#15 | |
Site Moderator
Drives: Stuff
I like a looser car so IMO the RCEs would be a much worse setup for me, but I haven't tested them. If RCE wants to send me some I'll datalog and compare.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#16 |
A closer comparison would be RCE and Swift BRZ springs, which I'm personally torn between. They both offer less than 1" drop, same 4.5 rate for the rear, but the Switf BRZ are slightly softer up front.
#17 |
Drives: E46 M3 (daily) / EG Civic (track)
#18 | |
Drives: really slow...
If the stock shocks had better high speed compression damping you can better argue the merits of each spring. To me the RCE 20mm drop and square 4.3k/4.3k setup is better for my driving style so that's subjective but is an additional 5mm drop bad? On a really bumpy track.. probably? On a different, can someone confirm if the Eibach is more progressive than the RCE. I thought they were. |
| The Following User Says Thank You to RYU For This Useful Post: | Gixxersixxerman (01-11-2013) |
#19 |
The Pro-Kit is 50lbs softer up front and 24lbs stiffer in the rear than RCE yellows.
The Pro-Kit is advertised at a 1" drop (25mm) but people are reporting only 7/8" (22mm). The 2mm gap at the wheel is probably less than a millimeter of lost travel at the shock. The specs of both RCE and Eibach springs are great. Just different. Both work and both will add performance gains. I'm just posting facts because, of course, this is the internet and not everything on the internet is fact. Technically, both springs are progressive but that's only to achieve the ride height for each kit. Once you get to static height the springs become linear. |
#20 | ||
Drives: WRB BRZ MT
Im not into drifting anything, just traditional apex-cornering. Since the pro-kits are stiffer in the rear and softer in the front, Im assuming it will have frs-like handling characteristics (as opposed to brz) |
#21 | |
Drives: 2013 WRB 6MT BRZ Ltd.
This means the Pro Kit is closest to the stock BRZ spring rate ratio, but slightly more oversteery (though not anywhere near as much as the FRS). |
| The Following User Says Thank You to Smudgeous For This Useful Post: | itisthumper (01-12-2013) |
#22 |
Drives: WRB BRZ MT
It seems the equal balance for the RCE yellow would cause a lot of understeer, no? Is it really better for the track?
#23 | |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
#24 |
I'm glad this thread was started so thanks OP.
I was wondering about this topic in another thread (I was off topic in that one) and this question never really got answered. I currently have the Eibach pro-kit springs and really like the feel of them, but have only used them on the street so far. |
#25 | |
I do think Eibach springs are fine FWIW. - Andrew Last edited by Racecomp Engineering; 06-01-2017 at 02:10 PM. |
| The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post: | D_Thissen (10-16-2014), jmark (06-01-2017), new2subaru (04-27-2018), TofuJoe (11-20-2016), transition (03-15-2014), whataboutbob (01-13-2013) |
#26 |
AutoX-10/10ths every run
I noticed a reduction in understeer after mounting the RaceCompEngineering springs along with a bunch of Whiteline stuff and getting an alignment.
| The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | console_cowboy (05-18-2013), Racecomp Engineering (01-13-2013) |
#27 |
I just completed a buffet style track day @ Streets of Willow yesterday. My only mods to the entire car are HP+ front brake pads and RCE yellows. What a fun car.
It's properly neutral imho. Any adjustments to understeer/oversteer was made easily by adjusting tire pressures (+-2 to 4psi). I was able to induce long drifts on the skidpad no problem but could also induce a lot of push in the front if needed. Its when the car does these things when you don't want it to is when it becomes a problem. I had about 2.5hrs of all-you-can-drive track time . Awesome. I hope more track day coordinators take note. I'll pay more for no run groups! Once I kill these Prius tires is when i'll look into coilovers and more adjustment. The RCE yellows are an excellent Stage 1 mod. |
| The Following User Says Thank You to RYU For This Useful Post: | whataboutbob (05-19-2013) |
#28 |
Drives: Mazda 3
If a car is already perfectly setup, then a stiffer front spring will introduce more understeer. But a stock BRZ/FRS with zero camber and macpherson struts in front will benefit greatly from stiffer front springs to keep body roll and camber loss to a minimum.
| Help removing yellow spots | MattR | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 56 | 06-04-2016 02:17 AM |
| White n' Yellow. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 08-02-2015 05:01 AM |
| Does this mean a Yellow BRZ/GT-86 will be in Initial D Stage 6? | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 43 | 06-23-2015 02:53 PM |
| Yellow fog tint looks awesome! | DookDookDGM | BRZ Photos, Videos, Wallpapers, Gallery Forum | 37 | 11-07-2012 04:40 AM |
