Old 02-05-2013, 06:04 PM   #15
Dustin@Dynosty
^ they can always be improved... Ferrea has some nice products to add, at least that is what is going in our built motor
Dustin@Dynosty is offline   Reply With Quote
Old 02-05-2013, 06:07 PM   #16
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Oh of course, everything can always be improved! I was just talking on behalf of the majority of people doing work to their car - although if you are buying a built bottom end, maybe you aren't " most " brz/frs owners.
What advantages can be had by utilizing ferrea products for these heads?
Tansey86 is offline   Reply With Quote
Old 02-05-2013, 06:22 PM   #17
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Originally Posted by Kochinopride View Post
I wonder if you guys can build me a block and all the trimmings to run up to 1,000HP and safely drive it every day
Give me 5Grand and i can get that.... 2JZ from japan hahaha
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 02-05-2013, 06:34 PM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
http://www.ft86club.com/forums/showthread.php?t=24283
Old 02-05-2013, 06:34 PM   #19
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Yes we will be beefing up the head as well.
FullBlown is offline   Reply With Quote
Old 02-05-2013, 06:52 PM   #20
JDM_GT86
JDM_GT86's Avatar
Drives: 2013 Scion FRS
I cant wait for the day I can run 20-25 psi in my FRS. My Tc on 15psi is a beast I can't even imagine what a FA20 can do.
Sent from my Toster, using Tapatalk 2
JDM_GT86 is offline   Reply With Quote
Old 02-05-2013, 07:01 PM   #21
J-Money
J-Money's Avatar
Drives: GT-86
Supercharger would be rough with alot of power.. just because the car is so light and going from 1-3 or even 4th gear the tires will be slipping all the time.. turbo would be a better option boosting up with a built motor due to turbo kicking in at a later time.
On
J-Money is offline   Reply With Quote
Old 02-05-2013, 07:06 PM   #22
dabocx
dabocx's Avatar
Drives: Scion FRS
On
Boost by gear is pretty handy actually. A friend of mine has that on his full race turboed 8th gen si.
dabocx is offline   Reply With Quote
Old 02-05-2013, 07:09 PM   #23
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
You can apply boost per gear as well. Don't give her full boost till 3rd or so.
dorifuto is offline   Reply With Quote
Old 02-05-2013, 07:38 PM   #24
civdaddy
Drives: Slow
On
Have you ever driven a 2.0l supercharged car? The power comes on pretty much in a linear fashion because the boost generated is rpm dependent being its design so traction would be better than a turbo for this car. Peak torque and hp would be at the same rpm as NA basically but just bigger numbers. A turbo setup will give you more torque and at MUCH lower rpm.
civdaddy is offline   Reply With Quote
Old 02-05-2013, 07:40 PM   #25
Tansey86
Tansey86's Avatar
Depends on what type of supercharger you are talking about. Twin screw comes on harder and faster than a turbo, centri comes on linear.
Old 02-05-2013, 07:49 PM   #26
civdaddy
Drives: Slow
I had twinscrew aka "roots" blower on my si and the power came on linear and full boost did not happen until near redline because the blower is drive via a BELT from the motor
Old 02-05-2013, 07:51 PM   #27
Tansey86
Tansey86's Avatar
You just described a centri blower - and although roots and twin screw use similar designs they are not synonymous.
Old 02-05-2013, 07:54 PM   #28
ModBargains.com
ModBargains.com's Avatar
Always good stuff...
ModBargains.com is offline   Reply With Quote
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm TyperRspec789 Mid-Atlantic 66 02-02-2013 02:25 PM
