Old 01-24-2012, 02:49 PM   #15
Longhorn248
Hook 'em
Longhorn248's Avatar
Originally Posted by 7thgear View Post
i'd put in a different engine all together...
you have to define what you want to do,
do you want to make a point and build up X engine to make Y power
or do you just need Y power and don't want to worry about anything else?
drop in a straight 6 from a supra or something and call it a day.
Personally I have no aspirations of adding anything more than the regular bolt ons and that probably won't be for a while after I buy the car. I was just curious if sleeving would be a viable solution to push more boost into this particular block without worrying about warping the cylinders.
Longhorn248 is offline   Reply With Quote
Old 01-24-2012, 02:52 PM   #16
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Google'd a bit
Open allows higher boost
Closed
Helps a bit too
Snoopyalien24 is offline   Reply With Quote
Old 01-24-2012, 02:58 PM   #17
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
sure,
sleeving, drilling holes + tapping in reinforcement plugs, blueprinting, better gaskets, stronger studs, etc etc.
many ways to do it
Old 01-24-2012, 04:00 PM   #18
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
Originally Posted by Snoopyalien24 View Post
Google'd a bit
Closed
Helps a bit too
open deck doesnt allow for higher boost. the problem with open deck is that under pressure the cylinder can expand and cause catastrophic failure.
and to the person that asked you are correct in that you can't compare a inline 4 to a boxer i just ment i have faith in subaru and toyotas design.
Syldrin is offline   Reply With Quote
Old 01-24-2012, 04:38 PM   #19
arghx7
Drives: car
It depends on what you mean by "allows for higher boost." Part of increasing the knock limit (allowing for more advanced ignition timing and higher loads) is improving cooling. Open decks allow for greater cooling besides having less weight. That being said, you can generalize an open deck as having a lower structural limit than a closed deck. It depends on the design targets though. It's just like aluminum blocks aren't automatically weaker than cast iron blocks.
Closed deck would make little sense on a 200 horsepower engine designed to be light weight while having a relatively high horsepower per liter for a naturally aspirated motor.
arghx7 is offline   Reply With Quote
Old 01-24-2012, 05:05 PM   #20
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
actually closed decking doesn't make the cylinder wall stronger and contrary to popular belief the 'closed section' only extends down about .5" of the bore. So it supports the top from shift and deformation at the top...which will marginally add strength but does not help the EJ25 from failing...even with the deck conversion they still crack at #4.
I do prefer closed/semi-closed over open because it is a stronger foundation, however I'm not sweating the open deck.
Homemade WRX is offline   Reply With Quote
Old 01-24-2012, 06:12 PM   #21
arghx7
Drives: car
I have not seen actual stress-strain testing or finite element analysis/modeling to support or not support that... hard to say...
Old 01-24-2012, 06:18 PM   #22
Syldrin
Troll Feeder
Syldrin's Avatar
good point argh i didn't think of it that way i was just thinking of pressure exerted on the cylinder wall.
Old 01-24-2012, 06:24 PM   #23
Syldrin
Troll Feeder
Syldrin's Avatar
good info as you can tell i didn't know that. i've never opened a motor i just have a short block 2az sitting in my garage (case and crank) and i havent looked at it much. just know it's an open deck. thanks for sharing that knowlege.
and like i said i am not sweating it's an open deck my car's motor has handled some serious abuse and it's just fine.
Old 01-24-2012, 09:34 PM   #24
Homemade WRX
yeah, when I install the big bore Darton sleeves on the EJ257 cases, the .5" or so of 'closing' actually gets cut through.
Those with experience in this realm of subaru's will also know that the cracked cylinder walls happen partially down the wall, not only at the top.
Old 01-25-2012, 11:00 AM   #25
Levi
Drives: Toyota
Looks like we shall not be able to increase bore especially if we want 8.500 RPM redline.
Levi is offline   Reply With Quote
Old 01-25-2012, 11:09 AM   #26
Syldrin
Troll Feeder
Syldrin's Avatar
darton sleeves my man. they make it a semi closed deck and you can increase the bore that way.
Old 01-25-2012, 05:41 PM   #27
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Open deck isn't really that much of a problem. Seems like a few guys are using the "Honda" days as a reference. You have to remember a few things that make an inline 4 much different than Subaru block. Inline 4's have 1 long set of cylinders that are only supported at the bottom and where they touch each other. They are also pretty deep, meaning the top of the block to the bottom of the coolant jacket is very deep. Based on this picture they are about 3.25" deep. This is a picture of common B18 bored out for sleeves. Not to mention the sleeve is only held in the bottom by about .5".
The Subaru engines only have two cylinders to support which are also pretty short. For instance check out this picture showing the coolant passage on the EJ motor. You can also see where the bottom of the Cast-In sleeve ends. 2.68" of no support. Sleeves are 4.85" overall meaning there is 2.15" of support of the sleeve in the bottom of the block. So they are pretty stout relative to the Honda engine.
Even if Subaru did make them semi closed deck, that doesn't keep things like this happening....
In the end, all we can do is guess how this engine will perform. I wouldn't worry too much at the moment as 90% of the customers out there are not going to turbo this for the first 1 year. After that I suspect that the new Subaru Turbo motors will be out and either you will buy the turbo BRZ, or do a swap.
I suspect that its plenty strong enough to handle 15psi of boost even with the stock CR. This should be enough to add 100 extra Wheel HP, which i think would be perfect on this car. 280-300WHP on this car is like 350-380 Wheel HP on the STI, which should make most people smile! I know I will be smiling tomorrow after we get to finally put our hands on one of these!
PERRIN_Jeff is offline   Reply With Quote
Old 01-25-2012, 05:58 PM   #28
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
tell us how it goes and update us on its limits plus 15psi on stock CR would give crazy hp numbers....
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
Open Air FR-S Concept Rampant FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 22 02-01-2012 11:01 PM
Keep your eyes/cameras open in SoCal? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 14 10-10-2011 10:21 PM
Ken Block Gymkhana 3 Midship Runabout Other Vehicles & General Automotive Discussions 24 09-14-2010 11:55 PM
