#15 |
Add lightness!
Drives: 17' WRX
Comparing different dynos and cars is pretty dumb. Might as well compare track times from different tracks.
Seems like a nice package. |
#16 |
Drives: 2013 White Out FR-S
LOL not bad considering it was 69 degrees. That car would never make that in florida its like comparing a dyno run in high elevation to ours its not the same situation. Most cars even with a tune one isnt making that in our weather. Infact even there base run was on a different date with 80 degrees and low humidity. Our stage 2 tune makes about 7-8whp more power in other areas of the country due to geographic location alone.
#17 |
#18 |
#19 |
Need a baseline dyno.
2022 BRZ Build 2013 FR-S Build |
#20 |
Drives: 2013 Asphalt FR-S
Was this with your stage2 tune? Sorry, not sure if I saw it mentioned.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
#21 |
#22 |
OK. Just looking for a way to figure out what the actual gains were on the same dyno.
| The Following User Says Thank You to DarkSunrise For This Useful Post: | simpleisbest (01-16-2013) |
#23 |
most dynojet numbers are comparable but you have to remember that geographic location plays allot in end results. this car be it was not dyno'd prior on the same dyno the baseline is still valid since we are located in the same general area
#24 | |
Drives: 2013 Hot Lava Scion FRS
#25 |
my car will be going back to stock later on this week to get our intake as well as another one tested with and without a tune
#26 |
Awesome. Keep us posted! If a tune is required then Im going to have to hold off for more $$$ since I just purhased a Perrin carback.
#27 |
already stated in the intake thread no tune needed our intake doesnt bog or cause flat spots
#28 |
| Borla cat-back w/ UEL header tested at the track | BeltedBiscuit | Engine, Exhaust, Transmission | 17 | 12-30-2012 02:57 AM |
| AVO Inlet Kit tested at Drift Office | AVOturboworld | Engine, Exhaust, Transmission | 26 | 10-02-2012 04:21 PM |
| Navy developed and tested a railgun | SVTSHC | Off-Topic Lounge [WARNING: NO POLITICS] | 21 | 03-01-2012 07:43 PM |
| Turbo FR-S Tested For Drift Reportedly Spotted | DanPO | Scion FR-S / Toyota 86 GT86 General Forum | 123 | 01-24-2012 01:25 AM |
