Old 02-11-2013, 11:10 PM   #15
[deleted]
GG
Drives: BRZ 6MT
yes +35 will poke out at stock height. a drop and/or adding at least -1deg camber will bring it back in. I am currently running a 17x9 +35 with a 245/40/17 and i have pics in a thread right below this one
[deleted] is offline   Reply With Quote
Old 02-12-2013, 02:09 AM   #16
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'd like to run these +35 but I'm worried about rubbing my fender in the front, I'm about 1.5" lower. Right now I am on 17x9 et42 with 245/40/17
Old 02-14-2013, 02:37 AM   #17
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
This is with 235s on the +45s. Just fits. Yet to test drive. Just got 1 to test fit. What do we reckon. Will they be OK?
I reckon the +45s are the way to go with coilovers.
Name:  ImageUploadedByTapatalk 21360826801.700472.jpg
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
Fly Guy (03-25-2014)
Old 02-14-2013, 09:04 AM   #18
wgnzlz
wgnzlz's Avatar
Drives: 2013 WRB BRZ Limted
Thanks for the picture. I am going to go with +35 offset. Due to my intended use of the car (mainly DD with some AutoX for fun) I probably won't go with coilvers. Instead I will be ordering RCE Yellows tomorrow and Koni Yellows in the near future.
Moto-East Tune, Perrin drop-in, P&L Catless Header and Overpipe, Motiv HFC, Invidia Q300, 17x9+35 Enkei RPF1, 245/40 PSS, RCE & Koni Yellows
wgnzlz is offline   Reply With Quote
Old 02-14-2013, 11:33 AM   #19
kykiee
kykiee's Avatar
Drives: 13 Subaru BRZ, 02 Toyota 4Runner
Originally Posted by wgnzlz View Post
I just found a set of +35 in stock. It's decision time.
I would like to know where you found this set
2013 Subaru BRZ Limited - GBS - 6MT - VIN #01197
kykiee is offline   Reply With Quote
Old 02-15-2013, 05:44 AM   #20
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
so far they are running fine with no rubbing
the +45 poke plenty at std height
Old 02-15-2013, 10:49 AM   #21
wgnzlz
wgnzlz's Avatar
I ordered them from Dezod Motorsports. I believe thay have a few sets left in stock.
Old 02-16-2013, 12:29 AM   #22
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
I 2nd dezod. That's where I got my set. Will be mounting 245/35/17 r1rs in the morning.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 02-18-2013, 01:37 PM   #23
feldy
feldy's Avatar
Ok so here are pics of my 17x9 +35 Rpf1's with Toyo R1R's 245/35/17 Stock height for now. Will be on RCE yellow springs here in the next month. Camber is set at -2degrees currently.
The Following 5 Users Say Thank You to feldy For This Useful Post:
brz7400 (02-18-2013), Fly Guy (04-15-2013), miodculae (02-24-2013), normancw (04-10-2013), whataboutbob (02-18-2013)
Old 02-18-2013, 02:36 PM   #24
BlaineWasHere
Grip>Drift
Drives: FRS
I didn't even know a tire that small existed! I'm running 245/40/17
Old 02-18-2013, 02:45 PM   #25
feldy
feldy's Avatar
Its a used set that I'm testing out for gearing reasons. I have a new set of 245/40/17 hankook rs3s in the laundry room waiting for spring.
Old 02-20-2013, 06:00 PM   #26
wgnzlz
wgnzlz's Avatar
Just got my wheels (17x9+35)! 15.6lbs on my bathroom scale.
The Following 2 Users Say Thank You to wgnzlz For This Useful Post:
SuperTom (02-16-2020), whataboutbob (02-22-2013)
Old 02-20-2013, 06:14 PM   #27
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Sweet, these will look good.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 02-20-2013, 06:18 PM   #28
wgnzlz
wgnzlz's Avatar
I hope so. I'm not going to install them until I get the RCE springs and camber bolts installed, which haven't shipped yet.
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
RPF1 are coming in 17x9 5x100 in Nov! Cheddar Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-23-2012 06:23 PM
