#15 |
Drives: Raven FR-S
if your friend is coming from an crz to an sti it just depends how fast he can adapt to the new car its way faster than the crz and the awd is completely different from the fwd crz. how long has he been autoxing the sti?
| The Following User Says Thank You to Speedy000 For This Useful Post: | SuperDave (12-11-2012) |
#16 | |
Drives: White Out FR-S
Autocross usually has a safeguard for hard launches for unfair starts, namely, a tight S shape tuinnel of cones on it's side at the very start. Unless the course has long and wide turns and 1 long straight, the FR-S' lightness and agility will make mince meat out of an STi stock for stock in a small track. Ask any MX-5 or Minis at an autocross event to see if they are scared of EVOs or STis. On a proper higher speed circuit, the MX-5s, FR-S, S2000, RX8's will have a much tougher time as the STi wouldn't have to use as much brake and let off the turbo. The STi is fast, but on a small and tight course (such as autocross), it needs more braking distance, has less throttle response, it's heaviness and the inherent understeer of the AWD system will all make hugging around the cones a more difficult prospect. Fast does not always equal quick. Last edited by ST185RC; 12-06-2012 at 03:26 PM. |
| The Following User Says Thank You to ST185RC For This Useful Post: | DanoFA20 (12-07-2012) |
#17 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
@ST185RC
Yeah, I could see that if the distance from the start to the first corner in the circuit was close, but the last time I AutoXed, you could get up to around 55 before the first turn, and that was in my FR-S. Also, fast = quick. You mean agile.
| The Following User Says Thank You to raul For This Useful Post: | fatoni (12-06-2012) |
#18 |
Registered you sir
Drives: 99 impreza coupe
Fast is quick.... Rubber makes a significant difference favoring the sti
| The Following User Says Thank You to chulooz For This Useful Post: | karma003 (12-06-2012) |
#19 |
Drives: Mazda RX-8 MT, Scion FR-S MT
I went autocrossing with my rx-8 group a couple of years back. I believe my friend with his complete stock rx-8 was about 6-7 seconds faster than evos IVs and older STIs. But then again, he's competing in national competitions now
| The Following User Says Thank You to RowTarEEE For This Useful Post: | dori. (12-07-2012) |
#20 |
auto-crosser/drifter
Drives: 2013 scion FR-S black M/T
We both started auto xing about the same time 5 monthes ago. He just got thr sti yesterday thou
#21 |
Drives: Whiteout FRS- autocross ready
If he is new to driving the STi he will have his hands full figuring out the understeer, etc. You need a momentum course where you can hold speed through most of the course. If it is tight with lots of slowing and accelerating you will have to work hard to stay close to the STi. Good Luck- we are all counting on you.
| The Following User Says Thank You to MTCRX For This Useful Post: | karma003 (12-06-2012) |
#22 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
I wanna say sti will take it. Just because of the advantages. AWD, turbo and sticker tires.
#23 |
Well I got some new tires, the awd also makes the car heavy & turbo adds lag for a small coarse such as auto x
#24 |
Drives: MUNI
it's like bring a stick to a gun fight.
#25 |
Registered you sir
What types of speeds are you seeing in these events?
#26 |
My VTEC fluid is full
Drives: EFF JAY
The GR STi is just such a poorly set up car from the factory. It is soft & floaty, feels like a boat. The understeer is a test to your patience. I autocrossed my '11 STi a few times (when my s2k was down). It was just a horrible/waste of time.
Like I stated on my last post... given equal drivers, I do not see how a GR STi can pull faster times at an autocross. |
#27 |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Course and the driver mod are everything. I think the BRZ would be a much better auto-x car though. The AWD doesn't really help with auto-x. The turbo lag kills it unless its a corvette style course and the STI is just too heavy in comparison. Only real downside to the BRZ is the crappy tires.
#28 |
Señor Member
Drives: white BRZ 6MT
unlike about half the posters here, this contest is NOT cut and dry like a drag race
| The Following User Says Thank You to dori. For This Useful Post: | karma003 (12-11-2012) |
