which is why I posted up the times with and without comparable tires. The times can speak for themselves I guess.
:happy0180:
2022 BRZ Build
2013 FR-S Build
Old 04-30-2013, 05:07 PM   #18
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Stock vs stock, i think the ITR will be the "fastest" as you mentioned because of the better tires.
I own both cars and neither of them are stock right now, I havent tracked them yet but I'm planning to do it.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 04-30-2013, 05:19 PM   #19
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
I tend to agree with this notion except when it comes to tires since they play IMO the one of the largest roles in how fast you are and I count them as a wear item that will end up getting changed anyways.
Seems fair to me that everything on both cars are stock except tires are the same to compare the faster car but everything stock if you want to compare the better car to right out the box
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 04-30-2013, 05:23 PM   #20
fatoni
if you are going to keep at this hypothetical racing, you might as well pick a real track. the ring is used to develop cars. its not really a good metric considering how much room for human error there is over 13 miles.
also, im not sure a sixth gear is going to matter. having driven both, the itr was more impressive but the drives were years apart so it doesnt really mean anything. when we weighed the itr, it was a lot lighter than what it was listed at
Old 04-30-2013, 05:28 PM   #21
fatoni
we have been here before but i dont think being a wear item is reason enough. brakes are wear items and so is the clutch (entire cars are wear items too i suppose).
equalizing tires is informative but not fair.
Old 04-30-2013, 06:17 PM   #22
DarkSunrise
Yeah the Ring isn't the best for comparing laptimes, but it's the only set of times we have for these cars, unless someone owns both in stock form and is willing to do some testing (doubtful).
At the very least, the times on the Ring back up what we can guess from looking at the specs, namely that they're similar weight/hp cars built for similar purposes. On vaguely comparable tires, you'd expect them to put down similar laptimes, which the Ring confirms.
2022 BRZ Build
2013 FR-S Build
Old 04-30-2013, 06:22 PM   #23
Sonolin
Take a look at http://fastestlaps.com/comparisons/h...ota_ft-86.html
There's a lap time for Hockenheim Short & Vairano Handling Course on there for both cars.
From my previous experience, the lap data on that site is fairly accurate. Sometimes there's random times that get posted that are wrong, but they are debunked very quickly. They only use times from big names (race drivers and usually only big sources like Car and Drive, Road and Track, Motrotrend, etc.). Times are always stock (I believe the 86 is equipped with the bridgestones in those tests though).
EDIT: And yea not a lot of times to see, but at least those 2 courses + nordschliefe is a pretty good indication of how fast the 86 (stock) is IMO.
Sonolin is offline   Reply With Quote
Old 04-30-2013, 07:40 PM   #24
DarkSunrise
Yep, you're right. Looks like there are more data points there.
2022 BRZ Build
2013 FR-S Build
Old 04-30-2013, 07:44 PM   #25
_hollywood
Drives: 97 itr sold
The reason i bought an frs is because its the closest thing to a modern itr that is available, from the faux cf trim ( i know its t symbols but cmon) to the red stitched seats, and the minimalist approach, which over time is slowly being appreciated by the masses....
Simple is better imo
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 04-30-2013, 08:08 PM   #26
Sonolin
There's others (and more accurate 1/4 numbers, etc.) under the subaru brz entry as well. I check the site quite often, I used to be a number whore before this car, lol...
Old 05-02-2013, 02:22 PM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
My understanding is that RE010's were a pretty sticky track/autocross tire in their time. Tire Rack views Dunlop Z1 SS as the closest comparable modern-day tire, which is saying a lot.
http://www.edmunds.com/car-reviews/f...-civic-si.html
Also worth noting the RE050A's which the GT86 was tested on are pretty mild summer tires.
Eh, I had RE010's on my ITR. Those tires were good in 1997 no doubt, but.. compared to a star spec? No IMO. I've driven both on my ITR back to back. The RE010's don't hold a candle to the modern performance tires IMO.
Oh, and I turn faster times on Sebring with the Integras. :shrug: None of my cars are completely stock though.. so.. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-02-2013, 02:24 PM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
And lower weight. And "better" gearing.
Which is faster depends greatly on the track too.
I should run the ITR at Sebring again to get some recent times to compare, and data log it to compare data. IMO the BRZ will have higher entry, corner and exit speeds with lower straight speeds.. slow junker that it is
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
..... vs. DC2 Integra Type R quik1987 FR-S / BRZ vs.... 226 12-27-2021 09:15 AM
1994 Integra RS 5MT lowered. pyro530 Cars for Sale/Trade 2 01-26-2013 10:19 PM
Oil type? orthojoe Tracking / Autocross / HPDE / Drifting 1 01-14-2013 04:11 AM
FR-S vs. Acura Integra Type R bazi FR-S / BRZ vs.... 1 01-09-2013 05:16 PM
FRS/86/BRZ vs RSX Type S Maj3sty FR-S / BRZ vs.... 11 12-27-2012 05:17 PM
