Old 08-24-2013, 07:35 AM   #15
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by omegared19 View Post
A battery relocation kit will transfer more weight to your trunk area, and lighten the front. It makes a huge difference in handling and acceleration. That may be your best bet at this point
If you do a rear seat delete is it possible to mount the battery in the middle of rear seat to maintain the trunk space?
Another random question, are there any rear seat deletes that let you fold down so you can still fit track wheels and tools?
Old 08-24-2013, 09:37 AM   #16
Sciby
Sciby's Avatar
Drives: 2013 MY14 WRB BRZ
You'd have to get a completely sealed battery - most have vents, hence them being in the engine bay. Some are mounted in the boot (ala R33/34 Skylines) but that's beacuse the rear seat doesn't fold down, etc.
Sciby is offline   Reply With Quote
Old 08-24-2013, 10:55 AM   #17
utekineir
blowhard
Drives: frs, project forester
The one you make.
utekineir is offline   Reply With Quote
Old 08-24-2013, 04:12 PM   #18
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
-Taking everything out of the trunk shaved off 82lbs for me.
-Going from a stock exhaust to a single exit muffler delet track pipe saved me another 23lbs.
-Going to 17x9 rpf1s saves about 4lbs on each corner which is 16lbs total of unsprung weight.
Switch to some lightweight bucket seats that weigh like 10lbs each and a lightweight battery kit and that'll save you another 50lbs or so easy. I'll be doing this eventually as well. Also keep in mind that aftermarket engine/suspension components (headers, control arms etc) can also shed some weight while increasing overall performance,
So I'm about 120lbs lighter than stock and it cost me a lot less than going CF crazy and buying pointless shit.
TylerLieberman is offline   Reply With Quote
The Following 2 Users Say Thank You to TylerLieberman For This Useful Post:
BlueDubbinTDI (08-24-2013), DAEMANO (08-26-2013)
Old 08-24-2013, 06:09 PM   #19
Celica00
Celica00's Avatar
Drives: 86
Originally Posted by boredom.is.me View Post
5- You'll never have a flat as long as you have your spare. As soon as you take the spare out, you'll end up with a flat.
I was reading over this thread this morning and saw what you said and was like 'fucking hell yes i'm thanking the shit out of this post' only to see that I already did 5 months ago haha.
Celica00 is offline   Reply With Quote
The Following User Says Thank You to Celica00 For This Useful Post:
boredom.is.me (08-24-2013)
Old 08-24-2013, 06:11 PM   #20
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Haha
Old 08-24-2013, 09:14 PM   #21
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
First off, most trunk deletes have you remove that rear seat section of the center console. I'm not sure if it's removable without removing the center console in the front at the same time. The rear cushions are removable by themselves, and you don't need to buy any kids of delete kits. Once you remove the rear cushions, yes you can mount the battery in the rear seat area. If you were looking to mount it back there and still keep a sealed trunk, thus keeping the rear seat back, I'd recommend mounting the battery on the floor behind one of the two front seats. That way you can still fold down the rear seat back. If you are planning on removing the rear seat back, and still want the ability to load those 4 extra wheels for the track, then I'd recommend removing the rear seat belts as well for weight. But regardless of where in the cabin you want to mount the battery, you'll need a battery case with relocation kit. You do your research, you can make your own relocation kit. Shouldn't be too terribly difficult.
I realize this is a lot of info, just weigh all the pro's n con's before making any final decisions. Feel free to hit me up with any other questions, good luck, and may the force be with you.
omegared19 is offline   Reply With Quote
Old 08-24-2013, 09:17 PM   #22
omegared19
omegared19's Avatar
One more thing, no there are no rear seat delete kits that fold down. They're all bolted in. Thus you can not do that cool bring your extra wheels to the track thing.
Old 08-25-2013, 08:12 AM   #23
charged86
charged86's Avatar
Forced induction
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 08-26-2013, 03:11 AM   #24
SiSGT86
Drives: White, stock.
^ what's up with you FI guys hijacking every thread whether it's about tuning an NA or taking out weight of a car. Your ideas a redundant, uninspiring and un-original. Not to mention incredibly annoying.
SiSGT86 is offline   Reply With Quote
Old 08-26-2013, 02:26 PM   #25
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
No way the spare and tools weight that much, do they?
jadewbj is offline   Reply With Quote
Old 08-26-2013, 03:39 PM   #26
TylerLieberman
Drives: '24 GR86
I took everything out. Tools, spare tire, and all of the interior trim pieces.
Everything came out to a bit over 80lbs.
Old 08-26-2013, 03:59 PM   #27
jadewbj
jadewbj's Avatar
Wow, did not think it was that much. I pulled the tire, tools and left all the carpet and trim in. I actually need to get some foam to fill the area cause you can't put anything of any weight in there now, it collapses the cover lol.
Old 08-26-2013, 04:09 PM   #28
TylerLieberman
Drives: '24 GR86
Yeah by taking everything out, I can put 4 wheels, jack and stands, helmets, and a shit ton of tools in my car now with ease.
Weight..... icemang17 Tracking / Autocross / HPDE / Drifting 2 07-02-2012 07:24 PM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 03:55 PM
Actual Weight For FRS??? DanPO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-22-2012 06:07 PM
Official JDM BRZ weight and MPG ayau BRZ First-Gen (2012+) — General Topics 50 02-08-2012 03:04 AM
Weight of FT-86? Levi Engine, Exhaust, Transmission 38 06-14-2011 11:43 PM
