Old 04-18-2013, 01:58 AM   #15
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
I can twist in my knob (insert joke) until the top part starts to poke out. Don't do it real tight or you might risk popping the top off. Don't leave it loose or you might lose grip when shifting. Try throwing in another half spin to align the knob.
I am very insecure. I have no friends. I want people to love me
Old 04-18-2013, 02:26 AM   #16
BrianJC
Drives: 2013 Hot Lava FRS M/T
Originally Posted by pr086 View Post
when i do that till it's tight the numbers don't line up anymore
Mine came loose after the end of the day at the track. At first I tighten it and shift numbers don't line up. But then I realize I was being too gentle as my shift knob came loose from just a couple of shifts. So I then really tighten it, I managed to get an extra 2 turns on it more than before. It ended up super tight and the shift numbers lined up perfectly.
BrianJC is offline   Reply With Quote
Old 04-18-2013, 03:10 AM   #17
GNS
Drives: .
What purpose does the lite silver ring under the knob serve? Id that what locks it in place?
If this ring is what I think it is, it's basically to help you line the knob up properly. It causes the knob to stop turning when you tighten it...think of it like a nut that stops the knob from being screwed onto the shifter any further.
Turn the knob upside down and look inside the threaded portion. If you see a ring or something like that deep inside, that's what you need to adjust. Use a long flathead screwdriver or something to move that ring clockwise/counter-clockwise a little bit, then try screwing the knob back on. If the knob starts to tighten and the pattern is slightly lopsided (leaning to the left), that's when you make the final tightening turn and the pattern will line up properly as the knob seats against that ring.
If the knob doesn't tighten until after the pattern is even or leaning to the right, remove the knob and adjust that ring. Repeat until satisfied.
GNS is offline   Reply With Quote
Old 04-18-2013, 09:57 AM   #18
pr086
Drives: fast
Originally Posted by SkitterSkotter View Post
This. Probably your best solution. My shift knob moved a bit last summer when the temperatures were quite hot. locktite should set it in place for a while.
Im thinking the heat had something to do with it, it was very hot here yesterday
pr086 is offline   Reply With Quote
Old 04-18-2013, 09:59 AM   #19
pr086
Drives: fast
My last car had a locking nut under the knob. You would tighten the nut up against the nob when it was lined up right. It doesn't appear this one works the same way? So i should just screw the knob down as much as possible?
Old 04-18-2013, 11:10 AM   #20
frslee
Just drive it
Drives: 13' FR-S
Time to get a new shift knob without any numbers!
frslee is offline   Reply With Quote
Old 04-18-2013, 11:23 AM   #21
pr086
Drives: fast
I actually like the stock knob
Old 04-18-2013, 11:58 AM   #22
13 FR-S Veteran
13 FR-S Veteran's Avatar
Drives: 2013 FR-S (Raven Black)
Originally Posted by ihaskrayon View Post
If you don't plan on swapping your knob, you could put a little locktite on the threads and alight it straight. That way it wont come loose again and it'll be straight.
as above...but i'd add the caveat that you use "BLUE" Loctite if you do plan on swapping knobs. Even if you don't "plan" on it.....you may change your mind down the road.
13 FR-S Veteran is offline   Reply With Quote
Old 04-18-2013, 12:01 PM   #23
DarkSunrise
DarkSunrise's Avatar
This happened with mine. I was able to turn it a full rotation without the top popping off. Now it's on there nice and tight, and aligned perfectly. If you're not able to do that, loctite is a good solution.
2022 BRZ Build
2013 FR-S Build
Old 04-18-2013, 12:02 PM   #24
whaap
whaap's Avatar
Locktite makes several grades of thread tighteners. Be careful which one you use. For example, if you used their red Locktite you would never be able to remove your knob without using a torch and then it would be one destroyed knob. Buy, borrow or use their blue Locktite. Use just a small amount, perhaps just a drop or two, position the knob the way you want it and give it a little time to set up. It should do a good job holding the knob in position. Work on developing the habit of pushing the knob with the heel of you hand and pulling it with your fingers instead of grabbing the knob in a death grip.
whaap is offline   Reply With Quote
Old 04-18-2013, 12:32 PM   #25
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Righty tighty, lefty loosey
"BLUE" loctite on threads and not alot needed as mentioned it will cure in approx 8 hours. But still if really forced can be unbonded by a good hard twist no worries.
Old 04-18-2013, 12:35 PM   #26
OrbitalEllipses
Drives: Attitude
That's a great way to pop off the shift pattern piece.
When my BRZ was delivered, the shifter was lined up properly yet kind of loose. I cranked it 360 degrees so that the shift pattern still lined up properly and the knob too tight to move. Only thing is that I slightly dislodged the shift pattern.
clzzical (04-26-2013)
Old 04-18-2013, 02:28 PM   #27
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Get a lock washer if you want it to line up. You'll have some play in the final turn or so. That's how I straightened my aftermarket knob.
raul is offline   Reply With Quote
Old 04-18-2013, 02:48 PM   #28
FR-anco89
FR-anco89's Avatar
Drives: Asphalt FR-S MT
I put some plumbers tape till it was tight enough haven't had a problem since.
FR-anco89 is offline   Reply With Quote
Stock shift knob weight pkny Cosmetic Modification (Interior/Exterior/Lighting) 5 07-30-2015 10:11 PM
MT Stock Shift Knob, Stock Intake w/Snorkel Vicious LED Interior Parts (Incl. Lighting) 1 02-09-2013 04:14 PM
Stock Shift Knob jadewbj Interior Parts (Incl. Lighting) 1 10-26-2012 11:53 AM
MXP Titanium shift knob - in stock No Limit Motorsport Interior Parts (Incl. Lighting) 1 08-06-2012 04:37 PM
