Old 12-04-2011, 01:04 PM   #15
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
I've been looking or 17x8.5s for 235/40/17s. Only food a few there plenty of 17x8 though.
I just bought a set of Kosei K4R 17x8.5 for my Bimmer and they are extremely light (15.4 lbs) for $199 but its for 5X120. Not sure if they make it in 5X100. I only found 17X7 in 5X100 and its only 14 lbs.
Kosei K4R
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 12-04-2011, 03:42 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Kosei K4R
17x7 only, already checked
PLENTY of 17x8.5 options in 5x114.3 though
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 04:16 PM   #17
ft86Fan
ft86Fan's Avatar
Wow, you guys are good :-)
I bought the 17X8 and 17X8.5 Kosei K4R. Both of them has 5X114.3 stamped on them even though its 5X120. I asked TireRack about it and was told that most likely the mold for the blanks was for 5X114.3 but then they drill the holes for whatever bolt pattern they want. I'm sure they can do the same for 5X100. I guess they are not doing it now because its not popular but wait until our cars come out :-)
Old 12-04-2011, 04:33 PM   #18
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I was just looking up rims with the 5x100 and they all suck ass to me.
SUB-FT86 is offline   Reply With Quote
Old 12-04-2011, 04:56 PM   #19
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Do the math. It'll increase diameter unfavorably enough. If you want street tires 235/40/17s will lower the diameter and therefore shorten the gearing. Since the op is talking track use I made the assumption that he cared more about performance impacts over street tire availability. There's a chart in the tire width thread showing these sizes (with diameter changes) and prices of good tires that I threw together last week.
Combine the worse gearing with the additional sidewall flex and the only slight bump in width.. I see it as pointless. Unless you are trying to save money, tires will be about ~30 (or 50 for re11s) cheaper per tire for the good street tires versas 235/40/17s. Sadly RS-3s are not sold in 235/40/17 but I plan on contacting them to see if they'd consider the size. Compared to stock tire pricing is 1-23 bucks per tire cheaper.
A) Shortening the diameter for tighter gearing isn't what I'd want. That means you have to shift out of second gear sooner, and that can be an issue for auto-x.
B) Sidewall flex is not an issue. And actually, the tread pattern is better with the 225/50/16's versus a narrower 16, where the tire doesn't have a rough edge to the tread so it rolls over better under hard cornering.
I ran 205/55/16's, 215/45/17's, 225/40/17's, and 225/50/16's on my Impreza (which only has ~170hp mind you, and weighs 2600lbs, very simular to the BRZ/FRS and with the Macpherson front suspension setup too) and the 225/50/16's were BY FAR the best for every scenario (track, auto-x, mountain roads, and daily driving).
Kostamojen is offline   Reply With Quote
Old 12-04-2011, 04:58 PM   #20
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
Hey sorry, I'm not familiar with racing and wheel size.
I understand the weight saving benefits of a smaller tire, unsprung weight, and better cornering,
but why do sports cars such as the Cayman R or Ferrari California come with large tires if smaller tires are better for racing?
quik1987 is offline   Reply With Quote
Old 12-04-2011, 05:01 PM   #21
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
porsche and ferraris run larger wheels and tires because they need to clear their massive brakes which are often 15"+ with supersized calipers
DuMa is offline   Reply With Quote
Old 12-04-2011, 05:08 PM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
There are plenty of good wheels in 17x8 though..
Volk, etc make wheels that will work too even at 17x8.5, but I have no intention of buying wheels like that unless they are used (I buy wheels for function and the functional difference is just not worth the price to me).
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 05:10 PM   #23
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
As proven by GRM and others, the gearing will make up that once or maybe twice per run shift. I don't hit 60mph in second and I rarely ever have an autocross that requires me to shift into third.
Sidewall flex can definately be an issue.
Laptimes?
I like the Rotas though
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 05:15 PM   #24
quik1987
quik1987's Avatar
This car has a big brake option 6/4 pot brembos though, requiring 18 inch wheels.
We know 18s and 19s fit
So what set up is better?
Big Brake Kit with ULTRALIGHTWEIGHT 18/19
or 16s with 2/1 pot brakes?
Old 12-04-2011, 05:17 PM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Test it and find out. I'll be running 235/40/17s myself. I'll take the extra width and slightly shorter gearing myself. I have no intention of ever putting 18" or larger wheels on this car and would only consider 16s if I were running R comps in 245/45/16.
Others opinions and experience will vary so you probably just need to find which you like the most.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 08:36 PM   #26
Kostamojen
Really? I've had a few that require 3rd or I bounce off the rev limiter... But I have a 6200rpm redline too.
I worry more about tires that DON'T have sidewall flex. Although that might be better for drifting.
Old 12-04-2011, 08:41 PM   #27
fatoni
i dont think the big brakes are going to stop any faster. they are just going to be able to stop better for longer
Old 12-04-2011, 09:59 PM   #28
DuMa
DuMa's Avatar
agreed. biggest i would ever run is maybe 245/40/17. the prices for 18" tires and wheels disgust me
18" OEM Wheels!!! madfast Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 12-11-2011 03:15 PM
Toyota Holds "FT-86 Fastest Painted Website" Event to Help Launch FR-S / FT-86 Snoopyalien24 Scion FR-S / Toyota 86 GT86 General Forum 35 11-26-2011 07:56 AM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 05:58 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
