Old 04-27-2013, 05:34 PM   #15
ben15r
ben15r's Avatar
Drives: FBM stage 1 rebadged FRS
I wont argue with you over the travel because my brother doesn't remember if he measured the same points or not (he can be a major pain) but he was under it, either way my wear was in the middle of the slip joint and the cage has marks on it that that look like it bound against the slip joint if that makes sense I am trying to understand all of this.
it looks like it is under a hard angle that is what seems to be the cause but again I don't really know.
ben15r is offline   Reply With Quote
Old 04-27-2013, 05:56 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
It's good to see more cf driveshafts being offered, should help price wise if there's competition/different options for people to pick up
Old 04-27-2013, 07:22 PM   #17
robispec
Drives: Black frs project
no argument intended just reporting my findings...
My car has 10K miles at a 3" drop from stock my axles at this ride height are already running uphill to the wheel assembly.
7 of the 10K are trackday/roadracing miles
My front and rear tires rub on the upper fender liner in the rear at full compression as we have extended the stock travel 3" in front and 3.25 in the rear (limits of the upwards travel is the upper fender liner inner fender steel)
robispec is offline   Reply With Quote
Old 04-27-2013, 08:36 PM   #18
ben15r
ben15r's Avatar
I am not lowered nearly as far as you, but I do not know what the up travel is but when it squatted in second it was done,
Ill throw a stock shaft in it save for upgrades and run the coil overs on hard when I drag race
Old 05-03-2013, 02:55 AM   #19
Knickstape
Knickstape's Avatar
Drives: '13 FR-S (Asphalt)
I see you offer an aluminum version on ft86speedfactory, but not on your main site. I have an auto and was wondering If the MT and AT shafts the same? It doesn't state on there
Opti-Guard, 35% Tint, Perrin 2" Antenna, Helix Side Markers, Valenti Tails, Carsmo Armrest, LED DRL Strip // UniChip, Perrin CAI & Inlet Tube, Perrin Cat-Back Exhaust, Grimmspeed Super-Loop Header.
Knickstape is offline   Reply With Quote
Old 05-06-2013, 05:06 PM   #20
Driveshaft Shop
Drives: 31 Ford, Viper GTS,65 Riviera,Cayen
As of right now we do not offer a aluminum version for this car. We also are in the middle of building a driveshaft for the auto transmissions.
Driveshaft Shop is offline   Reply With Quote
Old 05-06-2013, 10:02 PM   #21
Ozzman
Drives: old
I've heard of the benefits of one piece drive shafts. What I would like to know is why do so many car manufacturers run 2 piece drive shafts on automobiles?
Ozzman is offline   Reply With Quote
Old 05-07-2013, 12:05 AM   #22
Xdragonxb0i
Drives: ex500r
Just broke one tonight will be ordered on Monday
What did you break and how?
Xdragonxb0i is offline   Reply With Quote
Old 05-07-2013, 03:21 AM   #23
cf6mech
Drives: FRS Silver LS1 swapped.
NVH ....... Noise vibration harshness. If your more concerned about performance,...your less concerned about NVH.
cf6mech is offline   Reply With Quote
Old 05-07-2013, 07:27 AM   #24
Driveshaft Shop
ok, Auto shafts will be made shortly. we have the sample and its a go........
Old 05-07-2013, 08:00 AM   #25
ben15r
ben15r's Avatar
http://www.ft86club.com/forums/showthread.php?t=34943
Destroyed the bearing cage. I was drag racing felt like a good launch no wheel hop, and when I hit second it just let go.
Old 05-07-2013, 08:54 AM   #26
8686
8686's Avatar
Drives: 86
Do you mean AT transmission drive shaft? oh finally.
8686 is offline   Reply With Quote
Old 05-07-2013, 09:23 AM   #27
Driveshaft Shop
the axles we make for this are at least 50% stronger in all area's
The Following User Says Thank You to Driveshaft Shop For This Useful Post:
ben15r (05-07-2013)
Old 05-07-2013, 12:36 PM   #28
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Are there any CF MT shafts on the shelf at this time or is there still a few weeks lead time?
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Replacing Axle's in my Elantra suprachica79 Other Vehicles & General Automotive Discussions 3 10-16-2011 10:25 PM
