Old 03-14-2013, 01:20 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by whtchocla7e View Post
Did they also replace the timing gears?
The way they jumped to conclusions quickly and tried to pin it on you, tells me they know something. Maybe the botched the job.
This! This happened to a local guy but the dealer admitted the mistake and replaced the engine.
Fight the hell out of this one. Worst case, insurance should (I know multiple that have) cover hydrolock as a comp claim but that should be an absolutel LAST resort.
I'd want evidence of hydrolock though, water near/on the throttle body isn't evidence.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
tripjammer (03-19-2013)
Old 03-14-2013, 01:20 PM   #16
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
you should fight dealer and hire attorney if they BSing you.
it's impossible to hydrolock it with stock air filter. even CAI design for this car, it will get hydrolocked. like Jeebus said, CAI that design that filter is located right in front of wheel, like RSX-S, Civic Si would get hydrolocked but this is not right case.
Old 03-14-2013, 01:24 PM   #17
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A lawyer is a bad idea at this time. If he gets a lawyer so will they and everything will stop until the lawyers fight it out at the expense of all involved. Probably the worst next step he could take honestly.
Instead he needs to keep fighting with corporate, file a BBB claim and start a social media campaign. All of that is more effective right now than a lawyer would be.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 3 Users Say Thank You to Dave-ROR For This Useful Post:
jstans84 (03-26-2013), SkullWorks (03-14-2013), tripjammer (03-19-2013)
Old 03-14-2013, 01:30 PM   #18
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by pozer View Post
I also removed the resonator so the large hole on the right side of the box is open but this would still mean I would need to fill the engine bay with water and it would also stop the lower part of the stock air box from sucking up any water in since it can't complete a vacuum.
Let me get this straight, you removed the resonator, and didn't plug the hole. So you've got a 2.5" hole that is completely open, bypassing the air filter?
post_break is offline   Reply With Quote
The Following 2 Users Say Thank You to post_break For This Useful Post:
Sportsguy83 (03-14-2013), tripjammer (03-19-2013)
Old 03-14-2013, 01:34 PM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's before the filter. The only hole post-filter is for the sound generator which he didn't mention.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-14-2013, 01:36 PM   #20
pozer
pozer's Avatar
Drives: 13 FR - s
Send a message via AIM to pozer
Wouldn't it be easy for them to just drop the oil pan and shake the rods and see if its a bearing? That's like 20min tops...
pozer is offline   Reply With Quote
Old 03-14-2013, 01:36 PM   #21
SkullWorks
Drives: SSM LT MT BRZ
Who currently has possession of the vehicle?
Is the motor still in the car?
If the car is still intact I would have it assessed by a third party. Find anyone with a mechanical engineering degree and experience with cars and have it looked at, his word on paper accompanied by his title and listed degrees will be hard for Scion to ignore. it is important to get someone else's professional opinion before the dealership gets in there and starts covering their a$$
SkullWorks is offline   Reply With Quote
Old 03-14-2013, 01:48 PM   #22
post_break
post_break's Avatar
Gotcha, I thought he removed the sound generator.
Old 03-14-2013, 01:51 PM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
He said resonator so I assumed the helmholtz resonator. He could have misspoke, I haven't seen the car so.. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-14-2013, 02:11 PM   #24
pozer
pozer's Avatar
Drives: 13 FR - s
You can see the intake in the video everything behind the filter is intact.
The Following User Says Thank You to pozer For This Useful Post:
Old 03-14-2013, 02:42 PM   #25
NickFRS
Drives: 2013 Asphalt FRS
Call toyota. Make a complaint. They will give you a claim and call them. Toyota reps will be on your side 100% more then a stupid tech.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
The Following User Says Thank You to NickFRS For This Useful Post:
Jesse (03-18-2013)
Old 03-14-2013, 03:23 PM   #26
pozer
pozer's Avatar
Drives: 13 FR - s
I did get a call back form dealer and the service manager was much nicer and more informative that the customer rep I spoke with early. Toyota has authorized them to look at it tomorrow and find what cyl it is and if its a rod or the bearing. I feel allot better about this knowing I did not hit water......
Old 03-14-2013, 05:47 PM   #27
FirestormFRS
A hydro locked engine in most circumstances dies period. I've seen hydro locked engines on the inside and it's never just one cylinder that is messed up. Generally all four are jacked up and they roll out the side of the block. I doubt it's hydro locked at all
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
*KID* (03-19-2013)
Old 03-14-2013, 06:18 PM   #28
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
Yes All the holes are on the inside of the engine bay... I also removed the resonator so the large hole on the right side of the box is open but this would still mean I would need to fill the engine bay with water and it would also stop the lower part of the stock air box from sucking up any water in since it can't complete a vacuum.
BTW I completely agree had I hydro locked the engine they should not cover it but this is not the case..
wait... you left the hole open when you removed the sound resonator? you do realize that basically by passes the mass ? which could produce an issue.
DanoFA20 is offline   Reply With Quote
BC Racing Coilovers - Knock? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 12-09-2015 10:41 PM
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 07:10 PM
Why you shouldnt support knock off companies.. showbe Engine, Exhaust, Transmission 44 10-29-2012 08:13 AM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
