Old 03-19-2013, 07:36 AM   #15
robispec
Drives: Black frs project
yes just tell me your drop from stock and I will mark the spacers Black on the top of the spherical (I will assemble them too)
RObi
robispec is offline   Reply With Quote
Old 03-19-2013, 07:52 AM   #16
robispec
Originally Posted by eckoflyte View Post
sorry the barrage of questions, but i think it may be useful for other users too.
i've noticed the front mounting (if picturing from the right side of the car) of the arm is offset so that it is mounted lower thereby the control is angled downward toward the front. Would this be a pro-dive setup? I would think you would prefer the offset the other way around to induce anti-dive. What are your experiences on handling/driving the car with either setup? And what do you prefer in the FRS?
Nice note....and yes we started much higher. We kept testing and found that the position you see is the fastest and really shortened up the braking zones as the weight transfer became better as the nose quit pitching down so hard. (as the pivot is lower the arc as the outboard end tries to go up the tension arm gets longer and this is what resists the diving action under heavy braking)
So it is anti dive and we have settled on a position 0.75" lower than stock.
(on a rear trailing arm setup going towards the ground is "anti-lift" or pro-dive)
it also provides "extra castor" as the wheel goes up in bump travel giving you extra dynamic camber on the side of the car that is experiancing lower ride height than static.
Old 03-19-2013, 08:16 AM   #17
eckoflyte
Drives: Toyota 86 GTS
From a design pov, how do you feel about using 7075 aluminum ends mated with steel tubing? Any valid concerns of corrosion on the 7075 by itself or galvanic corrosion since its mated to steel chromoly? Im no expert on this btw.
eckoflyte is offline   Reply With Quote
Old 03-19-2013, 01:22 PM   #18
robispec
we design race parts if someone were to be concerned for their specific aplication I would say stay with steel rod ends..the aluminum are an option for those willing to make sacrifices to get every ounce/gram off their car.
Old 03-19-2013, 01:30 PM   #19
Hancha Group
FT86Club Official Vendor
Hancha Group's Avatar
Drives: Subarus
It should be okay as long it stays in a dry environment. It isn't as bad as I may have made it out to be. Salt water is what accelerates the process. Robi is from Socal, you are in Australia, whereas I'm from Chicago so the operating environments are completely different. This is why I'm extra nitpicky. Zinc plating the steel and anodizing the aluminum also reduces the electrochemical voltage dramatically.
Hancha Group is offline   Reply With Quote
Old 03-19-2013, 02:46 PM   #20
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
keep me broke why dont you
added to my list of stuff to buy 100%, these will be on top in the 'must have ' pile
and thank you for this innovation
Huehuecoyotl is offline   Reply With Quote
Old 03-19-2013, 03:40 PM   #21
sw20kosh
Drives: 2013 Black FR-S
Would you by chance be showing these off and/or installing them at the next few FT86cup events? I wouldn't have the slightest clue how to adjust something like this...
Awesome piece though! More adjustability is fantastic but this goes a little beyond my knowledge of suspension geometry/performance.
Old 03-20-2013, 07:13 AM   #22
eckoflyte
Is there more specific information on what type rod ends are used? Like brand or part number
Old 03-20-2013, 10:52 AM   #23
st0k3d
He had cheerio's for breakfast, enjoys long walks on the beach, and horseback riding too.
Give it a break, you don't need to know every detail about everything. They are adjustable control arms, nuff said.
st0k3d is offline   Reply With Quote
Old 03-20-2013, 12:02 PM   #24
robispec
yes
Old 03-20-2013, 12:53 PM   #25
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
These look like a really nice part Robi! Thanks for all the time you've out into them.
GTM_Challenge is offline   Reply With Quote
Old 03-20-2013, 03:48 PM   #26
Shit Luck
Drives: red frs
will these be optioned with no coating? I have access to powder coating and orange doesnt match my ride... lol
Shit Luck is offline   Reply With Quote
Old 03-20-2013, 07:40 PM   #27
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I saw these in person. Very nice setup especially if you are really serious about getting every last bit out of your suspension on the track. Coupled with the GroundControl or various other caster/camber plates you really do have more adjustment than you would ever need on the front for fine tuning
AZFA20 is offline   Reply With Quote
Old 03-21-2013, 01:47 AM   #28
eckoflyte
Sorry if my questions about the product annoyed you. It's just I'm going to be spending about $1500 on front lca, rear lca and toe arms. Theres a fair few brands floating around, so just want to educate myself on the differences and make the right decision as it is a lot of money. And I spose having more info available on a public forum will help other members draw there own conclusions too.
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Lower Control Arms- offset/angles comparision Huehuecoyotl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 03-08-2013 09:20 AM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
