Old 02-12-2013, 12:06 AM   #15
Ben_G
Drives: Blue BRZ
Wheel wells for sure...and the engine bay.... and wheels.... and underbody.... but how durable is the coating to heat and impact?
Ben_G is offline   Reply With Quote
Old 02-13-2013, 06:48 AM   #16
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
I want to dip my car in this stuff
[ame="http://www.youtube.com/watch?v=IfUaKXasdD4&feature=player_embedded"]Ultra Ever Dry - YouTube[/ame]
Vladror is offline   Reply With Quote
Old 02-13-2013, 06:57 AM   #17
Shagaliscious
Drives: Firestorm FR-S (MT)
Someone posted this in the off-topic section already.
http://www.ft86club.com/forums/showthread.php?t=28740
Old 02-13-2013, 06:59 AM   #18
Wolfe
86 Investigator
Wolfe's Avatar
Drives: RX-8
I want to dip me in this stuff and then go swimming. I wonder how long it lasts. Amazing.
日本製
Wolfe is offline   Reply With Quote
Old 02-13-2013, 08:13 AM   #19
blackraven1425
Drives: raven at
A couple of the comments on the video seem to say that's probably a bad idea. It's toxic to inhale since it's a silica, and if you jumped in the pool, you'd hit the bottom as if there's no water in it.
EDIT: After doing some looking around, it's not transparent. It's a bit cloudy in appearance. They're working on a transparent version, which would obviously be a bit more appropriate for external use. There's also claims that it doesn't take to abrasion very well. It's removed with standard detergents, but I'd think that's not an issue since you'd never need to wash the car anyway.
blackraven1425 is offline   Reply With Quote
Old 02-13-2013, 10:31 AM   #20
FRiSson
Drives: FR-S MT
You realize that once cars have impervious surfaces that stay clean all the time, there will no longer be any real value attached to a clean car. For a clean and shiny car to look good, there must be lots of dirty cars around. That's why houses that don't need to be painted (pre-colored siding) have a lower value than houses that require it. Before wrinkle-free shirts, a freshly-ironed shirt really set you apart as a careful dresser. Now wrinkle free shirts are the lowest common denominator, and have no special value.
FRiSson is offline   Reply With Quote
Old 02-13-2013, 10:35 AM   #21
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i'd like to coat my under carriage with this, but not on my paint.
chenshuo is offline   Reply With Quote
Old 02-13-2013, 10:52 AM   #22
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
I don't know if I would want to dip my undercarriage in this stuff until they have a health and safety study. It may cure swamp-ass but side effects may not be worth it.
Scott
naikaidriver is offline   Reply With Quote
Old 02-13-2013, 11:06 AM   #23
blackraven1425
Drives: raven at
Except for the fact that getting your car coated in this is likely to run into the hundreds to thousands range in price, and would need to be done every couple years. Then, it's only going to be people with some money who can actually afford to do this to their car who care about the way it looks.
Old 02-13-2013, 11:12 AM   #24
blackraven1425
Drives: raven at
Scott
It's only really dangerous if you breathe it in or get it in your eyes while it's wet. Look at the safety data sheets.
http://www.ultraeverdrystore.com/how-to-use/
Old 02-13-2013, 11:13 AM   #25
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
As I said in some other post, once applied, touching it destroys the effect. It mats down the microfibers, and the exposed surface area goes way up. You'd need to apply it after every wash. Watch the video closely: they never touch the treated surface.
b.e is offline   Reply With Quote
Old 02-13-2013, 11:15 AM   #26
Frostyman
Drives: 2013 Raven FRS
Scott
I laughed so hard. I don't think anyone else in this thread got it.
Frostyman is offline   Reply With Quote
Old 02-13-2013, 11:31 AM   #27
Vladror
Vladror's Avatar
Originally Posted by b.e View Post
.... You'd need to apply it after every wash. ...
good luck trying to wash it
(but i get your point)
Old 02-13-2013, 12:05 PM   #28
blackraven1425
Drives: raven at
There are no microfibers in this stuff, it's a silica suspension for the top layer. I think it was in the application video, but what happens with repeated touching is that it dissolves in the oils from your hand, and each time you touch it, it'll have less and be pushed out to the sides from pressure. If mild pressure alone were the problem, you wouldn't be able to throw a handful of mud at it and have is slide off. High pressure water is a problem because this stuff isn't exactly very hard.
Why would you ever wash it? Just give it a quick rinse with the hose and drive at creep speeds for about 3 seconds, and there's not going to be any water or anything else left on it.
Personally, if it were clear, I'd do everything except the door handles. Dry those off with a towel when you give it a rinse, and it's good.
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Get on the Waiting List for Sonax Nano Polish and Fine Abrasive DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 10-18-2012 09:34 AM
Amazing car physics engine Suffa Off-Topic Lounge [WARNING: NO POLITICS] 1 10-07-2012 01:51 AM
The Amazing Spiderman trailer vaporiz Off-Topic Lounge [WARNING: NO POLITICS] 13 02-14-2012 04:13 AM
Nano house $700. 1660 Off-Topic Lounge [WARNING: NO POLITICS] 1 07-29-2011 04:04 PM
