Old 04-23-2013, 05:53 PM   #15
DylanFRS
Lost in Kansas
DylanFRS's Avatar
Drives: 2013 Scion FRS (Raven)
Definitely like the new proposal.
Now we just gotta hope they get the MSR MX-5s and ZOK Soltices (Solstii?) out of CS.
DylanFRS is offline   Reply With Quote
Old 04-23-2013, 06:51 PM   #16
xwd
Originally Posted by whataboutbob View Post
Does 13.10 E allow for the Crawford AOS?
"The installation of oil catch tanks is allowed provided the function of the PCV system is not altered"
If not, I need to sell mine...
That's the same as the old rule. I ended up selling mine and just using a Radium can on the actual PCV line, because of the rule. I was surprised the amount of oil it's caught after a couple autocrosses.
The Crawford can through its mounting also happens to tie together the two diagonal braces, which also isn't legal.
The Following 2 Users Say Thank You to xwd For This Useful Post:
Scooby South (04-23-2013), whataboutbob (04-24-2013)
Old 04-23-2013, 06:53 PM   #17
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by MTCRX View Post
I am liking this proposal better as it advances through reviews. I think they are doing a good job. I do have a question though; how are remote reservoir dampers legal? As I understand the rules, the shocks must be like OEM but now you can have adjustable shocks. OEM shocks do not have remote reservoirs and if it doesn't say you can, you can't. Where am I missing the wording that allows them? And, are they really that much better?
Hence why it needs to be fixed.. My personal opinion is that someone along the way made an argument that hey.. I could replace my stock shocks with remote reservoir shocks.. along with R comp rubber.. I personally think Stock should be just that Stock. with OE replacement parts.. only.. my 2 peso's..
Bill
Scooby South is offline   Reply With Quote
Old 04-23-2013, 07:01 PM   #18
xwd
It doesn't say anything about them being like OEM and never has. They have allowed any type of shock in stock class as long as it meets certain criteria, such as stock attachment points and the overall length has to be within 1" of stock. It also can only have two adjustments. The nitrogen pressure is not considered an adjustment.
Typically the remotes allow for extra oil which means less heat, also sometimes the shock components work better because you aren't having to package so much in the shock body. It can also allow compression to be adjusted easier since they are typically easy to get to versus having to monkey with something on the bottom of the shock.
Old 04-23-2013, 07:07 PM   #19
xwd
Bill
The original reason why they allowed non-OEM shocks was for safety reasons, specifically when used with R compound tires. OEM shocks were terrible and a rollover was certainly possible. They took out the "no remote" rule change because they realized shocks aren't easy to police and some have made a significant investment in shocks already. Someone will rebuild/revalve/change internals on any shock and spend whatever they need to get an advantage. It's one of those things which is impossible to police. Koni Motorsports (real motorsports) shocks like the 2812 are still $$$ but do not use remote reservoirs.
Old 04-23-2013, 07:41 PM   #20
Scooby South
Conedancer
^^ Agreed. ... had a shot at 2812's .. but didn't work out..
Someone that can't afford the OMG stuff.. shouldn't be precluded from running for a title just because they can't afford the top shelf livery.. .. Again my opinion.. Autocross is meant to be affordable for the Average Joe... for the most part.. But I also understand the other side..
Bill
Old 04-23-2013, 09:11 PM   #21
xwd
Like Sam has said plenty of times many championships have been won on off the shelf or simply revalved Konis and even stock shocks. In the end it is a tenths type of gain, not seconds.
Old 04-23-2013, 09:48 PM   #22
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by NYC BRZ View Post
Lightweight 17x7 5x100 are limited in choices. Thanks for clarifying.
It seems like 16x7 5x100 would be an option.
dsgerbc is offline   Reply With Quote
Old 04-24-2013, 12:16 AM   #23
xwd
Finding a lightweight 16x7 in the right offset isn't easy. Rota used to make the slipstream in +48, about 14 lbs, but they stopped making them a long time ago. You can find the motegi traklite in 16x7 +50 but they aren't cheap. 17x7 has more tire options, 16x7 the 225/50 is the only real tire offered.
Old 04-25-2013, 10:49 PM   #24
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
I guess that will eventually be legal lol
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 04-26-2013, 12:51 PM   #25
mottor
mottor's Avatar
I'm new to this auto x stuff.. Can someone clarify the T/C rules, particularly as it relates to our car? It seems like they deleted the rule that allows us to disable it when they removed 13.10.O, is that correct?
2013 Asphalt FR-S 6MT - Perrin 2.5" Catback Exhaust - Grimmspeed Strut Tower Bar - Grimmspeed Master Cylinder Brace
Grimmspeed Hood Struts - Grimmspeed 86 Oil Cap - Grimmspeed Boxer Battery Tie Down - HID - Pioneer AVH-X5500BHS - Infinity Basslink 10" Sub
mottor is offline   Reply With Quote
Old 04-26-2013, 12:56 PM   #26
xwd
If you can disable it via an existing method the car supports via buttons, switches, etc. then you are free to do so. The original allowance they added in was to allow people to change the T/C computer and vehicle ECU for all vehicles, they narrowed it down now to ONLY vehicles which do not have another method to defeat it. The only "autocross" car right now which comes to mind is the VW GTI.
So no change for us, you can defeat it by holding the button down or doing the "pedal dance" trick.
Let's discuss SCCA Stock Class ayau Tracking / Autocross / HPDE / Drifting 314 04-18-2013 02:03 PM
April SCCA Fastrack xwd Tracking / Autocross / HPDE / Drifting 86 04-05-2013 08:48 AM
2012 BRZ/FR-S Stock Class Autocross Discussion EMguy Tracking / Autocross / HPDE / Drifting 183 01-04-2013 03:17 AM
November Fastrack xwd Tracking / Autocross / HPDE / Drifting 2 10-23-2012 06:26 PM
And the Winner is:...........BRZ to STX ..Oct fastrack Scooby South Tracking / Autocross / HPDE / Drifting 79 09-28-2012 03:40 AM
