Old 02-11-2013, 03:31 PM   #15
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by dsgerbc View Post
I think you're reading from a correct location (misread what you were saying earlier), just past the pump, unless Subaru completely re-did their oiling for the FA engine.
Hmm that sucks. I was hoping it was at the end of the circuit
Under certain conditions the gauge bounces a bit so I was hoping that location wouldn't be ideal. I'll move it anyways, not going to hurt or take much time to do so. See what it reads just after the cooler. Could bypass the cooler too.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 12:07 AM   #16
robispec
Drives: Black frs project
we will be logging pressures at the track this weekend with the stock system then put our overkill solution back on and relog to see how everything changes.
robispec is offline   Reply With Quote
Old 02-12-2013, 02:28 AM   #17
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
So I finally hooked up the control unit for my gauges and installed the oil pressure gauge in the block (via the plug between the intake and AC).
At idle, I get between 750-850 kPa (108-123 PSI). That seems kinda crazy high, but whatever...
It starts dropping as it warms up, eventually settling at about:
idle: 115 kPa (16.7 PSI)
3k: 400 kPA (58 PSI)
4k: 450-500 kPa (65.2-72.5 PSI)
It's fairly steady from there until ~7k RPM where it starts dropping, eventually down to around 425 kPA at/near redline. That's 61.4 PSI.
Having heard the whole 10 PSI per 1,000 RPM that seems a bit low.
Also, I am running a fairly large oil cooler (19 row) which can account for some pressure loss.
So would anyone be concerned with 61 PSI near redline? Not sure if a bigger or smaller cooler would help/hurt. No cooler would increase it of course so I'm somewhat curious what people are seeing stock. Maybe I'll bypass my cooler and see whenever I have some time.
Dave, you are on the safe side
My observations:
I got my DEFI oil press\temp gauge installed recently
using stock fill 0W20
On a warmed engine (90С\190F oil) engine runs 1-0,9 bar \ 13-14 psi oil pressure
On the road the oil pressure seems to follow the tacho pretty fast and pretty straightforward in most cases - 2K rpm for 2bar \ 30psi , 3 for 3bar and so on till the bypass at 6 bar \ 87 psi sharp , no matter how you redline the engine
of course, when it's cold, the oil press could be higher
1 difference is I get steady 6bar under high load, no mater what
I will try these measures again when an oil cooler comes
MSTiFK8R is offline   Reply With Quote
Old 02-12-2013, 08:18 AM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
My observations:
I wish I had 87psi. A 26psi drop should not occur due to the cooler. Ugh.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 08:57 AM   #19
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
correction - that's with Motul 300V 0W20
I recall stock fill didn't show that sharp 6bar performance when hot
which oil cooler do you use?
Old 02-12-2013, 10:38 AM   #20
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Mocal 19row 235 matrix with -10 AN lines.
On the race car it resulted in a net loss of about 2-3 PSI loss with at least twice the hose length, remote oil filter, 4 90 degree bends and 2 45s.
Current setup in the BRZ is that cooler, a total of ~4 feet of hose, 2 0 degree fittings (basically zero loss), 1 90 and 1 45.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 11:05 AM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Oh also.. I'm hoping to not take a nap after work tonight and hopefully will do the following testing:
Tonight: Install the gauge sender sandwich plate after the oil cooler sandwich plate, install oil pressure there (and temp, or I may just move temp over to the location the pressure is currently read from). If I don't put the temp in the current spot in the block I'll reinstall the OEM plug there.
Tomorrow night: Move the gauge sender sandwich plate between the spacer and oil cooler sandwich plate if possible (lines are exact length more or less but hopefully they'll move up 3/4"), otherwise, remove oil cooler sandwich plate and drain the cooler or loop the lines.
Possibly Friday/weekend, bypass cooler and test pressure sender in both locations again, although I suspect the tests above (plus original/current config) will show the same data as this test.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-12-2013, 11:30 PM   #22
jamal
jamal's Avatar
Drives: Legacy GT
Does this car have one of those OEM oil to water cooler things? If so, getting rid of that would help- they have a pretty significant pressure drop.
And IMO you are measuring pressure in the right spot- right before the bearings.
jamal is offline   Reply With Quote
Old 02-12-2013, 11:31 PM   #23
OrbitalEllipses
Drives: Attitude
I do not believe we have those.
Old 02-12-2013, 11:45 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
No, OEM there is no oil cooler.
Old 02-13-2013, 12:04 AM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
They do not have an oil to water cooler.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-13-2013, 06:59 AM   #26
aaronosaurus
The data matters
Drives: WRBP BRZ
Have you taken measurements without the oil cooler in the loop? My search skills are failing me, but I can't find what pressures this vehicle should be running stock.
aaronosaurus is offline   Reply With Quote
Old 02-13-2013, 11:32 AM   #27
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I haven't yet. I currently have the temp and pressure gauges in a second sandwich plate above the cooler sandwich plate. I didn't drive the car today but I'll probably drive it tomorrow and get some readings from that location, then I'll move it before the cooler which will show exactly what loss I'm getting from the cooler itself.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 02-15-2013, 10:46 AM   #28
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I can't wait to see Robi's testing... but here's some more data from this morning.
As noted above I switched both sensor locations and oil weight. Most of this increase is due to the oil weight I'm sure. However, the gauge is actually STABLE now instead of bouncing often in the original location.
It's still "cold" here (~60 degrees) but on the same route today I showed the following oil pressures at approx 75C oil temp (at the sandwich plate after the oil cooler):
3k: 650 kPa (94.3 PSI)
3.5k: 680 kPa (98.6 PSI)
4k: 715 kPa (103.7 PSI)
High RPM to redline: Rock solid at about 750 kPa (108.8 PSI)
That's a massive increase from before. Again I think the pressure increase is a combination of weather (colder temps and thus colder oil) and oil weight. The stability of the reading is, IMO, related to the location of the sensor but Robi will hopefully be able to provide his experiences this weekend.
Looking forward to tracking the car next weekend instead of worrying about oil pressure
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Some observations Nardi330 AUSTRALIA 20 02-07-2013 06:18 AM
90 Day Anniversary ..some Observations Scooby South BRZ First-Gen (2012+) — General Topics 6 09-03-2012 11:17 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 04:29 PM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
