Old 12-23-2011, 03:12 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by MrVito View Post
Additionally, a better front brake option may be the 06-07 WRX calipers. They can be cleared by 16" wheels. They're under $700 for the pair ( http://www.gotboostinc.com/su4frbrcasuw.html ), they use the same line fitting as stock sliders. 4 pot monoblock, and it uses the same pad sizes from 02-11 WRX's, huge aftermarket support there. The WRX uses a 295mm vented rotor, and I wouldn't be surprised if the AS1 does as well. I also know that the 4 pots don't suffer from mushy-pedal-syndrome when paired with a stock WRX MC which pushes the same sliding calipers that appear to be on the AS1. To be fair, this does nothing to address rotor size, but if people are all that concerned with actual braking force, this may be a slightly more cost effective option.
True, and yes the AS1 uses the same 295mm rotors.
But I'd only suggest this for looks. As Vito pointed out, you are not increasing the size of the rotors (to some extend they would help with fluid fade.. SLIGHTLY... and only for an extra lap or so..), and the stock sliders will lock up the tires just fine so there is no shortening of the braking distance to be had here with slamming on the brakes.. but you should get better modulation and pad wear. With better modulation comes the ability to more easily find impending lockup which will outbrake ABS (slightly) assuming the ABS system isn't tuned overly agressively.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-23-2011, 03:15 PM   #16
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Perhaps Legacy GT Front rotors and sliders as a more effect option?
Just looking over the OEM Subaru brake options at http://forums.nasioc.com/forums/show....php?t=1265631 , and it appears that they mey be the best "bang for your buck" solution. 2005-2009 LGT that is.
Edit:
Possible vented disc solution for the rears, stolen from the same thread:
290x18mm (170mm parking brake)
290x18mm (190mm parking brake)
290x18mm (2010+ Legacy GT)
This is a new rotor size for Subaru (in the US anyway). It uses either a 2-piston opposed caliper or a 1-pot slider. The 2-pot will not bolt up to other Subarus without something like the Kartboy brackets or having a new backing plate pressed onto the spindle. There are three versions of this rotor, one is for the regular 170mm parking brake, the others are for the sti 190mm parking brake in both 5x100 and 5x114.3
Applications:
05+ Legacy GT (1-pot)
06-07 WRX (2-pot)
SVX (5x114.3) (only in JDM-land)
Some older non-us spec-b Legacys and wrx/sti models (see rear brake redux)
Note: The LGT uses a different brake line than older Legacies and Imprezas. So I think you need to grind down part of the caliper where the line mounts to get it to work on an Impreza. The LGT lines are a different shape and mount and a different angle and you can't use them.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 12-23-2011, 03:19 PM   #17
Homemade WRX
Pro Subie Engine Nerd
Homemade WRX's Avatar
Drives: BRZ has a reserved space
Originally Posted by Ryephile View Post
You've alluded to this a handful of times in your posts. You've also mentioned you consult with OEM's, which rules out virtually all aftermarket. So who do you work for?
I do both. I own 3MI Racing (designing tailored/custom Subie parts since 06) and also consult at Volvo Powertrain in their performance and emissions group.
3MI Racing.
I a long time Subaru head (though use to have an old SR5 too, twas stolen...to those Toyota guys) and know/work with several vendors or give input on ideas and projects. I then do my 3MI Racing stuff which is more engine oriented in block, heads and subsystem design work. But I'm finally coming out of the tailored market and going mainstream with a few engines...hence my website now being under construction.
Still waiting to see if Quirt and Bill will let me know about fueling.
Homemade WRX is offline   Reply With Quote
Old 12-23-2011, 03:24 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Edit:
Applications:
06-07 WRX (2-pot)
Nice link
Was just going to post that (the LGT rear info) but then I did the quick math.. the 290x18 is stock on the AS1 using the Legacy GT 1 pot slider Otherwise that would have been the ideal rear upgrade for cheapness since you wouldn't have to deal with the parking brake crap.
The front LGT upgrade definately sounds interesting although I suspect Subaru would have tried that and found the front bias to be too much.. or maybe originally it was WRX all around and fixed the front bias issue with the LGT rears.. either way just upgrading the fronts to LGT spec may be enough to offset the bias enough on track to hurt braking performance... someone will have to test.
If you are limited by the AS1 stock brakes but want to save some money perhaps STI rears and LGT fronts would balance out pretty nicely..
edit: last sentence was totally wrong, was processing too many things in my head while typing lol
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-23-2011, 03:28 PM   #19
oneday
Opinionated
oneday's Avatar
Drives: Something Red
The likelihood of COBB doing anything for this car is pretty slim. They completely back ed out of the non-FI marketplace a couple of years ago and I just spoke with Gary while at SEMA about support for new non-FI cars and he indicated that it would be hard for them to justify getting back into that game. That primarily applies to AccessPORTS, btw...I'm sure that if current WRX/STI hardparts are direct bolt ons, then you'll see some crossover.
All of the usual suspects will have parts out quickly...AEM/K&N, Perrin, Whiteline, Cusco, GTSPEC, Invidia, HKS, Greddy (obviously), Brian Crower, KW, Tein, Eibach, and Hotchkis.
And Robispec? Really, how is that guy still relevant? He was terrible to deal with seven years ago when my friend and I were giving him feedback on his early KW spec Evo kits.
Most of the cars I drive have nets for windows.
oneday is offline   Reply With Quote
Old 12-23-2011, 03:34 PM   #20
Homemade WRX
^^^I was figuring with how the market is so hyped about his car, that Cobb would be back into the NA market...sounds like I was wrong.
Old 12-23-2011, 04:07 PM   #21
Farred
Farred's Avatar
Drives: my wife crazy
perrin and ams please!!!
Farred is offline   Reply With Quote
Old 12-23-2011, 04:09 PM   #22
oneday
Opinionated
oneday's Avatar
Yea, I was hoping they would be able to apply their skills to this platform too. Maybe there will be enough call for an AP, but I doubt they will be able to make more than 5-10hp from a tune and that is hard to justify charging the $495-595 MSRP that they would need to charge for the AP to cover expenses.
Old 12-23-2011, 04:48 PM   #23
Torquesteered
Torquesteered's Avatar
Drives: 07 fusion
I hope Cosworth is planning on doing some n/a parts and even full packages for this car, they have worked alot with subaru recently on the wrx STI. They have built some great n/a motors.
Torquesteered is offline   Reply With Quote
Old 12-23-2011, 05:16 PM   #24
brzmaybe
Drives: Subaru
Thanks on Aftermarket Suppliers
Thanks. That's the list I was looking for. Greddy's already shown a modified FT86... does that mean that frontline suppliers might find themselves in receipt of preproduction BRZ' before too long? Or is Subaru not so inclined to front load the aftermarket?
brzmaybe is offline   Reply With Quote
Old 12-23-2011, 05:25 PM   #25
brzmaybe
Drives: Subaru
Old 12-23-2011, 06:22 PM   #26
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Same car man. Any parts developed for the 86 will work on the brz
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-23-2011, 07:25 PM   #27
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
GT86/FR-S/BRZ
Same car different bumpers (and cosmetic crap)
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-23-2011, 07:25 PM   #28
coyote
coyote's Avatar
Drives: Slowly
This will be the first setup I test, as everything needed is sitting in my garage.
Good thread.
coyote is offline   Reply With Quote
Aftermarket battery speed-wiz Scion FR-S / Toyota 86 GT86 General Forum 59 08-08-2012 12:23 AM
Aftermarket wheels chopped onto Modellista 86 JDM-dono FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 12-20-2011 05:20 AM
Aftermarket wheels? Levi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-06-2011 08:19 AM
What Aftermarket parts would you like to see for the FT86/FRS mkivalex Scion FR-S / Toyota 86 GT86 General Forum 78 11-14-2011 11:50 AM
Toyota FT-86: a goldmine for aftermarket parts Axel Scion FR-S / Toyota 86 GT86 General Forum 16 12-27-2009 11:16 AM
