Old 03-24-2013, 05:30 PM   #15
ILoveMyFR-S
ILoveMyFR-S's Avatar
Drives: FR-S Raven
Yes pad on rotor rubbing. I m using some acorn tuner lugs I got from autozone. I put 89 ft of torque but I'm not sure I'm thinking lug nuts might be the problem as well.
Originally Posted by Beyer Subaru View Post
Like pad on rotor rubbing?
I would suppose that if you were using improper lugs that didn't put proper torque on wheel to rotor to hub it could cause louder than usual rubbing.
To some degree there will always be a little bit of noise there in normal operation.
ILoveMyFR-S is offline   Reply With Quote
Old 03-25-2013, 10:13 AM   #16
wparsons
wparsons's Avatar
I don't know if the others answered this or not. You want the conical/tapered version. I believe that would be a 60 degree taper.
Most all OEM and aftermarket Suby wheels will be of this design. The problem that you will run into with some aftermarket wheels is that the OEM lugs will make contact with the rotor before they are "tight" against the wheel.
So the stock wheels are tapered seat for sure? Excellent, I was hoping I wouldn't need different lugs for my RPF1's (still too cold up here, so they're not even mounted yet).
flickr
Old 03-25-2013, 10:50 AM   #17
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Yes, the taper is the same degree but it is not necessarily the same surface area. I always recommend to go with aftermarket lugs with aftermarket wheels.
I don't think it's a good idea to "try" and make the OEM nuts work.
Beyer Subaru is offline   Reply With Quote
What type of connector is this? boredom.is.me Electronics | Audio | NAV | Infotainment 1 01-20-2013 12:28 PM
Oil type? orthojoe Tracking / Autocross / HPDE / Drifting 1 01-14-2013 04:11 AM
FRS/86/BRZ vs RSX Type S Maj3sty FR-S / BRZ vs.... 11 12-27-2012 05:17 PM
Eight-Six TRD vs FD2 Type-R suzuka FR-S / BRZ vs.... 47 08-19-2012 07:26 PM
What type off LSD you would like on the FT-86? Blokatos Engine, Exhaust, Transmission 43 02-17-2010 04:06 AM
