Old 04-14-2013, 04:29 PM   #15
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Assuming E85?
This could be the perfect entry level turbo kit.
Deadspool is offline
Old 04-14-2013, 04:32 PM   #16
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by Deadspool View Post
Assuming E85?
I would hope they would have specified e85 if that was the fuel used, with e85 i would expect 10+ psi also.
JoeBoxer is offline
Old 04-14-2013, 04:32 PM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Assuming E85?
E85 is not needed at 5 psi. E85 does not make more HP. The advantage E85 provides is the ability to prevent detonation at higher PSI, thus allowing 20+ psi to be run on stock motor.
Sportsguy83 is offline
The Following User Says Thank You to Sportsguy83 For This Useful Post:
JoeBoxer (04-14-2013)
Old 04-14-2013, 04:33 PM   #18
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by lbroskee View Post
Looks amazing. Any idea how to squeeze some extra Torque? I think the AVO kit is around 280 hp and ~245 tq, but ur cheaper, master tuner, local, and can install for a decent peice from what lexusb3 told me, plus i already keep shoppin from you anyway
run a smaller turbo like the 57 or the 50 trim for more tq. larger turbos will have a wide variance between hp & tq. this is a great combo in my mind cause i can make good top end power and not torch my stock clutch with too much tq and tire spin. what you have to remember is tq is what creates engine limits no HP
FA20Club.com is offline
The Following User Says Thank You to FA20Club.com For This Useful Post:
350zgoingFRS_lol (05-04-2014)
Old 04-14-2013, 04:34 PM   #19
FA20Club.com
Assuming E85?
this was pump gas. no point in running e85 for this power/boost level
Old 04-14-2013, 04:37 PM   #20
Deadspool
Much title. Wow.
Deadspool's Avatar
I understand this, But as im working in a country that serves 91 on its best day, 5.3 psi does not answer the volume the engine is receiving.
5lbs on my T28 is not quite the same as 5lbs on my GT35.
I've never worked with an engine at 12.5 compression before, its all touch and go for me. Especially considering the urine we have for fuel on tap.
Old 04-14-2013, 04:37 PM   #21
FA20Club.com
you notice a decrease in spool time on e85 when tuned properly and an increase in tq because of it. which usually translates to an increase in power. the fuel isnt the difference its what it allows you to do on any level because of the increased margin of error before detonation.
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
lexusb3 (04-14-2013), Sportsguy83 (04-14-2013)
Old 04-14-2013, 04:38 PM   #22
86pro
Drives: frs
Oh im excited and cant wait. FA20club best investment into my car so far and the best to get to your car . I've never been lead wrong with them. Great work Tony.
86pro is offline
The Following User Says Thank You to 86pro For This Useful Post:
Xdragonxb0i (05-09-2013)
Old 04-14-2013, 04:46 PM   #23
FA20Club.com
appreciate it Jonathan
Old 04-14-2013, 04:52 PM   #24
Sportsguy83
Drives: Limited BRZ
Thanks for the further explanation. I still think at 5 psi there would not be much difference, the benefits would clearly show at higher psi correct?
Old 04-14-2013, 04:55 PM   #25
FA20Club.com
if your fuel quality is that poor one of the smaller trim turbos will work best along with ethanol if its readily available but i still dont think its absolutely necessary to run ethanol right off the get go with a proper tune.
Old 04-14-2013, 04:57 PM   #26
Frs300
Frs300's Avatar
Drives: Pile of junk
meth injection
Frs300 is offline
Old 04-14-2013, 04:57 PM   #27
lexusb3
Drives: FRS
AGREED!!!
lexusb3 is offline
Old 04-14-2013, 05:01 PM   #28
FA20Club.com
honestly i think its depends on the power its making at that level. i would normally not think to try it but with what this thing made at that level i might take a shot at it LOL. but you are correct that at higher levels the gains would be much more visible
turbo kit, turbocharged fa20
Fa20Club.com Turbo Kit FASTEST IN FLORIDA lexusb3 Forced Induction 864 02-22-2014 10:00 AM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
JFlogerzi's FA20Club 91 and E85 Tune Results and Impressions jflogerzi Engine, Exhaust, Transmission 16 03-24-2013 01:09 AM
FA20CLUB.com Stage 1 ECUTEK Reflash Results FA20Club.com Engine, Exhaust, Transmission 20 08-25-2012 07:02 PM
