Old 03-18-2013, 11:11 PM   #1
robispec
Drives: Black frs project
ROBISPEC Front ADJUSTABLE tubular lower control arms
FINALLY DONE WITH TESTING
last test over a 3" tall steel lamp base (plz don't ask it's embarassing)
TACOED the wheel so bad it was scraping on the Brake caliper and debeaded the tire.
these control arms are
rollcenter,
caster
track width
camber
and anti dive
adjustable
have bump steerable tierod ends too
NOW FOR SALE FINAL TESTING DONE
Proudly used by the Inovate Supercharged car at the Modified Magazine Ultimate street car Shootout.
These are HALF the weight of the stock item stiffer stronger and have a range of adjustment that excedes its usfulness..lol
robispec is offline   Reply With Quote
The Following 16 Users Say Thank You to robispec For This Useful Post:
03Z33 (03-25-2013), Anthonytpt (03-19-2013), B L U E S L A T E (03-26-2013), CSG Mike (03-19-2013), DAEMANO (03-29-2014), diss7 (08-25-2013), Enraged21 (05-25-2013), forwallblakmail (09-24-2013), JDKane527 (07-24-2013), NorCalRider (03-30-2013), PoorMansRacing (03-30-2014), Touge Monster (03-18-2013), ultra (08-26-2013), whataboutbob (03-19-2013), WillRacer1jz (03-19-2013), Wonderbar (08-25-2013)
Old 03-18-2013, 11:14 PM   #2
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Awesome been waiting for these
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-18-2013, 11:18 PM   #3
Captain Insano
Adjustable, stronger, AND half the weight. I like that.
Captain Insano is offline   Reply With Quote
Old 03-18-2013, 11:42 PM   #4
kanundrum
Drives: 2013 Whiteout FR-S
The Following 2 Users Say Thank You to kanundrum For This Useful Post:
ftc~brz (09-26-2013), robispec (03-19-2013)
Old 03-19-2013, 01:53 AM   #5
eckoflyte
Drives: Toyota 86 GTS
Price? Also what type of alloy is used for the body and ends/joints?
eckoflyte is offline   Reply With Quote
Old 03-19-2013, 01:55 AM   #6
whataboutbob
AutoX-10/10ths every run
VERY nice. Thanks Robi!
Build thread:Here
Old 03-19-2013, 02:09 AM   #7
robispec
4130 body, tension tube and tabs DOM bearing receiver on outboard end.
We have been using aluminum ends as we are not running wheel to wheel.
These make weight with the standard steel endlinks.
$ 750 with the bumpsteerable endlinks
The Following 2 Users Say Thank You to robispec For This Useful Post:
eckoflyte (03-19-2013), whataboutbob (03-21-2013)
Old 03-19-2013, 03:12 AM   #8
eckoflyte
what sort of aluminum alloy is used for the end joints?
Can we get closer up pictures of the adjustable RCA section?
Can the track width be adjusted with the arm on the car? I ask because I notice there is only one locking nut so doesnt look like the joint can rotate to adjust without it being off the car.
Exact weight? I've seen the stock front control arms on the scale and its 5.9 pounds.
Old 03-19-2013, 04:04 AM   #9
robispec
7075
I got what I got can correct roll center for up to a 4" drop from stock
No I dont like the compromises in beam strength and the weight increases by making it adjustable "on the car" the 12mm bolt is easy to remove and the rod end is easy to index at 1/2 turn/side when needed
I've weighed ten stock arms and they vary from 5.9 to 6.1
ours are 3.00 with steel rod ends
even if they weigh more the strength lack of flex and adgustability are the winners here! (imo)
The Following 3 Users Say Thank You to robispec For This Useful Post:
eckoflyte (03-19-2013), NorCalRider (03-30-2013), whataboutbob (03-21-2013)
Old 03-19-2013, 04:07 AM   #10
eckoflyte
sweet. can these be shipped with OEM mounting points already positioned so no need for end user to have to measure and mess around with adjustment?
Old 03-19-2013, 04:59 AM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Ummmm... I see Heim/rose joints. What are bump steerable tierod ends?
Ta.
Old 03-19-2013, 05:10 AM   #12
eckoflyte
was this a durability test for the control arms? how did they take it?
Old 03-19-2013, 07:08 AM   #13
eckoflyte
sorry the barrage of questions, but i think it may be useful for other users too.
i've noticed the front mounting (if picturing from the right side of the car) of the arm is offset so that it is mounted lower thereby the control is angled downward toward the front. Would this be a pro-dive setup? I would think you would prefer the offset the other way around to induce anti-dive. What are your experiences on handling/driving the car with either setup? And what do you prefer in the FRS?
Old 03-19-2013, 07:26 AM   #14
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Damn!
Sounds amazing; guess they are worth the money; will be third on my list.
MCA Coilovers, Whiteline Rear Lower Arms and now have found the front lower arms!
well unless you are making some rears as well cause this looks like a top product.
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Lower Control Arms- offset/angles comparision Huehuecoyotl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 03-08-2013 09:20 AM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
