Old 01-12-2013, 06:31 PM   #15
mla163
Overthinking it
Drives: BRZ in CS
Originally Posted by ABQautoxer View Post
I have two of the different version of the same ones:
http://www.purems.com/Products/PROTE...-Lift-Jack-Pad
1006 not the 1007. Love them.
These are great. If you can jack up two wheels at once, you can change tires in about 20 minutes.
mla163 is offline   Reply With Quote
Old 01-12-2013, 08:33 PM   #16
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
If it takes you 20 minutes to swap wheels with a cordless impact (with adequate torque) and a decent jack capable of lifting one side of the car at a time, you're doing something wrong (or just taking your time and working very slowly).
With the rather inexpensive tools I have, I average 10 minutes to swap tires on my cars, if I have everything set out and am in a hurry, 6-8 minutes for all of them isn't that difficult. IIRC my personal record is between 5 & 6 minutes, including torquing the lugs with a torque wrench. Never used a torque stick, never felt the need.
I've used several different cordless impacts and jacks over the years, but my current impact is a 19.2V Sears impact (cost $100 -- I already had the battery and charger), and I use a Harbor Freight lightweight aluminum floor jack ($60). I have the Flyin Miata jack adapter, but usually use a hockey puck with a slit cut in it like I have for years.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
CSG Mike (01-12-2013)
Old 01-13-2013, 01:00 PM   #17
Dezoris
Dezoris's Avatar
That adapter is cool. With the FRS you can lift one side of the car with the jack at the front pinch weld so its not needed. But if anyone else has tips post up?
Old 01-13-2013, 01:39 PM   #18
xwd
I use the adapter pad either way it helps distribute load so you aren't sitting right no the pinch weld with a flat surface.
Old 01-13-2013, 07:35 PM   #19
Dezoris
Dezoris's Avatar
I will pick one up thanks!
Old 01-16-2013, 09:18 PM   #20
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
If you use an adapter (something like a puck), it's not a problem to lift the car from somewhere other than the factory jack points? I figured I'd punch through some soft part of the floor panel jacking it up from the middle.
NRGBalanced is offline   Reply With Quote
Old 01-16-2013, 09:47 PM   #21
Miniata
Some cars you might be ok to jack in the middle of the car on the pinch welds, but some cars may start to deform if all the weight of one side of the car is in the middle. Since the pinch welds are reinforced at the jack points, and most cars are weight biased towards the front end, I just jack at the front jack point, and the whole side of the car can be lifted by just jacking at the front jack point, no need to jack in the middle of the car. My lightweight aluminum Harbor Freight jacks don't lift all that terribly high, but are still enough to lift one side of the car at a time. I have heard of people using a 2'-3' section of 2x4 and cutting a slot in the middle to fit around the pinch weld and using that in the middle since it would help distribute the weight better, but have never tried it myself.
Old 01-21-2013, 10:40 AM   #22
TemeCal
Drives: 86
@ABQautoxer or @dwx -
Trying to figure out which jack pad to get for my FR-S. Which model (1006 or 1007) will work with our cars? I noticed they're differently sized, and want to make sure:
A) it'll fit under a car with a 1.5" drop
B) the grooves in the pad are deep enough for the seams on our car
Thanks!
TemeCal is offline   Reply With Quote
Old 01-22-2013, 09:02 AM   #23
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
It is not a question of which fits the car, its which fits your jack. the 1007 is narrower and mean to sit on top of a smaller portable style jack's lifting point. The 1006 is completely flat on the bottom and can be used with most typical full size floor jacks, HF aluminum jacks, and lifts.
TomR
ABQautoxer is offline   Reply With Quote
The Following User Says Thank You to ABQautoxer For This Useful Post:
TemeCal (01-22-2013)
Old 01-22-2013, 09:54 AM   #24
TemeCal
Drives: 86
Ahhh....makes complete sense now. I assumed they were just different sizes, with different groove depths. Thanks for the clarification!!
FS: NRG Quick Releases, Hub, Quick Lock, Steering wheel Pekingduck Interior Parts (Incl. Lighting) 7 02-12-2014 05:59 PM
Motor swaps.. Brian S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-19-2012 04:18 PM
Engine Swaps Available 88blacktop Scion FR-S / Toyota 86 GT86 General Forum 2 05-04-2012 06:45 PM
Engine Swaps and Kit Cars! merlin2111 Other Vehicles & General Automotive Discussions 27 01-27-2012 05:18 PM
The AS1 and engine swaps Syldrin Engine, Exhaust, Transmission 36 01-25-2012 10:45 AM
