Old 01-04-2012, 01:54 PM   #15
Crashoverride
here, there, any where
Drives: FR-S SOON!!!
slight deep dish looks nice on a good staggered setup but some are just WAY over the top.
Crashoverride is offline   Reply With Quote
Old 01-11-2012, 08:56 PM   #16
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I'm willing to bet you can get it down to the low +20s without much trouble. Reason being is the GReddy car, for one was running converted hubs. Second, the car was running little/close to the factory camber settings. Next, the tires were hardly stretched. Not to mention the car was on 19s and there was still a big gap between the tire and the fender line.
17x9 +15 up front w/ 215/40R17
18x9.5 +22 rear w/ 225/40R18s.....or 235s for people who have no balls and say that's too much stretch or not functional and blah blah blah
^^Easily attainable and will be done
TylerLieberman is offline   Reply With Quote
Old 01-11-2012, 11:12 PM   #17
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
i can see those sizes fitting the AS1. Question is some show car builders are looking for that 3+inch lip on their wheels, in that case some width might be sacrificed in favor of offset to fit under the stock fenderlines even if abit rolled, or maybe not.
WingsofWar is offline   Reply With Quote
Old 01-11-2012, 11:43 PM   #18
emm3tt
Drives: e46 m3
Concavity is the new lip.
emm3tt is offline   Reply With Quote
Old 01-11-2012, 11:54 PM   #19
old greg
Rocket Surgeon
Drives: PSM GGA OMG
I don't see why they would. Running a narrower wheel with lower offset won't change front spacing (ie. lip), only the back spacing. There's only so much distance between the hub face and the fender, the width and offset of a wheel can't change that.
old greg is offline   Reply With Quote
Old 01-12-2012, 12:33 AM   #20
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
maybe im too use to cars in the past with stock high offsets like many FWD with +40/50/60 offset, and people who want to run deep dish wheels sacrificing wheel width for more offset because of limited spacing and many wheels built back then with lots of dish also had lower offsets. So it was impossible to get away with a High offset wide deep dish wheel back then...not sure about now.
Old 01-12-2012, 07:23 AM   #21
TylerLieberman
Drives: '24 GR86
Yeah theres only so much distance from the hub, where the wheel disc will meet, to the fender line. Only thing that will increase the lip is running a lower offset. Wheel width, wont make a differance. Yeah, the offset will be different, but in the end, itll still have the same lip size.
Old 01-12-2012, 03:07 PM   #22
Caliban
Terrorist of Chat Rooms
Drives: 05 E46M3, 06 CT9ARS, FR-S?
why would u run 17x9 front and 18x9.5 rear on the FRS/BRZ? why not 18x9 front and 18x9.5 rear? just curious
Caliban is offline   Reply With Quote
Old 01-12-2012, 04:16 PM   #23
old greg
Rocket Surgeon
Drives: PSM GGA OMG
For looks. I'm not advocating it, it's just purely nonfunctional.
Old 01-12-2012, 06:34 PM   #24
TylerLieberman
Drives: '24 GR86
I would for the use of drifting. Running 17s up front is better than running 18s. You're able to run a wide wheel, thus able to run a wider tire. To add to that, since they're 17s and not 18s, you'll still have more clearance for the wheel to get full lock without the worry of rubbing the fender well. ESPECIALLY WITH MODDED KNUCKLES.
Having the wider and taller tires up front helps with front end grip. Wide tires, 4 degrees negative camber, modded knuckles=stupid angle!
Old 01-16-2012, 06:47 PM   #25
Blaster
Drives: 2007 VW GTI
Being that it's a Subaru I don't think we'll be able to fit nice low offsets without some fender mods, camber, and stretch. I want to retain the stock tire size so I think a 17x9,17x9.5.18x9, or 18x9.5 would look sweet with a 215
Blaster is offline   Reply With Quote
Old 02-19-2012, 07:45 PM   #26
yogi86
DriftAmmo
yogi86's Avatar
Drives: Silvia S13, GT86 (soon)
im just going to wait and get the car first and see what we can fit under her... even making our own adjust be arms/ coilover, will be on the books, hopefully toyota rethinks there 5x100 stud patten (yuck)
yogi86 is offline   Reply With Quote
Wheel 101: JDLM Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-04-2021 07:54 PM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
Wheel offset on watanabes? Decameron Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2010 06:20 PM
Anyone order a Deep Dish? S2KtoFT86 Other Vehicles & General Automotive Discussions 8 12-04-2009 11:24 PM
