Old 07-15-2014, 08:36 AM   #15
tobin
tobin's Avatar
Drives: '13 BRZ
Originally Posted by FatFree View Post
I was wondering the same thing and it never seems to be answered clearly. Can the jdm exhaust tips be adjusted by pushing them past the metal stopper and if so how would one do this? The right tip sticks out noticeably further than the left and I would even like to push the left one in a little more too. Would you just use a rubber mallet?
I used a Dremel with a grinding stone to sand down the metal stoppers. I believe there are three bumps on the inside of each tip. Grind them down all the way until the inner diameter is completely round (the bumps are solid, you won't go through the metal). It took me about 40 minutes. I also rubbed a small amount of grease on the inside of the tip to push it on easier. Just push and twist the tips until it goes where you want it. I made mine so the bottom of the exhaust pipe is level with the smaller inner diameter of the tip.
tobin is offline   Reply With Quote
The Following User Says Thank You to tobin For This Useful Post:
FatFree (07-15-2014)
Old 07-15-2014, 01:04 PM   #16
btoast
I just pushed mine to the bumps and tightened them down. They don't stick out that far.
If you push too hard you may bend your muffler and then you will have one that sticks out more than the other.
If you push them back to the bumps you can get both to line up with each other no problem, but they will stick out a bit.
btoast is offline   Reply With Quote
Old 07-15-2014, 11:23 PM   #17
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
The problem is that they don't both line up. I would be fine with the distance that they stick out, although I would like them in just a tad bit more, but the passenger side exhaust tip sticks out noticeably more than the driver's side tip. That is even when they are both pushed all the way to the bumps.
FatFree is offline   Reply With Quote
Old 07-15-2014, 11:43 PM   #18
btoast
Are you checking to ensure that the tip is not sliding forward as you screw in the bottom bolt.
I had that issue. I would push the tip to the bump stop, make sure it was straight, then tighten the bolt, but the bolt would push the tip forward a bit.
I had to put pressure on the tip to keep it pushed back as I tightened the bolt.
Old 07-19-2014, 09:12 PM   #19
FatFree
FatFree's Avatar
Wow.... so I don't know what I was doing when I first installed the exhaust tips but I just unscrewed the passenger side tip and I pushed it in all the way successfully. Tips are now lined up evenly but I do wish they were a tad more flush with the diffuser. But they look good and I'm happy that they are now even!
Old 07-19-2014, 09:38 PM   #20
m.wood0213
Driving Enthusiast
m.wood0213's Avatar
Drives: 2013 BRZ Limited
I got mine shipped from japanparts.com for under 150 a years ago.
“This isn’t a supercar, it’s a sports car. It sacrifices rear seats yes but it just feels alive. Pure, direct, immediate. The other two are going to get all the admiring looks yes, that’s my point. I’m not driving around in this for other people’s benefit. I’m driving around in this BECAUSE I LOVE DRIVING IT. END!”
-Richard Hammond, Top Gear, USA Supercar Road Trip, 2011 Porsche GT3 RS.
My BRZ
m.wood0213 is offline   Reply With Quote
Old 08-10-2014, 06:40 PM   #21
jonnyozero3
Drives: 4 wheels & some metal bits
Long overdue answer. I just used a rubber mallet. Seemed to work fine.
jonnyozero3 is offline   Reply With Quote
JDM BRZ/GT-86 Exhaust Tips Sportsguy83 Engine, Exhaust, Transmission 166 09-16-2020 03:44 PM
Exhaust tips dawnst3ar Engine, Exhaust, Transmission 33 03-25-2015 12:27 PM
FS: JDM Exhaust Tips (OEM) Burrcold Canada Classifieds 12 04-08-2013 08:38 AM
Exhaust tips rawbz Cosmetic Modification (Interior/Exterior/Lighting) 37 01-19-2013 08:12 PM
