Old 03-15-2013, 03:23 AM   #15
Ahernandez0909
Ahernandez0909's Avatar
Drives: '13 Asphalt FR-S M/T
Originally Posted by ATL BRZ View Post
I'd go with the AB if you plan on keeping everything else in the exhaust stock, AB-M if not.
That's the thing... Idk if I'm eventually getting a mid pipe or not
Yes, yes that is a Scion.
Member Journal
Ahernandez0909 is offline   Reply With Quote
Old 03-15-2013, 03:26 AM   #16
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
AB-M is the safest option IMHO
86_ZN6 is offline   Reply With Quote
Old 03-15-2013, 03:37 AM   #17
Ahernandez0909
But I love the delete sound ughhhh I'm so indecisive.... Heads or tails... Haha
Member Journal
Old 03-15-2013, 06:53 AM   #18
vtmike
vtmike's Avatar
Drives: Scion FR-S
If you're considering something muffled the nameless axleback is better than both of those. Better sound, better steel, and better welds. They also have a dual exit muffler delete. It's more expensive than the other 2 but you get what you pay for. If this is your daily I wouldn't consider anything that's aluminized steel.
Sent from my Nexus 7 using Tapatalk HD
vtmike is offline   Reply With Quote
Old 03-15-2013, 06:54 AM   #19
vtmike
vtmike's Avatar
Drives: Scion FR-S
Although you may be alright if you don't leave souther ca often.
Old 03-15-2013, 09:38 AM   #20
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
All opinions, and off topic at that, but hey, thanks. I don't get why some people think mig welded aluminized steel with a coating on top is going to just fall apart, lol, give me a break. I personally find the Nameless way too quiet to warrant the cost. Also the design is just too complicated with all the piping and bends. I like simple designs and more significant weight savings. To each their own... right?
After watching the AB-M videos, to me it sounds like 75% as loud as the delete but a more gentlemanly tone. I'm also planning ahead for headers and midpipe in the distant future, so that's why I'm going with it. The works midpipe bolts right up and frees up 6hp, I like that it will fit the OEM muffler too in case I ever want to go quieter in the future.
The AB is probably 90% as loud as the delete without the drone.
Old 03-15-2013, 10:06 AM   #21
vtmike
vtmike's Avatar
Drives: Scion FR-S
I can understand not liking a particular design or sound. But, there are plenty of "simple" designs that use quality materials.
Motiv and perrin to name two.
It's a fact aluminized steel is going to fail sooner than t304. I don't understand why people would spend 27k on a new car and put a cheap exhaust on it that is worse quality than what came on it.
Sent from my Galaxy Nexus using Tapatalk 2
Old 03-15-2013, 10:31 AM   #22
sierra
Drives: Skoda Yeti DSG diesel 4x4
Looking forward to getting my AB-M shortly.
Here's a vid of it (WORKS AB-M) for those curious:
That video showed the left hand side is a waste of time with all the flow and sound coming from the right hand tip, as you would expect. I don't see the point? Why not just have a track pipe and a dummy tip on the right side?
It would save weight and be more efficient.
sierra is offline   Reply With Quote
Old 03-15-2013, 10:33 AM   #23
ATL BRZ
ATL BRZ's Avatar
If you pay closer attention you'll see the flow change dynamically from the left tip at idle to both tips in the midrange to mostly the right tip in higher rpms. A dummy tip wouldn't be audible in person and a single exit track pipe doesn't rumble nearly as much as a true dual exit.
Old 03-15-2013, 10:36 AM   #24
vtmike
vtmike's Avatar
Drives: Scion FR-S
Apparently it comes out one side off load and out the other during load. Looks bad in my opinion to have dual exit exhaust with exhaust gas only coming out one side at a time.
Old 03-15-2013, 10:39 AM   #25
ATL BRZ
ATL BRZ's Avatar
Because exhaust gases on a n/a car with two cats are so visible all the time, especially when it has warmed up,
Old 03-15-2013, 10:43 AM   #26
vtmike
vtmike's Avatar
Drives: Scion FR-S
Enjoy your cheap, poorly designed and fabricated exhaust. and replace in 2 years when it rusts through
Old 03-15-2013, 10:47 AM   #27
ATL BRZ
ATL BRZ's Avatar
Old 03-15-2013, 10:48 AM   #28
sierra
I did pay close attention and the flow is the same as if water was flowing through and the tips were pointing down. It dribbles out of the left pipe on idle but with a bit of pressure it all squirts out of the right pipe.
Compared to something like a Nameless axleback it's very crude but each to their own.
Berk Technology Muffler Delete jeebus Engine, Exhaust, Transmission 31 12-22-2014 03:34 PM
Berk Technology Dual Muffler Delete Group Buy!!! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 93 12-16-2013 09:54 AM
FS (BC): BERK technology muffler delete pipe stanm Canada Classifieds 16 01-03-2013 11:32 AM
FS: BERK Muffler Delete Dual Tip stanm Engine, Exhaust, Bolt-Ons 17 12-03-2012 10:13 PM
Berk Technology Dual Exit Muffler Delete jeebus Engine, Exhaust, Transmission 7 10-16-2012 09:38 PM
