Old 12-13-2012, 04:30 AM   #15
Supermassive
Supermassive's Avatar
As of right now I have not heard of nor seen any issues regarding FI on this motor, short of frying clutches...which is pretty much expected. I asked a similar question in my thread regarding what would break first and since no one really knows all we can do is wait and see. Some people think the ring lands will go first but seeing the stock pistons I don't really think that's gonna be the case. The con rods are already pretty beefy, which you can see in the Full Blown post about their 1000+ HP rods, I'd say they will happily contend with 500ish HP with no issues, but it remains to be seen, because i am sure we might see some stretching when people start pushing the redline higher to get more legroom in the RPM band. As for heat...well it would be silly to run a high HP setup without an external oil cooler, it's one of those things that makes up those "proper supporting mods" that people don't seem to take into account when they do the math concerning an FI install.
I'm gonna go with the diff being the weak link since the stock gearing is way short for the power we are seeing coming out of these FI setups. It won't be long before there are taller ratios built for high power but at the moment the only real option is Lexus IS final gearing kits which aren't really made for high power applications.
The other thing I expect to fail pretty quickly is the stock rings, dunno how hard they are, but with the boost adding additional pressure to the rings they may wear faster and cause blow by. Simple enough to fix, but I haven't seen any offerings from performance brands regarding piston ring kits for FI applications.
Supermassive is offline   Reply With Quote
The Following User Says Thank You to Supermassive For This Useful Post:
NickFRS (12-13-2012)
Old 12-13-2012, 04:38 AM   #16
NickFRS
Drives: 2013 Asphalt FRS
This is a solid answer that's in the ball park!!!
Yes I suspect the same thing. The stock rear diff is deff not a race application. As for the gear ratio I don't think that should be an issue. Shorter gear ratios can be in the favor under 400WHP. I mean who really goes over 150MPH on a track? Or who needs to. It's mainly about how fast it gets there. This car wasn't exactly made for a straight line. This we all know or else we wouldn't have bought our twins! And if you bought this car for a straight line maybe you should consider trading it in for a supra. Stock clutches have been burnt. So what HP applications have burnt these clutches? Do they handle 300WHP responsibly? when do they start "slipping"
Sorry if you already have posted this I was bored at work and didn't recall seeing anything about this sort of topic.
Also if there is one thing I learned about boosted Boxer engines is that they are usually closed deck. This is an open deck. So there are some changes in this FA engine then the EJ engines i'm used to seeing.
NickFRS is offline   Reply With Quote
Old 12-13-2012, 04:41 AM   #17
NickFRS
I'm also wondering if the Crawford built short blow is really a viable option for a turbo'd application. I know they make awesome pistons but is it really needed? Maybe we can get some professional input?
Old 12-13-2012, 04:58 AM   #18
NickFRS
P.s It's time for you turbo kit people to start bragging about your kits!
Old 12-13-2012, 05:02 AM   #19
Supermassive
The stock clutch starts slipping when you head north of 300HP so technically you could run the stock clutch up to that point but I tend to err on the side of caution since I have actually been stranded on the side of the road with a fried clutch on a 3000GT.
As for the gearing...the shorter gearing being subjected to higher power leads to much more shock in the driveline. Taller ratios aren't necessarily intended for higher speed, they are intended to make better use of the power generated. Remember any power that causes loss of traction is wasted power, taller gearing can help to reduce wheel spin and better transfer that power to the ground...and in the case of our car can help make the rear end more controllable, as fun as it is to be sideways, sometimes it's just as fun to hit a turn just right at the raw edge of traction. So for those of us who want to maintain some semblance of traction when the power is on, taller gearing helps alot with that.
Also who really goes 150mph on a track? Well if I can I do, I used to love my liter bikes because there are quite a few tracks you can break 150mph easily. If I have the ability to go that fast I would definitely go that fast...key word is ability though, that includes how comfortable I am with what I am riding/driving
That engine is waaaaay overbuilt for street applications but for a pure drag car it's a tuner's wet dream...only problem is there are no performance heads yet, so it's kind of a moot point...but the fact that it exists is reason enough to be excited about this platform...it will be neat to see what cars our little FA20 gets stuffed into
Old 12-13-2012, 05:04 AM   #20
Supermassive
Soon...supposedly mine will be shipped to me next week...fingers crossed!
P&L Motorsports Stage 1 btw...
Old 12-13-2012, 05:14 AM   #21
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Theres already so many threads on these topics on the forum.. ... and/or Read!
So many threads like this popping up lately
Ravenlokk is offline   Reply With Quote
Old 12-13-2012, 05:14 AM   #22
NickFRS
Very nice! and thanks for the solid answers.
I myself have gone 160 in my STi plenty of times on straights in good weather at the track.
I see what you mean about the taller gear ratio but that might get spendy in the long run. I don't see a problem with the current gear ratio sitting around 300WHP if you run a wider tire. Around a 18x9-10in. I believe for a normal person 300WHP would be perfect for the average autoX/weekend track guy. ESP if you DD the car.
BUUUTTTTT I would love to see a taller gear ratio 400+WHP FRS with some 18x10+ wheels on the track..... I could only imagine the track times.
Old 12-13-2012, 05:15 AM   #23
NickFRS
Already said sorry if I thread jacked! Maybe you should read! :happy0180:
Old 12-13-2012, 05:17 AM   #24
NickFRS
Oh and I searched "Blown turbo engines" and found this
h: Keyword(s): blown, turbo, engines
Thread / Thread Starter Last Post Replies Views Forum
Question for the Turbo community. ( 1 2)
NickFRS
Today 01:15 AM
by NickFRS
22 268 Forced Induction
Singapore !!! ( 1 2 3 ... Last Page)
sazu
12-09-2012 03:32 PM
by Burn
189 16,892 ASIA
supercharger or turbo? ( 1 2 3 ... Last Page)
RussellRockets
11-28-2012 03:54 AM
by MANDALAY
137 5,450 Forced Induction
fr-s/brz vs 28k cars ( 1 2 3)
sofrsnsokleen
11-16-2012 06:20 PM
by OrbitalEllipses
45 3,257 FR-S / BRZ vs....
Open ECU? ( 1 2 3 ... Last Page)
jedibow
11-09-2012 12:23 PM
by D-VO
212 17,301 Engine, Exhaust, Transmission, ECU
FR-S vs. 370z, end all be all of discussions ( 1 2 3 ... Last Page)
OldSkoolToys
09-25-2012 03:58 PM
by madoka
1,512 106,274 FR-S / BRZ vs....
How is this not an RX8? ( 1 2 3 ... Last Page)
Prof1ig8tor
09-05-2012 05:08 AM
by HunterGreene
336 36,448 FR-S / BRZ vs....
Super vs Turbocharging the car ( 1 2 3 ... Last Page)
Partial Stall
08-03-2012 08:12 PM
by Coheed
95 9,672 Forced Induction
need donor for treadstone turbo kit ( 1 2 3 ... Last Page)
treadstone performance
07-19-2012 07:31 AM
by 3MI Racing
113 10,106 Forced Induction
Subaru warranties ( 1 2)
brzzz
07-13-2012 11:19 AM
by DeeezNuuuts83
34 2,055 Subaru BRZ General Forum
Autocar: BRZ vs. MX-5 vs. 370Z ( 1 2 3 ... Last Page)
Levi
04-12-2012 02:30 PM
by Deslock
183 18,732 Subaru BRZ General Forum
Engine technology thread. ( 1 2 3 ... Last Page)
Dimman
04-12-2012 11:18 AM
by Homemade WRX
770 57,801 Engine, Exhaust, Transmission, ECU
Poll: Supra Owners ( 1 2 3 ... Last Page)
BoostJunkie
03-23-2012 08:07 AM
by racerkyo
81 6,297 Other Vehicles & General Automotive Discussions
Modified Mag FR-S review - A New Breed of Sports Car ( 1 2)
poormans_LFA
01-27-2012 08:55 AM
by tripjammer
31 4,923 Scion FR-S / Toyota 86 GT86 General Forum
Poll: FT-86 vote for you engine layout 2.0L NA vs 2.0L Turbo vs 6 banger ( 1 2 3 ... Last Page)
Allch Chcar
08-16-2011 11:31 PM
by Slide
87 6,889 Scion FR-S / Toyota 86 GT86 General Forum
Toyota FT-86 G Sport Concept from Gazoo at 2010 Tokyo Auto Salon! First turbo FT-86! ( 1 2 3 ... Last Page)
trueno86power
08-03-2011 10:43 AM
by Sport-Tech
214 77,233 Scion FR-S / Toyota 86 GT86 General Forum
FB engine details from C&D
chulooz
05-06-2011 12:38 PM
by chulooz
4 1,142 Engine, Exhaust, Transmission, ECU
200hp / 2700lbs - Really? ( 1 2 3 ... Last Page)
Old 12-13-2012, 05:20 AM   #25
NickFRS
Didn't see much about blown up engines from those topic heads and i'm not about to go through page by page.
The Following User Says Thank You to NickFRS For This Useful Post:
fuddbutter (12-13-2012)
Old 12-13-2012, 12:40 PM   #26
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
I for one want an engine to blow. That might seem like an odd request but how do you know what goes wrong until it breaks? These cars as a whole aside from the clutch have been taking more abuse than rihanna and have no scars from it. We have a great platform from drag racing to track applications. When a motor blows, ull know about it.
Tansey86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Tansey86 For This Useful Post:
fuddbutter (12-13-2012), NickFRS (12-13-2012)
Old 12-13-2012, 03:26 PM   #27
nonicname
Drives: it has 4 wheels and a motor
and @ freeman re read my post. I SAID N/A MOTORS BLOWING AND ASKING IF ANY TURBO ENGINES HAVE BLOWN YET! BLOWN = POPPED. Now back on topic
SHOW ME AN N/A BRZ/FRS MOTOR THAT HAS BLOWN!
if you are going to be spreading rumours at least have some back up.
nonicname is offline   Reply With Quote
The Following User Says Thank You to nonicname For This Useful Post:
Freeman (12-13-2012)
Old 12-13-2012, 03:30 PM   #28
be6sti
be6sti's Avatar
Drives: 2013 scion frs
If it hasn't happened yet its just a matter of time before someone finds the power limit of these engines... There's a limit to an engines capabilities they aren't magical
"Fuck it lets go!"
be6sti is offline   Reply With Quote
*Help Develop Parts for the FRS/BRZ Community* Lonewolf Scion FR-S / Toyota 86 GT86 General Forum 480 06-10-2022 09:40 AM
Thoughts on car community mottor Other Vehicles & General Automotive Discussions 70 12-18-2012 09:27 PM
Will this be the go-to FRS BRZ forum/community? #87 Off-Topic Lounge [WARNING: NO POLITICS] 17 05-28-2012 04:58 PM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
