View Poll Results: Which 17x9 would you buy (or have)?
Enkei RPF1 92 35.66%
Mach V Awesome 23 8.91%
Rota DPT 3 1.16%
Gram Light 57DR 44 17.05%
Work Emotion Kiwami 17 6.59%
Wedssport TC105N 68 26.36%
Other (please specify) 11 4.26%
Voters: 258. You may not vote on this poll
Old 03-26-2013, 06:52 PM   #15
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
This is tough all based on personal preference and what the context of "Best" refers to. I personally like Avant Garde. I ordered a set in 18s but if i were to get 17s. I voted "Other" and would get their M220 set in 17s.
Old 03-26-2013, 07:12 PM   #16
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Originally Posted by RoguePiston View Post
I love the concave look, is that a +35 or +38? Or are those the same look with different hub width.
The +35 and +38 have the same face, just more pad material on the back for the +35
GTM_Challenge is offline   Reply With Quote
Old 03-26-2013, 08:03 PM   #17
coyote
coyote's Avatar
Drives: Slowly
The thing I really get from those pictures is how much better the >40mm offset wheels look than the wheels with offsets <40mm.
All are nice wheels, but one group looks like they were chosen for the car ... (to me) the other looks like someone made do with the wrong size.
Off the car, the Weds are my favourite out of that bunch ... but the +35 offset is a fail.
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
zdr93523 (03-11-2014)
Old 03-26-2013, 09:11 PM   #18
Foobar
SLO NO MO
Foobar's Avatar
Regarding offset fail, I think camber has some input on how well it looks as well.
Also, do you think the fail is on the fronts or both front and rear?
Sent from my Nexus 4 using Tapatalk 2
Old 03-26-2013, 09:27 PM   #19
D1cker
Drives: B9 S4/ND2
How is it a fail? They fill the fenders perfectly and dont rub even under extreme use (I've hit 1.5 G+ with mine and no issue)
D1cker is offline   Reply With Quote
The Following User Says Thank You to D1cker For This Useful Post:
dori. (03-27-2013)
Old 03-26-2013, 11:49 PM   #20
Captain Insano
Exactly. The +35 fits perfect and leaves lotso room for brake upgrades. I think that's win/win (form/function).
Old 03-26-2013, 11:57 PM   #21
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I still like the Rota Grid
Spartan65 is offline   Reply With Quote
Old 03-27-2013, 10:09 AM   #22
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
you're out of your mind
+35 is pretty much perfect
dori. is offline   Reply With Quote
The Following User Says Thank You to dori. For This Useful Post:
karma003 (10-18-2013)
Old 03-27-2013, 04:02 PM   #23
RoguePiston
Drives: 2013 SUBARU BRZ,2010 KTM DUKE 690
Originally Posted by stilletto View Post
Works. Hands Down. ..though I'd suggest 18x9.5
I really like the Works, the +38 offset is prime with the concave look. They are a little heavy though around 20lbs..
RoguePiston is offline   Reply With Quote
Old 03-27-2013, 04:09 PM   #24
RoguePiston
Originally Posted by JoeBoxer View Post
Titans are around 18 pounds i believe
57DR's are not light, my 18's weren't anyways.
The Titans look great the the BRZ, and pretty cheap at just over $200 a piece
Old 03-27-2013, 04:12 PM   #25
RoguePiston
Originally Posted by GT86drifter View Post
advan tc2 its 17x8.5 but close enough
I'm planning on running a 245/40 tire so a 17x8.5 is still good, might actually be more square on the wheel depending on the tire brand.
Old 03-27-2013, 04:16 PM   #26
RoguePiston
They look great in 18's on this FR-S, do you know the specs in 17x9?
Old 03-27-2013, 04:23 PM   #27
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
i run these too
GT86drifter is offline   Reply With Quote
Old 03-27-2013, 04:30 PM   #28
RoguePiston
I think it depends on the suspension setup your running. Plus the tire size and width... A +42 wheel will poke out a little on stock suspension, but a +35 can be nicely tucked in the fender with some negative camber, springs, coilovers, etc.
I'm planning on running Koni struts with good springs so a +35 is the lowest I would go based on my suspension plans.
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 02:35 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
