Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 02-24-2013, 11:46 PM   #15
nix
nix's Avatar
Drives: AVO BRZ
Originally Posted by 86 gts View Post
I gave up trying to get one from the US
Instead I bought a 135/70 17 inch 5x100 spare from Cardiff Automotive in Newcastle
As above, it has the same rolling diameter as the FRS OEM spare
I was also given a Subaru OEM plate/bolt to hold down the spare
All up cost was $150 after bargaining
They have 3 left if you're interested
I'll post pics in the next few days
I'm not sure it will clear the front brakes on our cars. Also $150 is a bit steep most wreckers I scouted sold them for $80-100. Maybe it was from a newer car.
I wanted a spare that would clear brembos so I bought a 2004 STI space saver for $50 from ebay, redirected it via shipitto for $8 since the ebay seller didn't do international shipping. Through TNT it was about $90 or something.
nix is offline   Reply With Quote
Old 02-25-2013, 02:43 AM   #16
LineNoise
Drives: Fiesta XR4, Toyota 86 on order
You should never be mounting a space saver on the front. If a front tyre goes flat, swap a rear tyre onto the front and put the space saver on the rear.
LineNoise is offline   Reply With Quote
Old 02-25-2013, 04:05 AM   #17
Panman
Panman's Avatar
Drives: 86 GTS
Maybe on a front drive car that's true, but not necessarily the case on RWD
Panman is offline   Reply With Quote
Old 02-25-2013, 10:13 PM   #18
nix
nix's Avatar
Drives: AVO BRZ
Putting one on the back is not even an option for me (turbo). On the front will lengthen the braking zone but at least the car will stay facing the right way.
Old 02-26-2013, 01:32 AM   #19
Gums
Drives: SWP BRZ
My understanding is that due to the LSD the space saver cannot be fitted to the rear?
Gums is offline   Reply With Quote
Old 02-26-2013, 07:42 AM   #20
HCBS3140
HCBS3140's Avatar
Drives: 2012 86GTS & 2002 Boxster 986
I have a Subaru WRX STi 17" space saver (2006) - it's never been used and it is the same height as my !8" works emotion wheels with Pirelli 235/40/ 18 PZero's. Doesn't matter where you put the spacer saver on your car as you are limited to 80Km (50 MPH). I purchased the wheel and tyre plus the bolt and ring for $100.00 from Subaru Used parts , 88 Levensdfale Road Moorabbin. To keep my boot flat I have cutout a piece of heavy duty Plyboard and added Foam rubber on the spare wheel side and my boot floor is once again pefectly flat. Also the puncture repair kit sits inside the space saver spare wheel. Problem solved.
HCBS3140 is offline   Reply With Quote
Old 02-26-2013, 03:53 PM   #21
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
have you tried fitting the wheel? a 2006 STI is 5x114x3 PCD
JP is offline   Reply With Quote
Old 02-27-2013, 02:59 AM   #22
HCBS3140
HCBS3140's Avatar
Yes, I have and it fits - it is a 17" space Saver with
5 x 100 stud pattern. I was told that 2000 up t0 2006 space savers were 5 x 100. I tried the wheel on my car before I purchased it.
Old 02-27-2013, 03:22 AM   #23
JP
Backyard Fabricator
then it's not a 2006 STI spacesaver they went 5x114.3 after 2004 for the better hubs/wheel bearings
Old 02-27-2013, 08:31 AM   #24
HCBS3140
HCBS3140's Avatar
THEN MAYBE IT'S A 2004 - Certainly doesn't look that old - tyre looks brand new. - could it be just a WRX space saver - I was told that after 2006 the wheel would not fit.
Old 06-16-2020, 12:48 AM   #25
Halo_2
Drives: 2014 MY15 86 GTS
What’s the difference between a wrx and wrx sti spare ?
Halo_2 is offline   Reply With Quote
Old 06-18-2020, 09:07 AM   #26
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
I have a 125/70/18 off an A3 Audi that fits the 86 and is the same diameter as My 245/40/18. As for putting a SS wheel on the front of a car; that’s just putting yours and other roads users lives in danger regardless of the speed Rating. 80% of braking and 100% of steering is done thru the front wheels.
Bodalenko is offline   Reply With Quote
First run 86's (Space Saver question) DriftEightSix AUSTRALIA 11 01-10-2013 07:25 AM
FR-S space saver sierra Scion FR-S / Toyota 86 GT86 General Forum 2 11-29-2012 12:18 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 04:30 AM
Where can I get a space saver wheel from? Ravine AUSTRALIA 17 08-23-2012 01:04 AM
Trunk space? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 34 04-13-2011 12:29 PM
