Old 04-29-2013, 02:40 PM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by Carlitoz3 View Post
Can anyone post a picture of where exactly the jack is when lifting the engine?
I had no idea about this.
Oil pan is the engine jack point. Big black thing with the drain nut on the driver's side. Place a block of wood between the oil pan and the jack saddle. Don't forget to undo the engine mounts....
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
Books (04-30-2013), Carlitoz3 (04-29-2013), Sportsguy83 (04-29-2013)
Old 09-23-2015, 01:12 PM   #16
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Originally Posted by Argento_FR-S View Post
With my SRT header-back the hardest part was just getting the stock overpipe out. Takes a good bit of twisting and maneuvering, but isn't too bad. I managed to do the whole exhaust on jackstands.
Hey man I'm installing turbo kit right now and this over pipe on the factory headers is a pain in the ass. The nut on it is stripped on one side other one came out fine. Do I need to remove the over pipe from headers to get off or is their and way to wiggle it out?
SoCal80six is offline   Reply With Quote
Old 09-23-2015, 01:39 PM   #17
kch
Senior Misanthrope
kch's Avatar
If you don't care about ever using the stock header again, you can always just snap off the bolt. It's easy enough to do that plenty of people do it on accident.
Old 09-23-2015, 01:41 PM   #18
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Yeah I don't need to so I can just snap the one bolt that's holding over pipe to header?
Old 09-23-2015, 01:43 PM   #19
kch
Senior Misanthrope
kch's Avatar
Might as well give it a try. Just try not to hit anything too hard when it pops.
Edit: this is definitely the lazy solution. There might be a better one. I'm not liable for damage to your car, etc., etc.
Old 09-23-2015, 01:45 PM   #20
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Alright thank you!! I'll give it a try. Also do you think I'll have to lift engine to install new over pipe? If so do you know how?
Old 09-23-2015, 01:46 PM   #21
kch
Senior Misanthrope
kch's Avatar
Lifting the engine a few inches helps a lot. Unbolt the passenger-side motor mount (14 mm i think? i forgot). put some wood or something on top of your jack, and then *carefully* jack up the engine from the oil pan. it doesn't take much.
Edit: you only really need to unbolt one motor mount, but you can do both if you're having trouble fitting the OP.
The Following User Says Thank You to kch For This Useful Post:
SoCal80six (09-23-2015)
Old 09-23-2015, 01:48 PM   #22
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Alright thank you so much ahah. I shouldn't have to worry about breaking other motor mounts jacking it up right?
Old 09-23-2015, 01:49 PM   #23
kch
Senior Misanthrope
kch's Avatar
I can't say for 100% sure, but I have seen several successful header/OP installations where we jacked up the engine a couple inches after unbolting only the passenger side mount.
Old 09-23-2015, 01:58 PM   #24
SoCal80six
SoCal80six's Avatar
Drives: Asphalt frs
Alright I'll give it a shot thank you.
Nameless Performance Overpipe/Downpipe Combo Jason@Nameless Engine, Exhaust, Transmission 277 04-04-2018 12:37 AM
Will nameless downpipe w/highflow cat fit with... Pandle Engine, Exhaust, Transmission 2 02-17-2013 07:13 PM
Nameless axleback and downpipe FS 117 Engine, Exhaust, Bolt-Ons 8 02-01-2013 10:06 AM
Differences between an overpipe/midpipe/downpipe? Tonym427 Engine, Exhaust, Transmission 1 08-10-2012 12:05 AM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
