Old 02-04-2013, 02:55 PM   #15
n2oinferno
Praise Helix!
n2oinferno's Avatar
I'm willing to bet it might be the caffeine. Gets to me too if I drink too much.
Old 02-04-2013, 03:03 PM   #16
Jedi1
STX build in progress!
Jedi1's Avatar
Drives: Whiteout FRS. Just Gorgeous!
http://www.prweb.com/releases/2012/12/prweb10224741.htm
OR
[ame="http://www.amazon.com/Keurig-K-Cup-Reusable-Coffee-Filter/dp/B000DLB2FI"]Amazon.com: Keurig My K-Cup Reusable Coffee Filter: Kitchen & Dining[/ame]
and just buy what you want to drink.
Jedi1 is offline   Reply With Quote
Old 02-04-2013, 03:05 PM   #17
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
you know you ARE getting older..caffeinated drinks may be taking its toll on your body now. Sounds like you may have early onset of IBS (irritable bowel syndrom) which is only worsened by greasy fatty foods and caffeine
Old 02-04-2013, 03:12 PM   #18
HunterGreene
Hail Magnet
HunterGreene's Avatar
Hate to say this...but my mother has acid sensitivity too, and drinks "Sanka." Can't say I have ever tried it, but they must be doing something right if its been around all these years. Good Luck!
And nothing saying you can't always switch to low-cal energy drinks, right? Just avoid the carbonated ones.
Originally Posted by Asterisked Accolade View Post
What about tea?
Originally Posted by Xdragonxb0i View Post
Switch to tea
Not if he wants to stay awake and not have an amazing caffeine withdrawal. No tea has as much caffeine as coffee. Sure, its easier on the system, but he'd have to drink about 3x as much liquids to get the same amount. I'm all for a liquid flush, but that's ridiculous.
Old 02-04-2013, 03:19 PM   #19
luxmn
First FR-S
Drives: Whiteout MT FRS
working out. using your own body to keeps your mind sharp and awake is the best way.
luxmn is offline   Reply With Quote
Old 02-04-2013, 05:41 PM   #20
Xdragonxb0i
Drives: ex500r
Easier on the system, and have some caffiene in it. Of course it wont have as much as Black Coffee, But what is? Mountain Dew and 5 hour energy?
Xdragonxb0i is offline   Reply With Quote
Old 02-04-2013, 07:37 PM   #21
bestwheelbase
Drives: 1985 P-Type
Caffeine withdrawal is no big deal. It is totally worth it to shake the dependence - If one so desires.
@sho220 do you know it is the pH level that is causing the issue?
Old 02-04-2013, 07:39 PM   #22
OrbitalEllipses
Drives: Attitude
That's probably the culprit. Acidity wearing away the stomach lining, etc.. Doesn't prolonged coffee ingestion cause ulcers?
Old 02-04-2013, 07:46 PM   #23
bestwheelbase
Drives: 1985 P-Type
Didn't realize it was so common. Yipes.
Old 02-04-2013, 07:47 PM   #24
OrbitalEllipses
Drives: Attitude
Note: Acidity is a flavor tone, but the actual pH of coffee IS in the acidic range.
Old 02-05-2013, 12:54 AM   #25
Xdragonxb0i
Drives: ex500r
Could you put milk in the reduce the acidcity p.h of 6.5-7.0 or i you can try something else
Old 02-05-2013, 08:52 AM   #26
HunterGreene
Hail Magnet
Milk won't reduce the pH as much as it just dilutes the coffee slightly. To reduce pH you either need to add a base or buffer. And some people just don't like the flavor of cream in the coffee.
Btw, a quick google search actually finds that dark roast coffee is apparently better for people with sensitive stomachs. Go figure!
Old 02-05-2013, 09:10 AM   #27
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I'd try drinking a half glass of mike before Ur coffee love making session, and finish the milk after. Milk is a base and should help with Ur upset stomach and counter react the acid. I used to drink tons of milk as a kid. I simply stopped as I got older. I started getting crazy daily heart burn recently just looking at food. Started drinking milk again, problem solved. Might not be Ur answer, but at 2.99 a gallon try it out.
TouchMyHonda is offline   Reply With Quote
Old 02-05-2013, 09:21 AM   #28
HunterGreene
Hail Magnet
Another trick is to eat a banana, since it partially coats your stomach wall while its in there. Professional eaters (heard this from Adam Richman) use this trick when they are going to be eating extremely spicy foods.
Reported idle-drop and crickets - got turned away empower-auto Issues | Warranty | Recalls / TSB 11 10-21-2012 11:36 AM
Turned down BRZ today. Le sad Nat BRZ First-Gen (2012+) — General Topics 29 09-30-2012 12:51 PM
Turned 21 today Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 23 07-22-2012 07:23 PM
June 1st turned out to be a great day to pick up my Asphalt FR-S TPO Member's Car Journals 23 06-06-2012 11:25 PM
ABS button....means ABS be turned off? Shadowsong6 Scion FR-S / Toyota 86 GT86 General Forum 35 12-06-2009 01:20 AM
