#15 |
Drives: Attitude
Oil pan is the engine jack point. Big black thing with the drain nut on the driver's side. Place a block of wood between the oil pan and the jack saddle. Don't forget to undo the engine mounts....
| The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post: |
#16 |
Drives: Asphalt frs
Hey man I'm installing turbo kit right now and this over pipe on the factory headers is a pain in the ass. The nut on it is stripped on one side other one came out fine. Do I need to remove the over pipe from headers to get off or is their and way to wiggle it out?
#17 | |
Senior Misanthrope
#18 |
Drives: Asphalt frs
#19 | |
Senior Misanthrope
Edit: this is definitely the lazy solution. There might be a better one. I'm not liable for damage to your car, etc., etc. |
#20 |
Drives: Asphalt frs
#21 | |
Senior Misanthrope
Edit: you only really need to unbolt one motor mount, but you can do both if you're having trouble fitting the OP. |
| The Following User Says Thank You to kch For This Useful Post: | SoCal80six (09-23-2015) |
#22 |
Drives: Asphalt frs
Alright thank you so much ahah. I shouldn't have to worry about breaking other motor mounts jacking it up right?
#23 |
Senior Misanthrope
I can't say for 100% sure, but I have seen several successful header/OP installations where we jacked up the engine a couple inches after unbolting only the passenger side mount.
#24 |
Drives: Asphalt frs
| Nameless Performance Overpipe/Downpipe Combo | Jason@Nameless | Engine, Exhaust, Transmission | 277 | 04-04-2018 01:37 AM |
| Will nameless downpipe w/highflow cat fit with... | Pandle | Engine, Exhaust, Transmission | 2 | 02-17-2013 08:13 PM |
| Nameless axleback and downpipe FS | 117 | Engine, Exhaust, Bolt-Ons | 8 | 02-01-2013 11:06 AM |
| Differences between an overpipe/midpipe/downpipe? | Tonym427 | Engine, Exhaust, Transmission | 1 | 08-10-2012 01:05 AM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
