Old 02-15-2013, 03:45 PM   #15
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I think that your observation about it only being less comfortable over really rough stuff and big hits is pretty indicative of a good damper. I've found that disregarding big hits, comfort is more dependent on damper quality and setup than spring rate, at least until you go to the extreme.
Nathan
SubieNate is offline   Reply With Quote
Old 03-19-2013, 05:38 PM   #16
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Originally Posted by Turn in Concepts View Post
Koni with RCE Yellows
After a few months of testing this suspension setup we have completely fallen in love with it. The ride quality is very similar to stock and the car is quite comfortable to drive making this setup perfect for a daily driver. As expected, the only noticeable difference in comfort is found over large bumps and rough patches in the road however we found that for street driving, setting the dampers to their lower settings minimized the increased roughness of the Konis compared tot he OEM setup.
When you push the car in the turns, the fun really begins, much of the stock body roll is eliminated. The responsiveness of the car at turn in is astounding! The nimbleness that the car has in stock forum is not lost with this setup. The car can still be thrown around and controlled but is now even easier to control at the limit. Whether you are tracking, Auto X, or just hooning the car is simply more fun to drive, and much faster!
For anyone looking for a setup that looks great, performs great, and feels great this is the setup for you.
I foresee a trip to Cincy to get this setup (plus a little more) installed in my future.
Apex Chase is offline   Reply With Quote
Old 05-20-2013, 11:05 AM   #17
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
This still in favor as a suspension choice after a couple more months on it. Planning to go this route shortly myself.
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 05-20-2013, 11:35 AM   #18
Turn in Concepts
Turn in Concepts's Avatar
You will not regret going this route!
Turn in Concepts is offline   Reply With Quote
Old 05-21-2013, 02:06 AM   #19
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
I had a set of these on my ms6 with a mild drop spring and it handled like a beast! If I find an extra set of oem struts this would be very tempting.
spdfreak is offline   Reply With Quote
Old 05-21-2013, 10:33 AM   #20
WolfSongX
WolfSongX's Avatar
I have a thread out in the Classifieds that have had a few people with donor struts respond to it. I have a pending deal with someone already, so it's possible that a few of these others have donors available. You should check it out.
It might be worth it to start a thread in there where people can indicate that they have a set of struts or suspension available for conversion where people wanting to do this swap can go look for donors. At the time there were 3 WTB threads for donor struts.
Derek
Old 05-21-2013, 12:47 PM   #21
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
I closed on a deal with another forum member on a set of front OEM dampers last night myself. Hopefully I'll be on a set of Koni Yellows & Eibach Pro-Kits before too long.
mit_peid is offline   Reply With Quote
Old 05-21-2013, 02:35 PM   #22
Turn in Concepts
Keep in mind we offer NEW donor housings and install the konis in some of our packages!
Old 05-09-2014, 12:04 PM   #23
Account Attempt No. 4
Account Attempt No. 4's Avatar
Drives: 2013 WRB BRZ Limited
Can you PM me a price for this? I already have the RCE yellows on my car but I really don't want to go to the hassle of drilling/cutting the OEM housing myself.
Hopefully you still do this, (old thread!)
Originally Posted by Calum View Post
No it's not. - Yes it is. - It'll make 400 whp. - No, it'll only make 200 whp and break down all the time. - Oil temperatures!! - This will never happen. - But the other kit. - Turbo is better. - No, supercharger is better. - Rotrex sucks. - You suck. - Perrin said. - But Visconti said.
Account Attempt No. 4 is offline   Reply With Quote
The Following User Says Thank You to Account Attempt No. 4 For This Useful Post:
DAEMANO (05-09-2014)
Old 05-11-2014, 04:15 PM   #24
ncmx5
ncmx5's Avatar
Drives: 2013 BRZ premium
Just take your time and be careful with your measurements and you wont have a problem at all doing the fronts. No need to buy another set of dampers
ncmx5 is offline   Reply With Quote
Old 05-12-2014, 11:48 AM   #25
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I wish I had donors instead of cutting mine. That way I could easily just swap back and forth for winter. Lowered in snow no fun. I may look for front shocks and re-assemble the stock stuff.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 06-18-2014, 05:39 PM   #26
Turn in Concepts
Give us a call and we can help you with this.
red door handle inserts abutterman Cosmetic Modification (Interior/Exterior/Lighting) 4 08-04-2015 09:10 PM
Koni Suspension Components dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 06-20-2013 10:00 PM
FYI: Status of Koni Sports Sam Strano Tracking / Autocross / HPDE / Drifting 68 06-14-2013 04:19 PM
KONI!! Are here! Turn in Concepts Brakes, Suspension, Chassis 14 04-01-2013 07:38 AM
Cross member bushings vs. Inserts wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 11-22-2012 03:40 PM
